I have an F33 error code on my washer. Please advise
F33
System leak
If after 30 seconds the control does not detect water entering machine,
the valves will be turned off and the error code will be displayed.
OR
If the control has turned the water valves on, and after 8 minutes, the
flow sensor has detected 10.5 gallons of water passing through it, but has
not detected the pressure switch trip, the valves will be turned off, and
the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Possible Causes / Procedure
1. Check for crack or holes in the washer tub and pressure switch hose.
2. Replace components if necessary.
In the small service manual inside the machine says:
F33 : When the connection between ump and the CCU is lost. Checkn wire harness connections to the pump and the CCU
CCU = CENTRAL CONTROL UNIT
SOURCE: error code f33
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
yes i do but i press cancel 2x and it doesnt clear it. i unplugged and back but still doesnt cancel. it wont open and cancel is not being processed.
found a small washcloth blocking the front little holes. Maybe that was it.
This is the pressure switch HOSE. Probably has pin hole in it. That's what cures my F33 error code. Easy do it yourself and cheap.
