I have a Behringer MX8000A mixing desk. It has worked fine for a few years, but recently it's started playing up. After a varying amount of time (sometimes as soon as you turn it on, sometimes 10-20minutes later), all the Peak and -20db lights come on on all channels. Also, normally both power lights are on, but when all the lights come on as above, the -18v power light goes off. What's going on?!
To solve this problem ,replace voltage regulators for +18 and -18 volts with lm338. these have a higher current rating and are directly replacable.
Posted on Jan 26, 2010
  • John Huffhines Feb 03, 2011
    How do you know which voltage regulators are 18
Having problems connecting speakers via a power amp in to my behringer x2222 usb mixing desk - im not getting the ins and outs correct :(
I had a like problem with a crown amp. I found it was in the amp settings , nothing to do with the mixer set up. We had it a mono setting. Take a look at your amp set up book, i'll almost bet thats where the problem is
Dec 06, 2012 | Behringer Xenyx X2222USB USB Audio Mixer
22 samsung syncmaster S22B150 led monitor color settings problem how to fix
I have the same monitor. It was working just fine for almost a full year and recently I started to play games on Furg Games Play Free Online Games for a few hours a day and my eyes started to hurt. I've tried to change brightness and contrast several times but still I can't stay more than an hour in front of it.
Oct 11, 2012 | Samsung Computers & Internet
How to i test to see if a mic element is still working
The easiest way is to plug it into a mixing desk or microphone input on a sound card. However, whichever you do you will need phantom power as this microphone requires it.
Aug 23, 2012 | Behringer C-1 Microphone
Behringer XENYX 2442 FX: Turntable into CD/tape IN. CD/tape OUT connected to USB device IN. Why is there no signal from mixer to the computer?
If I read correctly, you have outputs on the Behringer (CD/Tape Out) connected to inputs on the Behringer (USB Device In). Is that correct? If so, try going from CD/Tape Out directly to the computer. If not, please explain what the "USB Device In" is.
Apr 30, 2012 | Music
Hi,I was jamming yesterday and while playing not very loud the mixer went off and never worked again,also cut out the stereo amps I was using to power big speakers,been using it for about 5 hours one a week for last few months with no probs,Q:is there a fuse inside that may have blown? There was a 3amp in the normal plug which stated 5amp but worked fine for ages,I replaced it with another 3amp seeing I didn't have a 5 amp but no power,have you any ideas what to do because I need this working quick and can't afford another one,it's a behringer xenyx 1222fx mixer. Any help would be amazing Thanks Mike
Mar 09, 2012 | Behringer XENYX 1222FX MIX BOARD
I am new . I don't no where to conect mix to
For the whole mix, there are two XLR (mic cable) sockets on the back panel labeled 'Main Output' Left and Right, if your amp has XLR inputs you should use these. Otherwise there are two jack sockets labeled 'Main Out'.
This is a complex desk with a lot of useful options, you're going to have to spend some time reading the manual. Have fun.
Jun 12, 2011 | Behringer XENYX 2442FX Mixer
Worked perfectly for years. Now loaves collapse. Tried different yeast brands, varying amounts of yeast, varying amounts of water -- all changes carefully controlled. Is there anything in the operation...
Recommend you buy one of the commercial automatic bread machine mixes at the grocery store. They run about 3 or 4 dollars...If the bread doesn't turn out well then you DO have problem with your machine. If the store bought mix DOES turn out well then you have a problem with your recipe or the wrong kind of ingredients etc.....
Dec 02, 2010 | Sunbeam 5833 ExpressBake Bread Maker
I have a hq-31 mono 31 band eq with feedback
first connect your sound source(dvd player-vcr-...)to eq-input-------eq output--------line in in mixing desk.
Oct 13, 2009 | Audio Players & Recorders
How would you connect a Roland Space Echo direct into a Behringer 2642a mixing desk? Have tryed all inputs/outputs with nothing. Could this be because the mixing desk has ballanced ins/outs and the Roland...
In order for this to work, you need what is called an "insert" cable. This will have a balanced 1/4" connector on one end and 2 1/4" mono-connectors on the other. The balanced connector is also known as a TRS connector (Tip,Ring,Sleeve). You should have "insert" jacks on the mixer. Place the balanced connector into whatever insert you wish to use (usually this is inserted into the main insert). One of the 1/4 plugs is for input, one for output. I don't know which is which for your specific unit, you will have to experiment. Keep us posted. Dan
Jun 12, 2009 | Behringer Audio Players & Recorders
303 people viewed this question
