Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint wd640 replacement motor brushes
Hi,i have a hotpoint wd640 washer dryer which is 2 years old and has not had any problems yet,but i have been told the brushes in the motor should be replaced by now.have tried to get brushes but nobody seems to stock them is this because this machine does not have brushes. your advice would be greatly appreciated.
thank you
    President:
  • 1,462 Answers
Machine has brushes but they usually last longer than 2 years (mine are still ok after 5 years.
if you get no drum rotation, then suspect the brushes and replace them if necessary
Posted on Jul 17, 2008
Where are the brushes on a WD640 as I cant see them. I've taken the back off but they were not where I was expecting. The machine has stopped spinning.
Brushes are mounted on the motor at the opposite to the belt pulley. A bit fiddly to get at but can be removed without removing the motor itself. Brushes are not the only reason for no spin of course. An easy way to check brushes is to use a simple multimeter and check continuity between the brush connector and the commutatir
Feb 18, 2015 | Hotpoint Aquarius WD640 Front Load...
How do you remove the brushes from the motor?
You need to remove the lower rear cover of washer.
Remove the drive belt.
Unplug motor lead, and pull off earth wire.
Undo 2 bolts securing the motor to the tub.
Lever back the motor, and keeping a grip on the motor lift out of washer.
The brushes are located at the oppisite end to the pulley, they will probably be enclosed in black plastic holders, but you cannot mistake them, as they each have a wire going to them.
Hope this helps.
Dec 14, 2009 | Hotpoint Aquarius WD640 Front Load...
Have a fault code show on washing machine f-01 hotpoint wd640 Thanks Paul
F01 - motor triac on main pcb. check motor connections/brushes etc if not will need new pcb.
Oct 21, 2009 | Hotpoint Aquarius WD640 Front Load...
Error code f-01
This motor does not have brushes fitted, the error code F01 indicates that the motor triac has shorted, this is part of the electronics that control the motor, it could possibly require a new main pcb, and/or new motor. If it is under 5 years old, then you are better off contacting Hotpoint, and getting it done under the 5 year part guarantee.
Plz rate my solution.
Thanks.
Jan 05, 2009 | Hotpoint Aquarius WD640 Front Load...
E30 flashing when I try to start wash program on Hotpoint Aquariu
E30 indicates a motor problem, you will need to call an engineer.
Possible worn brushes which you can do if you know what you are doing.
Nov 24, 2008 | Hotpoint Aquarius WD640 Front Load...
Fault f13
Hi. F13 indicates dryer fan motor or thermistor problem
If you can't hear the fan motor running on the dry cycle then it is probably faulty.
Hope this helps.
Please feedback.
Thanks
Nov 13, 2008 | Hotpoint Aquarius WD640 Front Load...
Fitting "Bushes
you will have to remove the back then the motor then the motor brushes
Aug 12, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WD440
Check the coalbrushes in the motor. This is a common problem on most frontloaders.
Jan 24, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machine not spinning
Bring your sample to appliances store let them chech if their available.
Check the heat sensor detach one line test the continuity both terminal if open replace it.
Jan 05, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
161 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
