Question about Philips 27PT6441 27" TV
My phillips tv audio doesn't work well
If switch off the tv and then switch on the tv, there is no audio for about 5 minutes..after which audio returns but the volume is so low that you can hardly hear anything even at the maximum. I did notice that there is sharp sound as soon as you switch on the tv..as if the fuse broke or something.
  • 30 Answers
This problem might be related to a bad control board that controls the Audio and Video and other functions. It costs $180.00 to replace. Not worth fixing
Posted on Jul 25, 2008
Phillips tv wont change channel
tried with pressing the channel button at the panel tv or using with the remote controller doesn't work?.
Oct 26, 2012 | Philips Phillips 2422-549-01929 Tv Remote
I don't have the user instructions for my Philips remote. Need to set up my TV - purchased the remote in 2010, it doesn't show a model/name on it anywhere. How do I find the instructions or apply...
If the TV is a Panasonic, I'm sure the Phillips remote wont work unless it is a "universal" remote. You will need to code it in to work on your TV if its a universal one. See if it has an auto scan button on the remote.
Dec 27, 2017 | Philips SRU3004 Remote Control
Samsungh LA40B530 No picture but sound
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync, but if otherwise then
The ysus board is the most common reason.
you can try websites on ebay.com to buy parts for replacement...
Aug 03, 2010 | Samsung LA40B530 40 in. HD-Ready TV
The volume does not work on my phillips hdtv- solve
Try accessing the audio menu and be sure the TV speakers are turned ON. Good luck !
Dec 05, 2009 | Cars & Trucks
Pioneer SD-P6091 Projection TV - TV turns off by itself
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jan 20, 2009 | Pioneer SD-P6091K TV
Phillips 60 in. rear projection approx. 10 years old
This is a common problem with the older models. The opt chip fails. You can get a repair kit at www.magnavoxhelp.com. After a few months of getting smaller and smaller the audio and video will go out but the power light will remain lit.
Aug 18, 2008 | Philips 60P8341 60" Rear Projection...
Phillips tv
Are you connected using R,G,B (component) cables? Check them to make sure they are in firmly - if so, then try a new set - that may very well fix the rolling issue. (Unless the rolling is caused by poor antenna reception).
Press "Sleep" on the original remote control for this TV if you still have it until the TV says "Sleep OFF".
If no strong TV signal is detected, this unit goes into sleep mode, which may explain Tuner B shutting off after 5 minutes.
Feb 23, 2008 | Philips TV Tuner Video Capture PCI Card -...
Phillips 36" shuts off
It looks like that your TV is overheating. Most of the TV's have a fail safe so if any case they are over heating it will shut off so it doesn't damage the TV. i would advise that you seek help of a professional in your area.
Jun 17, 2007 | Philips 36RF82S 36" TV
Philips 27PT6441 27" TV Logo
61 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
