Briggs & Sratton - Pressure Washers --> replacement Spray Gun Model PW0811508.07 - Serial HH1620471 - Clean machine 1500 PSI --> Coleman Powermate 1500 PSI XO 140*F 48373
2 Suggested Answers
SOURCE: need instruction book for coleman powermate clean 1500
The hose connection I believe is for hooking a hose up and running it into a bottle of cleaner. The cleaner is mixed with the water when it is sprayed, The knob on the bottom adjusts the strenght of the solution. Most washers have the same setup.
Posted on May 26, 2009
Coleman Powermate pressure washer. Model PW0751310 A lot of water leaks out in the handle where you squeeze for the unit to work, thus the power spray is weak at best. Took handle/arm apart and didn't...
There may be orings in gun but usually not available as a repair kit. Replace the gun with a 5000 to 6000 psi. You will get a much longer life by over sizing gun. If you like to tinker, you can by orings at Lowes in the plumbing department. Lube the orings with silicone paste (also sold at lowes). Good luck
Mar 17, 2011 | Caterpillar Cat Pump Pressure Washer Pump...
I have a durabuilt model 1404 and i need a new gun and the adjustable nozzle
We have this gun / wand / nozzle available. Please call 800.257.8103 or visit our website at www.landanw.com for more information.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
Mar 10, 2011 | Coleman Powermate DuraBuilt 1400 PSI...
The gun part of the wond has a hold. will I need to replace the hold gun section? If so is their a replacement?
Hi, if the gun section is just leaking, then you can replace the washers inside; otherwise, its a replacement, which is not cheap unfortunately; but most guns should fit your machine.
Oct 13, 2010 | Coleman Powermate DuraBuilt 1400 PSI...
When the spry trigger is pressed the engine boggs down and stops. Is there a relief valve stuck maybe.
This issue is caused by defective unloader or debris trapped in spray nozzle or faulty gun. Easy to check. Check system with-out spray nozzle. The engine should not labor at all when you depress trigger without nozzle. If it labors/ dies faulty gun, if no labor, install new or clean nozzle (check for correct gpm for machine) and retest. If ok, you are done, if engine labors or dies, reduce pressure by turning pressure knob as required. If reducing pressure has no effect, most likely faulty unloader. Good luck
Oct 06, 2010 | Coleman Pressure Washer PW0881800
Hi! Our gun trigger is not working right on Model
Lowes and home depot sell replacement guns for most smaller pressure washers.
Jul 29, 2010 | Coleman Powermate DuraBuilt 1400 PSI...
Our neighbor just made the mistake of running hot water through our Model PW0501400 AND now the water is leaking from the spray gun. Has very little pressure. Is this a gasket problem?
The seals in the pump may have failed from the hot water; they shouldn't but stuff coming from China is often not as it should be. Your unit may have been assembled elsewhere but I would bet the innards are of Chinese origins.
Aug 23, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Durabuilt pressure washer 1600psi. Water leaking
Sounds like a faulty seal around the gun. Repair might be few bucks if you take it in. But the price of the part is probably under a buck. Depends if you want to rip apart it yourself.
Aug 12, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Need new gun and connection to gun
The DuraBuilt and Coleman pressure washers have a gun that tends to leak through the plastic clyinder wall that holds the plunger that moves with the trigger. You won't see the holes, but if you remove the upper half of the housing, hold the plastic tubes in place with one hand and turn on the water, not the motor, you will see water shooting through the wall.
Amazon sells an exact replacement gun and hose. FAIP PowerWasher Replacement Gun and Hose #80012. Mine does not leak at all and was $29 shipped.
Dec 14, 2008 | Coleman Powermate DuraBuilt 1400 PSI...
Washing Machines Logo
135 people viewed this question
Top Washing Machines Experts
