Question about Watches
How to remove the movement ,the stem to release the movement
  • benton-r Jun 22, 2008
    no hole, this is a elgin 616 17j 5 adjustment thanks
  • 2,071 Answers
When your watch is open already ,near the stem inside the watch there is small hole,use a needle to push this hole while pushing you pull also the stem,that it then take out the machine ,when going back the stem just put back where you taken,and it automatically lack,you cannot take out unless you push the hole,...that all benton..if my suggestion help you to understand your problem rate me as fixya..
Posted on Jun 21, 2008
Braun bn0095 watch battery replace
"For servicing and repairs, the removal of the access screw on the back of the watch gives access to the stem release catch; after removal of the crown and stem, pressurised air is inserted to blow-out the crystal. Thereafter, the entire movement, together with the dial and hands are easily removed from the top. Experienced watchmakers with the necessary equipment should only perform this operation and the removal of the access-screw by any other persons without the required expertise is highly discouraged."
Mar 26, 2013 | Braun Watches
I want to remove the stem from a Miyota 2015 Movement and insert a shotened version.
Hello Malcolm,
You can view the details with diagrams on how to remove the stem from this link:
Stem Removal (screw type)
Stem Removal (Push Button Type)
For the complete guide, you can refer to this link:
Changing Watch Movement / Stem
Oct 21, 2011 | Watches
I have a diesel watch model dz-2136 I need to know how to remove stem
Thank you for contacting FixYa.
I dont know why you want to remove the stem but here you go.
To remove the stem you must first loosen the set lever screw, then you can pull the stem out.
You only need to turn the set lever screw a couple turns to release the stem. Some movements use a button instead and in that case you would simply push the button down lightly with a pointed tool and while holding the button down pull the stem out.
For watches with one-piece cases where the movement comes out the dial side and the case has no removable back, you will not be able to get at the set lever screw. For this type of watch you must grasp the crown firmly and pull it out, or use plastic or soft brass tweezers to get behind the crown and pop it off. These watches have two-piece stems that have male and female ends that snap together. Then remove the bezel and let the movement come out into your hands. Then remove the hands and the dial and put the movement face down into a movement holder. Now you can remove the stem as described above
Aug 26, 2010 | Diesel Audio Diesel Watch
How do I remove the crown/stem to take the watch movement out of the case? thanks Marc
Apr 04, 2010 | Watches
How to remove crown? [IMG]http://i120.photobucket.com/albums/o189/rocejo/IMG_0115.jpg[/IMG]
I've looked at the image you posted, and I think it's a Ronda 515 movement or something very close.
If that's the case, do the following.
Push the crown fully back to it's normal running position. If it's a screw-down crown then ensure it's unscrewed. Using the tip of a fine pair of tweezers (or similar - perhaps a needle) press lightly on the small depression that you can see in your photo (on the main metal plate of the movement, to the right, just below where the stem enters the mechanism). While pressing on that, gently pull on the crown. If it doesn't release, press a little harder on the depression but please be moderate with the force you use - if you press too hard you may damage the mechanism.
If you take enough care, you should be able to remove the crown and stem.
To replace it, make sure the movement is correctly aligned in the case and gently press in the stem. If you feel any resistance, then rotate the crown slightly and try again. Again, if you try and force it, you may damage the movement.
It is usually not necessary to place any pressure on the depression to reinsert the stem, but if all else fails it won't do any harm.
Please let me know how you get on.
Oct 21, 2017 | Luminox Navy Seal Dive 3001 Wrist Watch
Find watch numbers, seamaster automatic
I hope you have Omega Dynamic?!
If yes, then the crown can be removed by appling slight pressure against the watch. The stem inside the watch is made of 2 pieces and the crown can be pulled out. But be careful, there are chances that the stem may break :-)
Sep 07, 2009 | Omega Constallation 1272.70 Wrist Watch
Removing the crown/stem of CASIO EF-321
Other case for a simple Casio quartz watch :
Jan 15, 2009 | Casio Edifice EF106D2AV Wrist Watch
Removing the watch stem
Hi, it depends on the watch . Look carefully ,if there is a release button , somethin you can press on or lift up. Sometimes a needle is enough to do the job. On some quartz movements (the cheap ones) you just can't remove the stem ...
hope this will be helpfull!
K.
Apr 09, 2008 | Watches
Rmoving the corwn from a new sekonda watch
all Calibers are different. If you look on the plate where the stem protrudes from the movement you should see a small button that has a dimple in it to prevent your tweezers from slipping when you push it down to release the stem.
Donald McPherson C.W.
www.finewatchmaking.com
Dec 05, 2007 | Watches
How do i remove crown?
Hi, on the back of the movement there should either be a screw or a dimple in line or next to the line of the stem. If a dimple, press in with a pin or similar sturdy tool and gently withdraw the stem. If a screw, only one turn should be enough to release the stem
Nov 13, 2007 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Watches Logo
644 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
