Question about Dell Inspiron 6400 Notebook
DELL INSPIRON 6400 BATTERY CHARGE PROBLEM
MY LAPTOP RUNS OK OFF THE MAINS SO AM ASSUMING MY CHARGER INTO THE MACHINE IS GOOD BUT WONT CHARGE THE BATTERY BOUGHT ANOTHER NEW BATTERY STILL THE SAME CAN ANYONE HELP
CHEERS
  • 8 more comments
  • misszip2000 Aug 27, 2008
    I have the exact same problem. Literally over night, after having great battery strength, the battery suddenly died. I purchased a new battery, which arrived today. It will not charge either. It arrived partially charged, so I know it works and it is not the battery. The computer works fine when plugged in and is working with the new battery, although I have no way of charging the battery at this point.
  • calmstorm Nov 28, 2008
    More than that - before having this problem when I was removing the battery , the system would turn off, even the charger was plugged in. Now when I unplug the charger my laptop runs normally. I assume that there is some chip damaged on motherboard instead of dead battery or bad charger, I think this is the real problem.
  • Anonymous Dec 09, 2008
    Me too exactly the same as the last poster
  • jbshooter Jan 04, 2009
    I have a Dell Inspiron 6400 that I have recently reinstalled Windows XP on, but now the battery won't charge.  When I boot the system or remove the power cord and plug it back in the battery light will come on for about 30 seconds but then it goes off.  When I look at the battery settings in Windows it says that it is charging, but the percent of charge never changes.  Any ideas?
  • waddleitbe Feb 23, 2009
    On Dell 6400. I have more than one battery and now none will charge but PC works well on just straight power. I can see the 'plug' icon at bottom right corner showing it is running on AC but the 'lighting bolt' icon usually above the plug is absent. Also, it does not recognize the original Dell AC 19.5 volt 65 Watt adapter. Is this possibly the BIOS? or adapter is no longer at full 65watt strength. Volt meter registers 20 volts.
  • bsolomon Mar 04, 2009
    I have a relatively new ispiron 6400.The problem I have is that the battery does not charge. thoght it is a problem with the charger,so tried the charger on another similar laptop.it was fine. changed a new battery but it is not any better. seems the laptop does not reognize the charger nd therefore does not charge.
    I hope i can save the laptopaftr spending so much for it and now it is practically useless if it cannot charge.
    i dont remember having dropped it o subjected it to a great  shock.
  • jonathannc Mar 12, 2009
    battery does not charge, no light on battery test what so ever as its not been charged for about 6 months if not longer.. its a real pain .yet the 6400 works fine off the power supply. tried to open up the battery pack but its breaking up. what can i do. new charger yet it shows good output, new battery yet why should the old battery suddenly stop working, not as if it was used much.. any help would be great, no problems until the warranty expired.
  • selva_sahay Mar 16, 2009
    I have the same problem also..I remember dropping the laptop once...but still was working fine untill i used my Sister-in-law's charger(Dell also but diff model)...Ever since my battery has this problem..Some suggested to Install the BIOS ..tried but wont work...Looking for a solution for a long time.. Need help.. TQ
  • john498madma May 08, 2009
    My problem is the same, i bought the laptop 3 years ago, after 1 year and a month the battery didn't charge anymore. On advise of Dell i bought a 9 cells battery, now after 2 years this battery also didn't charge anymore
  • pagirat May 11, 2010
    Solution link . . . www.Laptop-Problem-Sollution.com
    Scholar:
  • 55 Answers
The battery has 5 small dots in it. Those are there for no reason. Those are actually LED lights. There's a button you can press. If we number the lights 1-2-3-4-5 with 1 being closest to the button, check the lights when you press the button. If 1-3-5 are lit, that means that you have a dead battery and needs to be replaced. Other than that, you're battery might still be working but nearing the end of its life. Goto support.dell.com -> drivers and downloads -> enter your service tag or system type -> download Dell Quickset. Once Quickset is installed, it will diagnose your battery automatically and let you know if your battery already needs a replacement. It is just sad that batteries are covered with a separate 1-year warranty only. You can also go to www.dellbatteryprogram.com and check if your battery was part of the Dell Battery Recall Program.
Posted on Nov 25, 2008
I reported this problem on 23 Feb and have solved this problem for my 6400 by purchasing a new AC adapter. I went to e-bay and searched for my model number listed on the charger and found several. I purchased about the cheapest one for $17.00 as i was not sure it would fix the problem. Plugged it in and presto, my battery charged. Now I wished I had bought a little heaver duty one with a longer connection cords.
Posted on Mar 19, 2009
  • beccamn Nov 10, 2010
    Hopefull it can help to solve problem by changing battery .it seems now the battery problem is really a headache,pls kindly visit our websitehttp://dell-laptop-batteries.net/inspiro... for more new model at most preferable price.
  • 85 Answers
Has the laptop ever been dropped. The only thing I can think of is damage to the charging circuit on the motherboard. You would need a visual inspection to be 100% sure.
Posted on Jun 21, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 19 Answers
We are an expert in providing laptop batteries, laptop adapters and other consumer electronics batteries. During the past years, this company has established very good relationship with almost all the primary manufacturers around the world. The products provided by batteriesaussie.com are of the top quality, 100% compatible with the original system and meet with all the Australian safety standards, and. CE certified.
Posted on Dec 03, 2012
    Problem Solver:
  • 8 Answers
I think the first you'd better confirm that if you battery power you laptop ok or not, and get some battery management software as a monitor to understand the state of the battery, may be it wille give you some information what the problem is. And you said "the second  battery"? Is it a replace one? the replacement dell inspiron 6400 battery is not the same with the original one though the are compatibility, so you can't use it to diagnose the fault.
  • Johnpush Nov 05, 2012
    That's very kind of you to share this for us.Thank you!
    Problem Solver:
  • 10 Answers
Problem with Dell Laptops?
For solutions for your problem you need to visit a site by just Click Here .
For any hardware problem with Dell Laptop you can Click Here
Posted on Jul 23, 2010
Laptop battery have problem really cause pain to end-user,you can find more new items from http://www.dell-laptop-batteries.net/inspiron-6400.htm, it will help you to select,much better in price and quality
Posted on Nov 11, 2010
  • 4 Answers
The flashing batt if left forever, eventually puts excessive strain on the chargers sensing circuit causing it to fail. (mine took a few months) A new battery was eventually bought, alas too late. A new ac adapter had to be bought as well. The old one continued to provide power, but would not charge the new battery since the sensing circuit was now shot.
Posted on May 15, 2010
I know this was a problem with the 6000 model and related to the charger.  A new charger would have to be bought from third party.  I had  the link for that somewhere, but found it just by searching for inspiron 6000 battery problem.
Posted on Sep 09, 2008
All our laptop battery are manufactured by state-of-the-art manufacturing plants. Our laptop batteries are guaranteed to meet or exceed the original equipment's specifications on all counts of durability, structure and fit. To add to it, our laptop batteries are backed by a 30-Day Money Back Guarantee and a full 1-year free replacement warranty for any form of manufacturing defects. At itsbattery.com, we value our customer relationships tremendously which shows in the unmatched quality of our customer service. We have a dedicated team of customer service executives who are always eager to help you find the laptop battery you need by supporting you with their extended product knowledge and expertise on laptop batteries.
Posted on May 18, 2010
Here is a very interesting thing that happen.
I had a trip on my holiday to a village, i plugged my laptop and the battery started to charge as before.
We measured the outlet tension and it indicated 250 V :)) Also during the trip to the laptop was placed in a bag that was kept for about 8 hours in a car trunk where the temperature was below 0 C :)))))
From now on my laptop battery is working / charging perfectly.
Posted on Jan 12, 2009
I bought a new battery for laptop and it still wont charge
Dell uses proprietary equipment. IF the laptop wont work when plugged in and it is the original Dell charger, you need to check the charger, if the charger wont work then the battery wont charge. Note that it might be the connection on the board inside the laptop especially if the cord got pulled on while plugged into the laptop.
Oct 05, 2015 | Dell Computers & Internet
Charging led blinking
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it
with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
Dec 02, 2012 | HP Pavilion dv9000z Notebook
My advent battery would not charge so i bought a new one and it still wont charge having to run my laptop from the mains
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Mar 12, 2011 | Advent Netbook
My laptop acer 5101awlmi wont charge my battery i have bought a new battery and charger the new battery worked fine until the power ran out. i can only use it now when it is pluged into the mains charger...
take it to be fixed my laptop did the same thing but i had vista at time
it is something internaly so you will need to take it in to a repair shop
Feb 07, 2011 | Computers & Internet
I brought anew battery and new charger for my
We offer all kinds of laptop batteries. such as apple battery ,Asus battery
and so on.
May 14, 2010 | Acer Aspire 3680 Laptop
My lab top wont charge the battery its new
Your laptop does not charge the battery, the charger plug charges the battery. Could be a bad charger or battery, just because its new does not mean it works.
Feb 05, 2010 | HP Pavilion dv1000 Notebook
My T42 suddenly wont recharge the battery or wrk off mainsadapter
If the Laptop wont work off the power adepter, it also will not charge. The adepter could be bad (even if showing a power light) or the connector on the laptop could be broken. The best test is to take the battery out, attach the power adepter and try to start the computer if it starts, your battery is at fault. If nothing, suspect eh charger first. Be sure the pin on the Laptop power connector isn't bent or broken.
Jan 04, 2009 | IBM ThinkPad T42 Notebook
Dell d610 latitude wont charge new battery
Hey,
First off, do you have a way to check the output of the ac adapter to ensure it's putting out the correct current?
If you've done that and have a multimeter handy, you can remove the battery, system off, and check the charge pins for current/voltage. I believe one of the end pins is neg (ground) and at least one of the other pins should show 2.6-3.6V, as well as other various voltages. If you fail to get any response at the charger pins, we'll need to look at the board circuitry, assuming again that the ac adapter is operating properly.
Good luck
Nov 26, 2008 | Dell Computers & Internet
Battery wont charge
most modern chargers have "smart chips" to control the charging process and prevent overcharging. if the voltage falls below a pre-set minimum the charger will refuse to charge the cell(s). assuming the cells are all good (which you should never do!) i'd give them a boost with a "dumb" charger like the ones you get at the dollar store that go in your cars cigarette lighter and is designed for a cell phone. do this at your own risk and be sure you don't reverse polarity! i give you this tip assuming you're cautious and knowledgable - don't blame me for any accidents. this *IS* a risky solution.
Jul 26, 2008 | HP Pavilion zt1135 Notebook
Dell Inspiron 6400 Notebook Logo
14,862 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
