I accidentally plug my wii to a 220 volts and then i suddenly heard something that pop out inside the adapter ..i immediately unplugged it..could it be possible that the entire wii unit was damaged or just the adapter?
you could try replacing the power supply. if it still does not work, you probably fried the processor or motherboard. (or both). just make sure the replacement power supply has the same type of connectors on the power leads to the motherboard, hard drive, etc.
<p>
<p>The battery of an iPod Touch prepared for use in the United
States is designed to be reloaded from the current supplied by a 110-volt
electrical system. Power is transmitted to the battery charger with an iPod
battery, which are connected via a USB cable and then connected to a 110 volt
outlet. To use the power of a 220 volt outlet with an iPod Touch, set the
current 220 volts to 110 volts. A conversion adapter voltage, also known as
"Step Down Transformer," it is necessary and can be obtained from an
electronics store, a hardware store and even some drug stores. <br />
<p><br />
<p>1. Place the 220-110 voltage converter card (aka, "Step
Down Transformer") next to a 220 volt outlet. Plug the adapter into the
outlet. <br />
<p><br />
<p>2. Connect the end of a USB cable to the USB connector USB
iPod charger iPod. Connect the other end of USB cable into your iPod's own
socket on the bottom of the iPod Touch. <br />
<p><br />
<p>3. Plug the iPod into the 110 volt outlet in the battery
adapter for the iPod Touch. <br />
<p><br />
<p>4. Unplug the charger from the iPod adapter and the adapter
from the outlet when the battery is charged. Unplug the USB cable from the iPod
charger and iPod Touch. <br />
Best case scenario, you fried your power adapter and just need a new one. Mild case scenario, you killed the power input fuse on the Wii's mainboard and the fuse will need to be replaced by a technician. Worst case scenario, the fuse didn't blow fast enough and your Wii's mainboard is now fried, requiring complete replacement.
You're going to have to take it to a technician for an analysis before anything else though, so you might as well start there.
Might try a different a/c adapter from gamestop or someplace else.....If that doesnt work, it may have internal fuses that popped.....If it doesnt the its toast.
It is possible that your power supply fried but everything else is still ok. Something like this could happen during a lightning storm. If you know someone with a wii, try to use their ac adapter (with a 120V adapter). If this works, then you just need a new power supply which is much cheaper.
wow that sucks, try going to gamestop in the morning and getting either a new or refurb/used one for about $20. hopefully you just blew the ac adapter and not the wii. also check to make sure you didnt trip the breaker the wii is on (check the breaker box/s around the house).
I'm going to go ahead and say it probably fried the Wii. I would maybe try getting a new adapter either way if it's at reasonable cost and see if it works again though.
if your Wii was from japan or another country which uses only a 110v AC power supply then you could have either blown some fuses inside the wii or at worse you could have fried some of the internals.
First of all find out which adapter you where supplied with, check the voltage rating on the adaptor. if it is a 110v adaptor then you may need to have your Wii replaced.
Wii consoles are region-specific and different regions also use different television standards.
You have potentially three problems:
Wii consoles are region-specific. Games for US/Canada won't work in a European Wii
European Wii consoles output PAL video signals. US/Canada/Japan TVs except NTSC video signals.
European Wii consoles likely require 220-volt power. US/Canada/Japan is 100-120-volt power.
So now your solutions for each:
You need to get games from France (or at least Europe) You can also look into a device called the Freeloader, but I'm not sure if it works with Wii games yet (the original allowed Gamecube consoles to play games from different regions)
You'll need a multi-standard TV, or a television standards converter. Tourist-y camera shops often sell converter boxes. You need to convert from a PAL video signal to an NTSC video signal in order to connect it to your TV.
Check the power adapter of the Wii. If it lists "110-240 volts" or "100-240 volts" (at least a voltage number in the 100-something range) on it, then the power supply will work and you just need an international plug adapter. You can get these from most travel stores and electronics stores. If the power adapter does not list a voltage in the 100-something range on it, then you will need a step-up transformer - that will convert power from 120-volt to 220-volt or 240-volt. The transformer may or may not have the right type of power receptacle, so you may also need a plug adapter. Check your local electronics store for this. Tell them you have a device from Europe and want to run it on your local electrical power. They should know what you need. If you have a choice, get one that is designed for computer or laptop use, as the cheaper ones provide "dirty" power which is fine for hair dryers and such, but bad for electronics.
