Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Wiring diagram for garage door opener
The sensor for the garage door opener was accidently knocked off. How do I fix it - there are 3 wires and only 2 places to wire it too.
Thanks for your assistance
  • 3 more comments
  • ajtoews Jun 30, 2008
    The problem became more complicated as we made the mistake of removing the 2nd sensor (and forgot how it was wired)! Yes, only 2 wires were used of the 3, however, all 3 had the ends stripped and so can't determine which 2 are the correct ones.
  • beenthereb4u Oct 02, 2008
    WE JUST OVED INTO OUR HOME AND THE GARAGE DOOR SENSORS SEEM TO NOT BE WORKING. ONE SENSOR HAS A GREEN LIGHT THE OTHER HAS A VERY DIM LIGHT AND SOMETIMES NO LIGHT EVEN THOUGH THE SENSORS ARE IN LINE NO MATTER WHAT I DO THE DOOR WON'T CLOSE. WHEN THE DOOR IS CLOSED IT WILL OPEN BUT WILL NOT CLOSE. HELP
  • Morgan Rosas
    Morgan Rosas Apr 22, 2014
    Sounds like your lights are misaligned. Try aligning your light and sensor until they both shine brightly.
  • Michael Calloway
    Michael Calloway Aug 18, 2016
    No higher than 6" above ground level, also make sure that there is not sunlight shining into the sensor eye...
  • Michael Calloway
    Also the stripped set of wires should go to the third (last one on the right) terminal and the solid colored wire go to the center terminal. I am dealing with the same issue, however, mine is a 1998 and those set up's were with a three screw terminal board the newer models have a four wire plug in style..Not totally sure 'bout that monster. G'luck. Mike Calloway
    New Friend:
Can you hook up sensors to an older craftsman garage door that never had them?
Posted on Sep 02, 2010
    Scholar:
  • 91 Answers
Normally when a new house is built the electricians will use whatever wire they have to pre wire the garage door sensors so you don't see wires hanging allover your garage. The sensors only need a 2 conductor wire. When you goto fix the sensor you can check the other sensor and see what wire colors were used and use the same colors. Example: sensors have a white and white/black wire (normally). the house may have red, white and green let's say. Just make sure the white goes to the white and the white/black goes to the red. So if you look at all the connections the white is on the same color everywhere (in back of the opener and sensors) and the white/black is on a different (and common color). The installer may have chosen to use green but normally thats not the case.
Posted on Jun 27, 2008
  • Jim  K
    Jim K Jun 30, 2008
    If you haven't removed the wires from the opener then you should get an idea of what colors that were used there should be the same colors at the sensors. The sensors are wired in parallel.
    Also, please verify the brand of opener you have.
  • tommedwin Apr 02, 2011
    I'm really frustrated with my Chamberlain installation. It says to connect the white wire to white and the white/red wire to red. The pre-installed wire in the garage has a blue wire with a white wire with small blue lined wire wrapped together, an orange and white with orange lined wire together, red wire and white with red lined wire, and green wire with white and greened lined wire together. I've tried several combinations and can't get it to work. Any ideas? Thanks!
  • 1,443 Answers
Hello, You need the operator/maint. manual to correctly wire this up.
Posted on Sep 28, 2015
SOURCE:
Ythe door goes up fine but u have to hold the button for it to go down
Normally this means that either your transmitter needs to be reprogrammed or you may have loose wiring. OR the alternative is that one of your sensors could be dirty or misalligned and you might not know it. Check the users manual and your door buttons to see if any wiring is faulty or loose. Most of the time it has to do with sensors. Holding button down is a manual bypass to force the door to go down. Something is telling it to stay up. Check your sensors. They can be easily moved, jarred, or knocked loose by accident.
Mar 09, 2011 | Chamberlain 3/4-HP Power Drive Chain Drive...
I need a wiring diagram to hook up the wires on my garaged door opener
From the wall control there are 2 wires. One with a red stripe goes to terminal #1. One solid white goes to terminal #2. From the door sensors the solid white wires go to terminal #2 and the 2 wires with black stripes go to terminal #3.
Sep 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
No wiring diagram for the sensors
The solid white wires from the sensor go to terminal #2 and the wires with the black stripe go to terminal #3.
Jul 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sensor and control wiring to unit what is the wiring diagram for sensors and opener to unit
1. RED - Red trace wire from wall control.
2. WHITE - Wires without trace from wal control and eyes.
3. GRAY - Wires with black trace from eyes.
Hope this helps
Jun 24, 2010 | liftmaster Chamberlain Garage Door Opener...
Need wiring diagram for eyes that control safty device door willnot close by one button push , have to hold button to close , light on opperator has one flash
Safety reversing sensors wire open (broken or disconnected).
Each sensor has a solid white wire and a white wire with black tracer.
The solid white wires go to terminal 2 and the wires with the black tracer go to terminal 3.
Jan 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
My wiring for my garage door opener is messed up at the sensors. i am looking for a diagram to show proper wire connections.
If you look at the wires from the sensors you will find one wire from each sensor is solid white and the other is white with a black tracer. The white wire from each sensor goes to terminal 2 on the back of the motor unit and the white wires with the black tracer goes to terminal 3.
Oct 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wiring diagram for garage door sensers Garage Master 1/2 hp part # 41A4252-7G
Each sensor has 2 wires. One solid white and one white with a black tracer. The solid wire from each sensor goes to terminal 2 and the white wire with the black tracer goes to terminal 3.
Oct 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
2000 sears craftsman garage door opener
#1 wire with red trace –
#2 all white wires with no trace
#3 wires with black trace
Mar 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Basic wiring for craftman garage door opener
from left to right..
1. red. to wall button
2. white . common to wall button and white wires of sensor.
3. black. white with black strip of sensors
Jul 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
23,936 people viewed this question
Top Sears Building Materials Experts
Mike
Steve Allison
Steve Allison
Are you a Sears Building Material Expert? Answer questions, earn points and help others
