Question about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
Network adaptor hi my sons b'day to day and we are desp trying to set up xbox live. it is asking for an ip address. can you help please?
  • Simon Vann
    Simon Vann May 11, 2010
    Yes I can but I will need more info.
    I need to know what wireless router you are using and if anyother machines are connected to this either wirelessly or cables.
    Problem Solver:
  • 9 Answers
Go to http://whatismyip.com/, the number on the screen is your IP adress. Enter that in the manual and your XBox should be connected.
Posted on Jul 09, 2008
Try doing automatic ip instead of a static ip
Posted on Jul 03, 2008
How do i connect to live?
1. Make sure first no other devices connected to the modem at the same time as some modems has an Ethernet port along with a USB port so, you might think you can use both at the same time & connect the PC through USB with the console through Ethernet & that's incorrect so, we need to disconnect the PC first.
2. Turn the modem off then turn it back on after couple of seconds (by turning the modem off I mean to unplug it from the wall outlet even if you have a power button for it), then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore to Factory Defaults" and when it ask you to Apply Settings select "Test Xbox Live".
applysettings.jpg3. If it's still not working we need to get the Physical Address of your PC to put it on the dashboard of your Xbox 360 console as some cable companies are preventing any unknown MAC Addresses from connecting, to get the Physical Address of you PC connect the PC only to the modem then follow these steps here, the physical address will look like this 00-E0-98-C1-88-C2.
4. Go on the dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Edit Settings" then "Additional Settings" tab then select "Advanced settings" & put the Physical Address of your PC without the dashes on the "Alternate MAC Address" part and select "Done", when it asks you to Apply Settings choose "Test Xbox Live".
b. Wired connection to router:
1. Go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore To Factory Defaults", when it ask you to apply settings select "Test Xbox Live".
2. Turn the router off then turn it back on after couple of seconds, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
c. Wireless connection to router:
2. Go on the Dashboard of your Xbox 360 console to the "system" area then "Network Settings" then "Edit Settings" then select your wireless settings part down there "Wireless Mode, Network Name,..." the console will automatically then search for your wireless network and when it find it and you select it, it will ask you to enter your wireless key which is called WEP or WPA key - you can find it written on your wireless router or then you need to contact your ISP (Internet Service Provider) to get it from them - when it ask you to apply settings select "Test Xbox Live". editbasic.jpg3. Just a kind of higher security that some router may use than the WEP & WPA key, you have also to accept the Xbox 360 connection to your wireless network on the router settings, you have to access to your router settings as mentioned before to check on the wireless security part whether your router apply a MAC filtering option, which is an option that blocks any unknown MAC address (the ID of any device) from accessing to your wireless network, and if it applies that kind of security you'll find your Xbox 360 MAC address on the list there so, allow the Xbox 360 to get connected to the network, or even you can just turn off the MAC access control option instead of that, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
4. If it's still not working, you can put the Xbox 360 console - as a trial - in a closer position to the router to see wither it's going to pick up an IP address or not.
5. If even after you turn off the MAC filtering option on your router settings your Xbox 360 can't still get connected to Xbox Live you need then to update your router firmware (The router software) and if you don't know how to do so then call your ISP (Internet Service Provider) to assist you with that, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
d. ICS (Internet Connection Sharing):
1. Go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore to Factory Default" when it asks you to Apply Settings choose "Test Xbox Live".
2. Allow the ICS option on the PC as mentioned before, then test Xbox Live.
3. If it's still not working, set the IP Settings manually to be:
IP Address: 192.168.0.2
Subnet Mask: 255.255.255.0
Gateway: 192.168.0.1
Then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
4. If it's still not working, you can get the IP address of your connection from the PC as mentioned before then set your IP manually on the Dashboard of your Xbox 360 console using this IP address, when it asks you to Apply Settings choose "Test Xbox Live".
If you faced any other kind of troubles with this part failing even after you tried these steps please don't hesitate to leave a comment.
Read more: http://xbox360help.blogspot.com/2007/04/ip-failed-xbox-360-live-test.html#ixzz14pRocyB3
Nov 09, 2010 | Microsoft Premium System for Xbox 360
Running two xbox live 360
Hello there.
A router shares your internet connection with local computers and devices on your local area network. Microsoft's xbox live requires a connection to your IP address on a certain port. This will be a problem when using 2 xboxes so what you would need to do is contact your Internet Service Provider, explain that you are using a router and require an additional Static IP Address.
Once they provide you the details for this, you can manually set up one of the xboxes with the static details your isp has given you.
This should stop the 2 xbox conflicting over connecting to the internet, as they will be running on seperate ip addresses.
Hope this helps.
May 19, 2008 | Microsoft Xbox 360 Console
My Zonet ZSR4134WE Wireless-N router doesn't connect to live. I've checked the MTU setting and everything. It works perfectly, until it gets to the "Xbox Live" part of the test, then it fails. Please help.
you need to open the ports on your router for xbox ports are TCP 88 UDP 88 UDP 3074 TCP 3074 UDP 53 TCP 53
first connect the xbox to the network and get the ip address (like 192.168.x.x) and then use the computer and login to router setup page and under firewall open these ports for the ip address of xbox . If you find a DMZ there , then enable it for XBOX ip address and reboot the router. ** imp: try to make a static ip address on xbox so when you restart the xbox teh ip address should not change -
to check what is the ip address provided from you router :- go command prompt (start ->run- > type cmd and hit enter) a black screen(command) type ipconfig you will find ip address of computer , so you can set the ip address of xbox like that -but just make the last number different (like ip address on computer 192.168.2.5 then make ip address of xbox to 192.168.2.6) perform this will help .. its all about the ports but be sure with ip address
Oct 01, 2010 | Zonet ZSR4134WE Wireless Router
Xbox live ip address test fails
If you are using Windows XP or below, press START, click RUN and type "cmd". If you are using Windows Vista, press START, click the search bar and type "cmd". The command prompt should appear.
Type: ipconfig /all
Search the list for your network adaptor and make a note of the MAC address.
Turn on your Xbox 360 and go to network settings. Select manual settings and enter the MAC address under the Alternative MAC address option. Retest the connection. If your computer is connected to the internet, your Xbox 360 will be too,
Jan 24, 2009 | Microsoft Xbox 360 Console
Xbox live dont work please help
the reason for this part to fail differs along with the difference of the type of connection you are using to connect your Xbox 360 console as follows:
a. Direct connection to modem:
2. Turn the modem off then turn it back on after couple of seconds (by turning the modem off I mean to unplug it from the wall outlet even if you have a power button for it), then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Restore to Factory Defaults" and when it ask you to Apply Settings select "Test Xbox Live". 3. If it's still not working we need to get the Physical Address of your PC to put it on the dashboard of your Xbox 360 console as some cable companies are preventing any unknown MAC Addresses from connecting, to get the Physical Address of you PC connect the PC only to the modem then follow these steps here, the physical address will look like this 00-E0-98-C1-88-C2.
4. Go on the dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Edit Settings” then “Additional Settings” tab then select “Advanced settings” & put the Physical Address of your PC without the dashes on the “Alternate MAC Address” part and select "Done", when it asks you to Apply Settings choose “Test Xbox Live”.
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore To Factory Defaults", when it ask you to apply settings select "Test Xbox Live".
2. Turn the router off then turn it back on after couple of seconds, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
3. Just a kind of higher security that some router may use than the WEP & WPA key, you have also to accept the Xbox 360 connection to your wireless network on the router settings, you have to access to your router settings as mentioned before to check on the wireless security part whether your router apply a MAC filtering option, which is an option that blocks any unknown MAC address (the ID of any device) from accessing to your wireless network, and if it applies that kind of security you’ll find your Xbox 360 MAC address on the list there so, allow the Xbox 360 to get connected to the network, or even you can just turn off the MAC access control option instead of that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
5. If even after you turn off the MAC filtering option on your router settings your Xbox 360 can't still get connected to Xbox Live you need then to update your router firmware (The router software) and if you don't know how to do so then call your ISP (Internet Service Provider) to assist you with that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore to Factory Default" when it asks you to Apply Settings choose “Test Xbox Live”.
Then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
4. If it's still not working, you can get the IP address of your connection from the PC as mentioned before then set your IP manually on the Dashboard of your Xbox 360 console using this IP address, when it asks you to Apply Settings choose “Test Xbox Live”.
If you faced any other kind of troubles with this part failing even after you tried these steps please check me
Jan 03, 2009 | Microsoft LIVE ONECARE 2.0 XP/Vista for PC
My xbox live doesnt work
If you faced any other kind of troubles with this part failing even after you tried these steps please check me man
Xbox no ip address
If you go to account settings, network settings, you can check that the IP is set to manual or static. I'd set it to static and put in your own, then forward the xbox live ports on your router. If you need detailed instructions on how to do that, I'll find you the page on xbox.com.
Jan 02, 2009 | Microsoft Xbox 360 Console
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Feb 22, 2008 | Microsoft Xbox 360 Console
Joining XBox Live
Make an account offline that should work.
Feb 06, 2008 | Microsoft Xbox 360 Console
Open Questions:
See all Microsoft Wireless Network Adapter Xbox 360 Questions
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
