Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubushi WS 65511
Hi again I am the guy form Scottsdale. I have been out of town for a month or so and won't be back to continue the repair of the tv. Thanks for your help and hope to get it up and running again. Replace the 7 caps and checked all fuses. Still comes on and goes off in 30 sec. If someone out there figures out my simptions let me know.
  • 927 Answers
Good Day, TSIRS; Try all of these: This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 1. Check for 12 volts DC (AC-off detect) at pin 3 of PC9A21, if missing replace PC9A21 part # 268P058020 on the Power PCB. 2. LED does not blink at plug in. Check for 5-volts DC at connector RF pin 3 (system reset) if low or missing suspect the reset switch S7L20 part # 432P089010 on the Control PCB. 3.LED does not stop blinking after plug in. Check for 12 volts at connect or PF pin 10 and 28 volts at connector PF pin 11, if the supplies are correct suspect a problem in the DM Assembly (part # 955C230002) 4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B03, C9B13, C9B14, C9B17 and C9B18 (1000 UFD, 16V, 105C) on the DM Power PCB located within the DM Assembly. If they are bad, replace them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-76 5. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 6. LED stops blinking after 70 seconds of plug in but will not power on. Check for 4.7 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D587002 7. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 935C978002. Good Luck, big IRISH.
Posted on Aug 07, 2008
Convergence bad on Mitsubishi WS-65511
if you are not handy with soldering you might damage tv more if you tray to do it yourself,but you guys can send your board for repair to us for professional convergence repair with new Parts,3 month warranty.
just go to ebay site and look for TEXAS TV PARTS,or texasgreatdeals4you,then when inside store just type convergence board repair service,if you don't see repair service for your tv just ask via ebays mail,Thanks,
Jan 10, 2014 | Televison & Video
I have a Mitsubushi Model WS-65511 Projection TV . Green light is flashing on the front, screen won't come on. tried resting , no change. What could be the problem?
ONLY 1 of 2 things can cause this problem----
First thing to do is remove front speaker grill--it should pull out and issecured with plastic pegs--behind it you will find an inspection plate---
Notice the one or two pairs of wires coming from the front keyboard of theset---remove the inspection plate and follow the wires to the right--you canunplug both plugs(most have two and they are marked with letters and differents so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc fromthe circuit---You will still be able to try to turn the set on with theremote---
These sets have a Receiver that is called a DM board--(large metal box to theleft as you look from the back) and if the power goes out the green light willblink for about 70 seconds and then go out---it is the Receiver booting up. Itis called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad resetswitch and two choices---either operate the set only with the remote or toremove the front screen and get at the reset switch (it is tiny) and removeand/or replace it.
If disconnecting the keyboard does not restore the set to operation---thereceiver is bad---there are 4 or more caps and some pico fuses that can fail inthat unit---Mitsubishi no longer sells or repairs these--if it is bad and notthe caps there is a company you can send the unit to and have it repaired--ifyou need to know their name let me know---
You can call them and get a quote for repairing the receiver.
Let me know what more information you need--I am here to help.
Apr 15, 2012 | Mitsubishi WD-62525 62" Rear Projection...
WS-65511 won't turn on
The power supply section to your set has the fault. If you come over me by Fixya paid service purchase, I'll assist you to repair your tV by yourself at home. OK.
Dec 07, 2011 | Mitsubishi WS-65511 65" Rear Projection...
I have a mitsubishi ms-65511 and we had a poweroutage for several hours today and now the tv won't turn on and I am getting a continuous green light of death ... HELP
Thats caused by weak capacitors on the DM board which cannot recharge after the power has been restored. Very inexpensive repair . The WS48511 - WS55511 DM repair kit from has the capacitors and the CD with repair instructions which should solve the issue of the steady blinking green light.
Oct 11, 2011 | Mitsubishi WS-65511 65" Rear Projection...
Power comes on and the back off.... Code is two flashes then paus then two flashes.... Where do I check to find fuses to the convergence?
This is a short protect error code. The affected parts is not only the pico fuses but also the convergence IC(STK393-110) that is mounted on the large aluminum heat sink. I have a link where you can buy the repair kit that includes steps-by-steps instructions that will guide you in the whole process of repair. Click the link below.
Mitsubishi V21 chassis(WS-65511) convergence repair kit ($42).
Scroll down to V21 chassis convergence repair kit.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Sep 13, 2011 | Mitsubishi WS-65511 65" Rear Projection...
No Picture after Wii Play: 65'' Mitsubishi HDTV 1080 (WS-65511)
mmm try this.... do u guys have the yellow white red cables hooked up to the front of the tv from the wii console? try loosening them up. worked for me. let's see how long it lasts .... !!!!
Dec 27, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
441 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
