Question about Kenmore Oasis HE 27082 Top Load Washer
Lid Display lit when starting wash cycle
Cant run wash cycle the when I press start the LID code appears on the screen and the machine wont run.
  • RJKVJK Aug 14, 2008
    When i try to run my washer, i get the code "lid" I have tried to press it closed but it will not run, where is the button to show that the lid is closed. Is it a sensor, or a button? I just did two loads of laundry and when I tried to start it again, that is when it said the lid is not closed.
    Where is the sensor that tells my washer that the lid is not closed? I am getting the code "lid" which means the lid is open, but it is not open, it is closed but it is not registering that it is closed. Can you please tell me where to find the sensor and what kind of sensor it is.
  • 958 Answers
LID code could mean that the door lid switch is not pressed. try to shut the door completely or the lid switch could have been broken. or the plastic that should press the lid switch could have been broken also. it is attached to the door i hope i was able to help.
Posted on Jun 21, 2008
What is hd code????
Hi Peter, If I understand your question correctly, you are asking what the code "HD" means for your machine. I am unable to find the code "HD", however, here is a list of the codes for these Maytag models, perhaps one looks similar to "HD". Hopefully this answers your question!
Washer displaying code messages
- "LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press PAUSE/CANCEL to clear display.
- "Ld" (Washer is taking too long to drain water from the wash tub)
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See "Connect the Drain Hose." Press PAUSE/CANCEL
to clear display.
- "uL" (Unbalanced Load)
If the load is unbalanced, the washer will display this code while running an imbalanced
load correction routine at the end of the wash cycle and before the final spin. If the code
remains and the wash cycle dial is flashing after the recovery routine has stopped, open
lid and redistribute the load. Close lid and press START.
- "oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill and begin the wash cycle. If
the washer is overloaded, it will drain any water and detergent that was added during the
fill. To correct the overload, remove several items and add detergent. Close lid and press
START.
- "Sd" (Suds Detected)
Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High
Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions.
If excessive suds are detected, the washer will display this code while running a suds
reduction correction routine at the end of the wash cycle. The suds reduction routine
removes extra suds and assures proper rinsing of your garments. If the code remains and
the wash cycle dial is flashing after the recovery routine has stopped, re-select your
desired cycle using cold water. Press START. Do not add detergent.
- "lid" (Lid Opened)
Is the lid open? Close the lid to clear the display. If the lid remains open for more than 10
minutes, water in the wash tub will drain.
- "HC" (Cold and Hot hoses switched)
This code will appear at the end of the wash cycle to indicate that the cold and hot water
inlet hoses are switched. See "Connect the Inlet Hoses."
- "dL" (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid keeping it from closing. Press
PAUSE/CANCEL once to clear the code.
- "dU" (Door/Lid cannot unlock)
Is there excessive weight on the lid, such as a basket of laundry? Excessive weight will
keep the lid from unlocking. Press PAUSE/CANCEL once to clear the code.
- "F##" code
Press PAUSE/CANCEL once to clear code. Press START. If code appears again, call for
service.
May 01, 2014 | Maytag Bravos MTW6600T Top Load Washer
What does LS on the display and dont end the cycle?
The control should flash this error code if it cannot detect the lid switch opening and closing properly.
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch.
The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 09, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
After starting the washer I get a L5 flashing display and my washer powers off. What can I do?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
May 03, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My washer wont do anything and keeps flashing L5
The control should flash this error code if the following conditions occur: ? The control cannot detect the lid switch opening and closing properly. ? There is a disagreement between the motor and machine controllers on the state of the lid switch (the control should not allow the unit to run in this condition). ? The user presses the START key while the lid is open. ? The user presses the START key without opening thelid between cycles.  Open the lid or press STOP/CANCEL to clear the display.
Apr 28, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
FL code on a Calypso Whirlpool washer
FL= Flood Condition
FL flashes if any overfill condition
occurs. This condition occurs when
excessive water in the tub causes the
overfill switch to trip. The control must
realize that the trio was due to an
overfill condition instead of a suds lock
condition in order for FL to be displayed.
With an overfill condition, the beeper
repeats a warning every 10 seconds with no
time out. The pump is cycled in drain mode
for 30 secondson 30 seconds off untill the
overfill switch resets or power is
discontinued to the unit.
Note: Press STOP/CANCEL to clear display on all error codes
Causes of flood condition. Inlet valves
stuck on, Sediment in water level pressure
tube.
Other codes:
PF power failure
Er control lost settings during PF
LF Long fill Clogged inlet screens
CE Com error between motor and control
Ld Long drain Clogged/slow drain/pump
CA/CI Motor amping up
ob off balance load
Sr relay failure no control to motor
LS Lid switch no signal from lid switch, error occurs if the motor and control disagree as to the position of the lid switch. Usually means corosion is buit up in the switch and the motor knows the lid is shut but the control does not. Cose appears when start button is pressed.
open lid= flashing display time If the lid is opened time remaining flashes in display. Close lid and press start to continue.
SL Suds Lock Current draw on motor is sensed by motor control and a suds lock is declared The control trys 3 times to fix this by doing a mini cycle, SL is displayed if the unit was unable to correct the problem. This problem is caused by:
Bad pump
Extra heavy load
Excessive detergent
or Excessive suds/wrong stuff
Feb 04, 2010 | Washing Machines
Washer will not fill with water after it locks
Hi brittruiz07, I’m an owner like you and will try to help.
Is your machine type a FAV6800AW or FAV9800AW? I need to know the model number this is important.
With this condition I assume both lid locks retract allowing you to open the lid and no water flows into the wash tub and you take no error codes to the display is this correct?
The Lid is Locked LED lit and if the water valves are not not signaled on at the start of the wash cycle this issue could be related could be related to a Control Board issue. I don't want to say failure just yet. Let's see if the Control Board will let you get into Service Mode. With no error codes to start the troubleshooting process with we need to enter Service Mode and vview machine Error Code History.
To enter Service Mode press and hold simultaneously the Enviro Plus and Spin Only keys for three seconds or until the control beeps and the display reads “00”.
This is from the Service Manual; this process starts on page 17 in the Service Manual.
In Service Mode press the Wrinkle Control key.
The display will show a “d”.
The diagnostic codes can be viewed by using the Set Delay Time arrow keys. Pressing the Set Delay Time down arrow key will cycle down the list one code at a time each time it is pushed. Please right down each code such 4, 18, 22 etc.
If there are no error codes in the Control Board memory the display will read “- -“ that’s two dashes in the display. I feel you will have many Error Codes from previous wash cycles. I just want to get a feel for the Error Code history.
Next I want you to hard reset the Control Board by pulling the disconnecting the washer power cord for ten seconds then reconnect washer power. Go back into Service Mode and make sure all Error Codes have cleared you should only see “- -“. Press the off button to back out of Service Mode.
Start a Quick Wash cycle with minimal machine settings and no clothes in the basket.
If the washer fails to start the Quick Wash cycle as you described in your initial post how long did it take for the machine to unlock the lid? Did any water flow into the tub and were there any Error Codes sent to the display? Please go back and read the error code list and let me know what error codes you see from this Quick Wash cycle attempt. I know this is painful but we need to start somewhere.
You can pump out excess water when you fail with dc/UC unbalance errors with this process from the Service Manual.
Close the lid and enter the Service Mode by pressing and holding simultaneously the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Press the Delicates key this will lock the lid.
Now press the Presoak key the drain pump will turn on.
Turn off the drain pump by hitting the off button or hit the Presoak key.
Rich
Aug 12, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Will not start up and show code 0d
Hello kc59mail ,
For the FAV6800A the od alarm means the Control Board has not seen a lid open condition for three complete wash cycles. I suspect the left lid lock.
I think you have a problem with the magnetic reed relay in the left lid lock. If you could try this? I want to make sure you signal an “OP” alarm to the display. Can you select Spin Only cycle with the lid open press start. Do you signal the “OP” alarm lid open to the display? If it does close the lid and the “OP” alarm should clear does it? I’m checking that the lid magnet is in place and the signaling connections are working thru the left lid lock back to the control board.
Let us know what you fin and we will go from there. You could try powering down the machine by removing the 120VAC power cord from you wall receptacle. That may give you three more wash cycles before the od alarm is triggered again.
Mar 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
KENMORE CALYPSO WASHING MACHINE
Jan 26, 2009 | Washing Machines
What is the L5 red light that appears when I press start for wash
Dec 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
140 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
