Pull the emegency brake pedal back with your hand manually while holding the release handle and light should go off. the spring return on your emergency brake pedal may just need adjustment. try this 1st before you do anything else please, it may be a simple thing. hope this helps and thank you for choosing fixya.com
It worked! Thank you!!!
SOURCE: emergency brake light on 92 chevy blazer
There is a pressure switch, that gets depressed or released due to pedal position. When you engage the PB the arm is depressed...releasing the pin-like pressure switch.
Examine the pedal itself...looking where it 'touches' the car.
Depress the pedal....while watching this place. Look for a 'pin-like' switch that is allowed to extend when the parking brake is engaged, and that would be depressed in when the arm is released/disengaged.
Once you have found this, it is likely that either the:
If you need other help on this, just ask...ask there are a few other solutions..but this is most likely the cause, and is a reasonably easy fix
SOURCE: On my 2003 Chevy Suburban, the emergency brake won't release.
there is a cable running from handle to brake assembly it is probably broke there is a release lever under there on brake about a one inch lever hold down on brake and move this and let up on pedal.
SOURCE: 1991 honda civic brake light stays on need to push brake pedal to
Sounds like you might have a caliper that is stuck and is not fully disengaging. If it is in the rear then you may have a bad rear caliper. Twoo things you can try. One is to crawl under the ca and adjust the tension two nuts on the emergency brake line. If that does not resolve the problem then remove the back tire and try to spin the drum or rotor whichever you may have. If it does not spin then try adjusting the e brake cable more if it still does not respond then you need to do a brake rebuild. Also does it pull while it is dragging? If it is then you will need to rebuild the brakes no matter what.
SOURCE: Brake lights stick while driving but turn off when pressing brake
CHECK YOUR BRAKE LIGHT SWITCH THAT IS ON YOUR BRAKE PEDAL UNDER THE DASH
SOURCE: emergency break cable broke on 2004 silverado
I had the same problem on my 2003. Open the driver door all the way. Get on your knees just outside the door. Follow the plastic tub that holds the parking brake release cable inside the truck. Start from the release lever and follow to the end of the tube. There will be a metal lever that the cable was attached to before it broke. You have to pull that lever with your hand to release the parking brake. Very Important!!!...Hold the parking brake activation pedal with your other hand when you release the brake. Let the pedal out slowly when you pull the metal release lever. The pedal will come back very fast and you could injure yourself if you are not careful. Good luck!
