Question about Panasonic CT-32SL14 32" TV
No RF Signal after main fuse replacement
Hi guys/gals. I had to repalce main power fuse, but on initial power up, my menus come up, but TV is not getting any signal from cable TV. Any clues?
    Genius:
  • 2,035 Answers
The power could have damaged the rf filter in the TV as please unplug it for 30 min then plug it and check , if get it service as the rf circuit may be defective...............................
Posted on Jun 21, 2008
    Genius:
  • 1,847 Answers
Chk the cable for siginal
  • Legin Varghese
    Legin Varghese Jun 21, 2008
    if you can connect the tv to a dvd or vhs player and and try playing something. that will give a clear picture of the issue
Hello I have been given 2nd hand a Dynex LCD TV DX 40l130A11 TV from my cusin and pluggin it in is fine and attaching it to cable was okay but it comes up saying no signal. how can I just view the TV?
Hi Rory,
I hope you have chosen the correct input source ie. RF, AV1, AV2, PC or HDMI to which you have connected the cable. Despite choosing the correct input source if the TV says no signal means it is not reading the signal. In that case the main board is defective. A good technician who knows component level repairing can repair the main board. Otherwise you will have to replace it.
Apr 12, 2015 | Dynex Televison & Video
Panasonic TH-42PX60B
have you already service the main unit, or you an initial check on the parts of the TV..
kindly post back the TV model/maker..
Thank you
May 18, 2008 | Panasonic TH37PX60 37 in. Plasma...
No signal for HDMI or DVI
Hi, what device or devices have you tried to connect through those ports? Were they working prior to this problem?
Mar 19, 2014 | Initial HDTV-320 32 in. LCD TV
Orange light on vizio no bad caps
You may be buying a main board, only a few guys in the industry even bother servicing main boards. Outside of a bad cap, fuse, or regulator its time to replace the board. If you have standby power, and you're not getting the "PS ON" signal from the main board, your main board is bad!
Feb 08, 2013 | Vizio SV471XVT 47 in. LCD TV
Tv wont turn on
Issue with Main Power Board..Fail to innitiate to logic board Due to over heat ..Check Hi Voltage board for over heat regulator and Capacitor as to be check for fail signal... May afect IF Board and RF Board for over power Due to Over Heat component ...Refer to Professtional TV Repair ..
Sep 30, 2010 | RCA L42WD22 42 in. LCD Television
I have a dmr ez28 which is connected to an antenna which is connected to the tv. The tv is getting the antenna signal, but the dvr won't record because it is not getting the signal. When turned to the...
No, you are not obligated to pay for services not rendered or in this case no longer needed.
You will need to contact FixYa administration for the details about canceling the charges. They can be reached at:
premium.support@fixya.com
There may be continued responses to your posted problem until Monday morning when the offices are once again populated. Bear with them, the experts answering do not initially see what has transpired previous to their posts. When they do see, it's only the comments made by you that are visible.
Normally the responses stop when you accept an answer. In this case, that may complicate things. So, be patient and send them a message explaining the situation.
There will be no problem,
Best regards,
Mike
Dec 25, 2009 | Televison & Video
Model 542-B11 External signal won't display (settings menus work)
Well first of all yo can try to reset your TV, just turn it off for more the 24 hours and then turn it on again, it helps you to reset your TV. (turn off your TV from main housing not only from the TV power button).
Let us know if this helps....
Good Luck!!
Thanks
Dec 14, 2009 | Televison & Video
Model no 21NE60 BREAK DOWN BECAUSE OF LIGHTNING
Lightning is never good.
Could be as simple as a fuse repalcement may be as bad in just getting a new TV.
You may want to check with your home owners insurance policy also as they may cover the repair or help in the cost of a replacement unit/TV.
Blessings,
A/V Media Guy
Nov 20, 2009 | Audio Players & Recorders
Proscan PS50700
Appreciate the direct "Ask Me".
Technically, when a TV signal is said to be snowy, it indicates that the incoming RF signal is weak; on the other hand, when a TV signal has static, this refers to electrical noise that goes with the TV signal.
Having said that, then to your concern:
  • for snowy signal, it is the cable providers problem. They have to change where your incoming cable is tapped from, check/replace the feedin cable itself or worst case scenario, replace the line amp/distribution amplifier feeding your cable input;
  • for static noise, what is required is to check possible sources which could include (but not be limited to) electronic ballasts of florescent lamps, electric fans, hair dryers, shavers, wireless phones, computers and others.
Additionally, you may want to check if you have any RF producing devices attached to the TV such as VCRs, DVDs, game consoles. You can try unplugging them when not in use.
Worst case scenario is the tuner block of the TV is getting weak (unlikely but possibly). You can try rewiring the cable to feed first into a VCR, connect the VCR to any of the free Video IN, and select channels through the VCR. If significant improvement, then you have just confirmed an internal fault with the TV tuner, if problem persists, then the static/noise/low RF is caused by something else.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 31, 2008 | Samsung TXE2745 TV
Mute on- no button?
The unit will display "Mute" for a myriad of reasons, but the most common seem to be that it is not receiving an RF signal from the microphone. Be sure that the batteries in the mic function properly, and that the mic is close enough to the receiver to get an initial signal.
Otherwise, check the menus - it doesn't appear to have a "hard" mute switch, but one of the "Soft" menus may have that information.
Nov 29, 2007 | AKG (40008801) Professional Microphone
Panasonic CT-32SL14 32" TV Logo
41 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
