Question about Dirt Devil Vacuums
I bout this vacume in mid December 07 and about February-March it started not picking up the dust on the floor. So in early April I bout a new filter and it still wasn't picking up the way it had in the beginning. I've taken it a part several times and cleaned it out with it being plugged at the bottom hose with dust bunnies. Well I just took it back to Walmart where I purchased it and I failed to keep the reciet they could not do any thing about the sweeper. I went back to the sweepers and relized I had not put the sponge filter back in the right place so I did that and brought it home where it clogged again. Well now that I have cleaned it out again, it doesn't appear to have much suction. Any clues that I am missing?
    President:
  • 1,673 Answers
Pull the hose out of the holder, is there suction there. If not, then there is a clog in the hose. If there is suction, then check the dirt outlet by the brush roll. Also if the belt is slipping, it may appear to not have as much suction, belts will stretch after a short period, replace it. There should be a local shop near you that does warranty work for Dirt Devil, you have a years warranty on this, if you can't figure it out, I would take it in, they can tell by the serial number if it is in warranty.
Posted on Jun 21, 2008
Vacum has suction, but won't pull debris from the floor
The vacuum may not be set for use on carpet.
Jan 19, 2017 | Vacuums
The alarm on my machine keeps sounding; even though I have cleaned the filters, emptied the dust bucket, its driving me mad as I rely so much on this machine; with dogs, cats and children and a farm h
Please check the suction on your machine? Is it strong? It may be that you have a clog, particularly since you have dogs, cats and children!
It suction is fine, have you checked the rotating roller brush? If the point of pickup is poor on your floors, you may need to check your belt. You may have picked up a large object that has affected the tension in the belt. Visit here for your belt: http://www.crucialvacuum.com/LG-Kompressor-Vacuum-MAS61842501-Belt-p/lg_vacuum_belt_5eph271.htm
Oct 18, 2011 | LG Electronics Kompressor Pet Care Upright...
My Bissell bagless vacuum does not seem to work anymore. It will start to with a suction and then instead of picking up the dirt, it appears to blow the dirt out almost in a cloud of dust and debris from...
this is caused by a dirty air filter and/or a blocked vacume hose ( most of the time the blockage is at the bend where the hose enters the floor sweeper area ) ---
remove and tap out and brush the filter ( or use a air compressor to blow out filter ).
then with the vacume on its side - remove the bottom plate ( like you were going to change the belt ) and use a coat hanger and clean out the hose between the floor sweeper and where the suction hoes attaches. this will restore your vacume to full operation.
c...
Jan 23, 2011 | Bissell 6595 Lift Off Bagless Upright...
Eureka Maxima 12 amp vaccum cleaner is not picking what can be done to make it pick up?
remove and clean the filter ( tap and brush filter or use a air compressor to blow out filter ) --- also check the vacume hose near the floor attachment for any dirt and debris that may be clogging the line. this should bring your vacume to full operation.
c...
Jan 22, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
Can I use the Vacum cleaner for floors only without using the liquid. I do not want to wet the floors just sweep the dust away. I cannot find my manual.
first off your manual is right here....
http://www.hoover.com/pdfs/manuals/H3000.pdf
But more to answer your question, yes you can use it on the floor without the wet. You will want to turn your brush switch to the off position. Also, do not fill the water tank or press the spray lever for dry pick up only.
Hope this helps.
Nov 05, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
I have the bissell powertrak revolution. I have hardwood floors...even on the lowest setting it is throwing some dirt back at me instead of picking it up....
do not worry about this....it is a common issue with every brand of vacume this style....the poblem is not of power or quality..but rather one of friction or lack of resistance because of the smooth floor surface....carpet surfaces permit the brush part of the roller to FLICK the dirt back up high enough ( only millimeters) to be sucked by the continuous suction flow of the vacume...however smooth finished hardwood or tile floors allow for the heavier none dust particules on your floors to be swept accross the floor with speed...if there was a back drop on the back end of your vacume cleaner these particules would be stoped and sucked up....try taping a strip of brstle board paper with scotch tape to the back part of ur vame head and see if it makes a differnce. Put the paper at dragging floor level and tape it..then sprinkle some dried toast on the bare floor and try it....let me know if it works...
Feb 20, 2010 | Bissell 6591 Power Trak Revolution Bagless...
It is blowing dust out of the motor
If this is a bagless machine, then the problem is that the really fine dust that you are picking up from your floor is so small that it is going through the filter and dust cup and building up in your vacuum motor. When enough build up collects, then it starts to blow it out the exhaust. I would bet a paper bagged machine for the long run. They are cleaner,
Nov 28, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Is their maintenance I need to do on my H702 central Vacumn?
H702 appears to be a Honeywell heavier duty for mid to large floor areas.I have not seen them but internally most Central vacs are VERY similar.
Most central vacs have an exposed filter which should be inspected periodically for damage or cleaning and replacement. A hanging cloth filter is normally fine for 7- 10 years with periodic inspection by the homeowner. Look for tears, never pick up wet stuff. very simple. You can clean a cloth filter prior to inspecting with the round brush from another vac or a soft paint brush.
I found internet reference to an H702 bag but it may be an option for your vac.
Some cv's have an additional or optional paper bag for allergy sufferers or removable cartridge filter which would be visible when removing the dust pail. regardless, the filter protects the motor from damage, periodically inspect when emptying. If dust gets through a damged filter it can leak into and blow a motor. As an cv ages a small degree of fine dust gets in no matter the brand, but most are fine for 10-12 years with no service.
If you see dust in the air exhausting or puffing from the vac, have the unit checked as this indicates dust which has run completely through the motor. If you see a small amount of black dust exhausting along your wall, it is normal from internal brush wear. Turn the vac on and off and listen to the motor as it winds down. If it growls or sounds scratchy or is squealing, that is an indication it needs to be serviced. Clean and inspect you pwer head every 4-6 months and change a smooth drive belt twice a year, broken or not as it will be stretched.
o
If this helps please post a response
Sep 25, 2009 | Vacuums
The vaccum doesn't pick up dirt, it sprays out
There is probably a second or third filter (besides the canister) that needs to be cleaned.
I doubt that it's rotating the wrong direction.
Apr 25, 2009 | Dirt Devil M084600 Dynamite Bagless...
There are no known vacum bags for a model wd06350 vac
This type of vacuum does not use a bag. If you are worried about clogging the filter cartridge try using a paper filter for a shop-vac. They are relatively cheap and are available at most hardware and department stores. These are made to simply wrap around the big cartridge. A rubber band will hold it in place.
Feb 09, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Vacuums Logo
Top Dirt Devil Vacuums Experts
Roger Potts
Jim Parker
Jim Parker
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
