Question about Panasonic Panafax UF-595 Plain Paper Laser Fax
Error Prinr Comm Document message. Fax sounds like it is still trying to print but nothing is happening
    Genius:
  • 2,120 Answers
Function 7 set
monitor key slowly 4 times
6
scroll down to ALL JOB CLEAR
wait for reboot
Posted on Aug 30, 2008
Comm error message
PROBABLY BAD PHONE LINE, CAN TRY SOME OF THE FOLLOWING
SLOW DOWN THE RX TO 1700
TURN OFF ECM
INSTALL DSL FILTER EVEN IF ITS NOT A DSL LINE
MAKE SURE THE PHONE COPANY KNOWS ITS A FAX LINE
IF ITS VOIP IT MAY NEVER WORK WELL
RESEAT ALL CONNECTORS IN FAX 3900
TRY SETTING TO MMR
MAY ALSO BE PROBLEM WITH THE SENDING FAX MACHINEOR, THERE PHONE LINE
Jul 11, 2013 | Konica Minolta Minolta FAX3900 Digital...
I keep getting comm error 242 when people are faxing to me
The "sender's" fax machine is attempting to RECEIVE a fax. This happens because they don't have the document fully inserted into the scanner before dialing. (According to HP's error code listing for "comm error 242" - http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=buu02549) This is not a problem of a bad connection. Bad line condition codes are 223, 224 and most of the codes starting with 23.
Apr 28, 2010 | HP LaserJet 3050 Printer
Comm error 252
The comm error 252 occurs due to,
  • Telephone line conditions were too poor to receive a fax.
This error can be rectified by
  1. Reattempt the fax reception at a later time when line conditions may have improved.
  2. Configure the machine to start reception at a lower speed.
  3. If the local machine successfully received several pages of a larger document, ask the remote user to transmit the document in several smaller parts.
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Jul 15, 2009 | HP LaserJet 3050 All-In-One Printer
Brother FAX 8360P comm.error
It could be line noise on the phone.., which allows phones to work ok, but causes problems with faxes. See this document from the brother website concerning comm.error:
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000100/000067/faq000167_000.html?reg=us&c=ca&lang=en&prod=fax2800_us&Cat=11
Would recommend having the phone company run a line check to make sure the phone line is clean of interference !
Jan 21, 2009 | Brother FAX-8360P Plain Paper Laser
Panafax UF 885 resets itself when trying to print comm journal
sounds like your firmware might be shot and it needs to be reinstalled, if your in canada i can recomend a tech
Nov 03, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
ERROR MESSAGES
nthemba- all the error codes you see indicates phone line condition or error at reciving fax's end. For more details you can refer to
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&lc=en&dlc=en&cc=us&product=79477&rule=17804&lang=en
Sep 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Sending error
I try sending a fax then the paper goes through it makes a loud beep and the message says theres been an error try again this happens all the time no matter who I fax. then it prints out error confirmation stating Mode G3 send error
Jul 29, 2008 | HP 1040 Plain Paper Inkjet Fax
How to get fax reports
Your only option is to have it print out automatically after every 32 transactions, print out after every transaction, or print out only when there was an error with the transmission.
That parameter is Comm Journal and you can get to it by going to Function 7, option 4. That should give you a fax parameter table. You want options 12 and 13. Set 13 to "1" if you want it to print out every 32 transactions. Set that to "2" if you don't.
Set 12 to 1 for Comm Journals Off, 2 for Always, and 3 for Incomplete Only (errors).
Oct 02, 2007 | Panasonic Panafax UF-490 Plain Paper Laser...
Panasonic Panafax UF-595 Plain Paper Laser Fax Logo
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
