Question about Lexmark Z1420 InkJet Photo Printer
Mains lead z1420 In the box is the wrong mains lead. My lead has a 3 configure and the black box which goes into the unit has 2, Can you tell me where to get the right one?
  • kittenkat270 Jun 21, 2008
    already tried there. Theysupply everything but mains leads. Thanks anyway,,
  • 2,035 Answers
If this was in the box when buy you can contact Lexmark and get it replaced for free the main chord or if want you can buy the power chord online:
Use this link :
Posted on Jun 21, 2008
How to wire air compressor motor to 220v
Insulate brown means cap and tape.
240Volt should not have neutral wire
240Volt coming from breaker box will have 2 hot wires... and either hot wire is same no matter wire color
Oct 07, 2014 | Hardware & Accessories
What is the whirring diagram
Most fans have 3 wires usually a white, black, and a blue(or black with white stripe) the white wire is the neutral and goes to the white wire in the ceiling box, the black wire is the fan hot lead and goes to the black hot lead in box and the blue(or other blk/wht) is for the lights and would go to the switched lead in the ceiling box(sometimes another color but not white or green)..if you don't have a switched lead coming out of the ceiling box and just two wires then the white goes to the white in the ceiling and both black and blue go to the black wire in the ceiling box
Jan 22, 2011 | Hunter 21617 Palermo Ceiling Fan
My dryer came with a 3 prong plug but the house i just bought has 4 prong, my question is when putting the cord on the dryer is the green or black wire the ground wire?
GREEN is always ground if you are going by United States wire color code. BLACK is HOT and is carrying 120VAC on it. RED is the other HOT lead. If you are attempying to convert from a 3-prong cord to a 4-prong, the following link explains how:
The main difference betwen the two configurations is how the Neutral (WHITE) and the Ground (GREEN) wires are terminated at the terminal block. In a 3-wire configuration neutral and ground are terminated together via ground strap. In a 4-wire configuration, these two wires are independent of each other with no ground strap. Neutral is terminated with neutral and ground gets terminated to the equipment cabinet.
Read through the link provided and let me know if you have any questions. I hope this helps you.
Jan 03, 2010 | GE DBXR463EDWW Electric Dryer
Where is distributor located1995 960 6cyl
hi, if you follow the leads that come from the top of the spark plugs where all these leads plug into is the distributer their will be four leads running along the outside going to each spark plug then the lead that goes into the center of the distributer goes to the coil.
So if you follow the four ht leads from the spark plugs what these all plug into is the distributer, if you are removing the distributer then make sure you mark where each lead goes as you need to put them all back in the right place.
Its best if you mark say the first lead with a 1 and then write a one onto the distributer where that lead goes into use permanent marker pen to do this so it dont rub off. getting the leads the wrong way round will mean the car will either miss fire or not run at all so just keep it all marked up properly.
Let me know how you get on or if you need further assistance ok
Nov 06, 2009 | 1995 Volvo 960
Kenwood KDC-MP2032 radio wiring color
YELLOW goes to the battery lead
RED goes to the ignition on lead
BLACK goes to chassis ground
Apr 05, 2009 | Kenwood KDC-MP2032 CD Player
Need wiring diagram for a hotpoint df22 dishwasher on/off switch, the switch in it has been replaced with the wrong one so i have no reference to connect up the new one. thanks
You're in luck - I've just had one apart to repair the wiring loom.
The door switch is a simple two-pole latching switch with the wiring as follows.
This is the order of connections from the front.
1. Brown - Live (fed from mains)
2. Red - Load (goes to controller)
3. Black - Load Neutral (return from controller)
4. Blue - Neutral (goes back to mains)
By the way - the flat wiring loom gets fatigued at the bend at the bottom of the door and will eventually short out. Easy to fix with heatproof cable stripped out from an immersion lead.
Jul 05, 2008 | Dishwashers
Cannot install the CD-ROM on my main computer
are you installing on other than your C:/ drive. Also, is your vista machine a 32 bit or 64 bit machine? 64 bit machines have a second program file directory and my guess is the printer is looking in the wrong place for the installed drivers.
Apr 12, 2008 | Lexmark Z1420 InkJet Photo Printer
My 1420 doesnt connect to WiFi
same problem here. Revieced just today an replacemnt from Lexmark, but the same behaviour!!!! Hate this thing.. :-)
Mar 19, 2008 | Lexmark Z1420 Printer
Audio, but no video when dvd played
you must connect the handbrake lead to a negative supply, it's a safety feature to stop you watching it while the vehicle is moving
Nov 01, 2007 | Pioneer AVH-P5700DVD Car DVD Player
if it is in warranty i would suggest you to call the hp guys .... if out of waranty please post the exact error message
Sep 12, 2007 | HP Pavilion A520n (DW233A#ABA) PC Desktop
Lexmark Z1420 InkJet Photo Printer Logo
50 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
