Question about Sony KP-65WS510 65" Rear Projection HDTV-Ready Television
No Picture I have 7 different Video Conections. The sound works on each Video selection but I have no Picture. The Screen is black>
    Genius:
  • 1,847 Answers
Seem like one of the ic on motherboard is gone bad.
For free sony support go the link choose the produce and chat for free
http://esupport.sony.com/US/perl/support-contacts.pl
Thanks for using fixya. Hope this solution may have helped you.
Posted on Jun 21, 2008
My ematic genesis prime will not allow me to watch YouTube videos. I can go on the app but whenever select a video the sound comes on but the video itself is just a black screen. Any ideas?
Go into the app settings and uninstall any updates. I made the mistake of allowing Google Play to automatically update all my apps, and it updated the Youtube app in the process. The result was exactly as you describe: a black screen in place of the picture. Once the Youtube app was rolled back to the factory default version, it started working properly.
Aug 20, 2013 | Ematic EGS004 Genesis Prime 7" Touchscreen...
No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
signeal
Nov 22, 2007 | Toshiba 50HP66 50 in. Plasma Television
No picture
interesting.have you tried playing a dvd thru a connected dvd player thru the 457. I would be curious to know if a different video source causes the same black and white pattern. try that and let me know.
Sep 10, 2007 | Yamaha RX-V457 Receiver
Conecting Wii to a Phillips lcd tv. rwy cords. but the picture is in black & white ?? i have sound. tried different connections eg: red to green conections & the only one that works is still black...
it sounds like you may be trying to plug a standard composit video cable (yellow) into a component video input (red, green, and blue)
these are actually two different connections. Most LCD tv's will have both options (sometimes there in weird different spots on the tv tho) if you don't have a standard RGB (red, white, and yellow composite video input) then you may need to purchase a component cable either at a local store or you can get one for $5 on Ebay
hope it helps!
~good luck!
Mar 16, 2011 | Nintendo Wii Console
I have a fujitsu 42" pds4229e-b and trying to set my wii up on it but when useing the video component conections i can only get a black & white picture and no sound any ideas?? i don't have a remote at...
Have you got component cables specially for the wii? if so, then the screen should work fine.
As for audio. You'll need to use separate RCA's Red and white into the audio input if your using external speakers, if your using a surround sound amp then put them into the input there.
Apr 29, 2010 | Fujitsu Plasmavision 42" TV
Black screen
I hate to say that's a very open-ended question. If I were to solve it myself this is how i would check the TV.If it's giving you a black screen that probably means its not getting a video signal.
1. what source dosen't have picture?, try another source does it work
2. Try a different input on the TV
3. Try different cables to see if their bad
4. Try a different source
These steps should help you narrow down your problem.
If the problem continues then you might have a bad switch board. That is very unlikely however.
Aug 11, 2008 | Protron Televison & Video
'SHARP LC 26SH12U' & Philps DVP 5160
sounds like you are using standard audio/video cables (yellow, blk., wht) in the component conections on either the tv, vcr or dvd player. If you intend on using component connection you will need to use different cables.
May 04, 2008 | Televison & Video
No video, only sound from tv tuner.
You need to plug the male yellow wire into one of the female wires that says media control...... something along those lines..... youll figure it out
Oct 06, 2006 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Picture went black
The good thing is you see something in the screen,with age the set has developed loose conections in a few different places,my suggesion is to call professional for service now and the repair will not as expensive,if the picture quality is good is worth it.
Sep 22, 2006 | Sony KV-32V26 32" TV
My tv blinks from black screen to picture
You might have loose conections on the horizontal driver or output circuit,do not use it like that or it will go dead completely and is going to cost a lot more.If the set is older than 5 years it might have loose conections in the power supply too.Call someone qualified for an estimate.
Sep 13, 2006 | Sony KV-32S42 32" TV
Sony KP-65WS510 65" Rear Projection HDTV-Ready Television Logo
61 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
