That is quite normal. When the rince cycle is on, it sprays water into the tub while spinning. In that way, it removes small traces of residule soap still on the clothes.Of course it should stop once the spin cycle is finnished.
If you have correctly selected rince and it doesnt rince, that part of the program is corrupt. Strangely enough, in S.Africa 90% of the washers with rince problems are the lg. Seen quite a few top loaders with this problem as well. There is no reason at all that once rince is selected it shouldnt work, except if faulty.. Only solution is to replace board if rincing to you is essential.
Check your lid switch, some machines stay running when you add clothes when it agitates, but will shut off if you lift the lid in rinse and spin, lid switch may be broken.
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
