Question about Maytag 24 in. MDB4100 Built-in Dishwasher
Dishwasher Issues My dishwasher is not properly dispensing the dishwasher soap. The flap on the soap container seems to be opening, but the soap is always caked in there after the cycle is finished. I have tried leaving the soap flap open, but that just seems to deposit soap particles on the dishes in the front of the bottom rack. Also, there is often a greasy film left on many of my dishes. Is this a soap issue or a water issue? I am very frustrated! Can you help?
  • Anonymous Aug 02, 2008
    I have the same problem, plus my rinsing agent is not dispensing. It looks like other sites have suggested replacing this part. Has anyone had any luck doing this?
  • st83sm Mar 23, 2009
    Has anyone found a solution for this problem? I am having the same problem with my Maytag 9100. Soap is always left caked in the dispenser at the end of the cycle. I am also suspicious that the rinse aid is not dispensing. Thanks.
  • 30 Answers
I would try using a different soap or less of your current soap.
Posted on May 03, 2009
SOURCE:
Soap door opens during cycle, but soap does not dispense??
Hello Eric, thank you for your post!
I understand that the dispenser on your Frigidaire dishwasher opens but the soap is not dispensing into your dishwasher. How old is your dishwasher soap? If it is around a year old you may need to discard it and use a new soap. Also check to make sure when you stack dishes that they are not obstructing the arms from reaching the dispenser. Make sure your spray arms are clear of any debris that could block the distribution of water inside of your dishwasher. You may need to connect with a professional technician for proper repairs if these steps do not correct your issues. I hope this information is helpful to you. -Matt
Aug 02, 2015 | Frigidaire Dishwashers
Soap dispenser flap (door?) does not open during cycle
Be sure that the lower rack is installed correctly, If reversed, the rack will block the soap door shut. One side of the rack has opening for the door.
Sep 18, 2010 | Frigidaire Professional Series 24 in....
The soap dish opened, but the dishes were not cleaned. The soap remains on the door even after two or three wah cycles. Checked all of the buttons.
Since you mention that your dishwasher has a dispenser has a flap that opens but detergent does not come out, the problem could be the wash water is not getting to it.
Can you confirm if during wash cycle the water is circulating especially through the top wash arm.
Keep a small container on the top rack and see if there is water collected in it at the end of cycle. Alternatively run the dishwasher with door open (you will have to find a way to enable the door switch inside the latch).
Please post a comment to confirm what you observe.
Sep 07, 2010 | Maytag Dishwashers
Soap dispenser does not open during wash
Well you can please follow the below steps -
1. Remove any dishes in the dishwasher. Unhook the dishwasher's dish trays or racks from their tracks, and set aside. Empty the soap dispenser if it contains unused soap that failed to dispense. Use a wet rag to wipe down the interior of the dishwasher, as well as the inside of the dispenser.
2. Close the dispenser, and shut the dishwasher door. Turn the dishwasher on to a manual setting, then stop it and open the appliance. Check to see if the dispenser is open. If it is, continue to Step 2. If the dispenser is closed, skip to Step 4.
3. Switch dishwasher soap. Some dishwasher dispensers have difficulty with dry or liquid dishwashing soap, depending on the make and model of your dishwasher. Incompatibilities typically result in the dispenser sticking shut, which explains why the dispenser opens when empty. Switch to liquid soap if you are using dry powder soap, or vice versa.
4. Check the dishwasher soap dispenser's spring. The spring is located behind the dispenser top's hinge. Consult your dishwasher's original manufacturer's manual or user guide to find a replacement spring. Pop the old spring out with a screwdriver, and replace with a new spring. This should resolve any issues related to the dispenser failing to open.
Please post comments if you need more help or information..........
Good Luck!!
Thanks
Jan 08, 2010 | Kenmore Dishwashers
Asko 1876 dishwasher soap flap opens as soon as power on.
I don't know about the control panel - I am having trouble with mine too, but in regard to the soap dispenser -- don't use it anymore. Just buy those little tablets. That is what the secretary at the repair shop told me when I had a problem and that's been fine.
Sep 24, 2009 | Asko 24 in. D3250 Built-in Dishwasher
Dishwasher does not rinse clean
run the dishwasher empty: use 1/2 the amount of soap you usually use in the soap dispenser close it then put white vinegar in the open dispenser and, run the dishwasher
Apr 22, 2009 | Dishwashers
Soap dispenser flap not opening
Not a solution but exactly the same problem. I should have sent the machine back (I bought mine about 2008 too) but by now, 2010, the machine is a complete waste of time and money. The soap dispenser fails to open every time, wasting money, water and my patience because I then have to hand wash after all. will try the suggested oil trick, but it was obviously a bad design to start with.
Jul 20, 2008 | Bosch 22 in. SKT5102 Free-Standing...
Problems with my dishwasher
You need to replace the dispenser or possibly the wax motor on the dispenser. I would be more than happy to help you. But need to know the brand an model # so I can make sure that I give you the proper advise.
Dec 31, 2007 | Dishwashers
Maytag 24 in. MDB4100 Built-in Dishwasher Logo
817 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
