Question about Refrigerators
Defrost drain is the defrost drain inside the freezer or outside on the back?
  • 4,889 Answers
Its on the outside and on the back...
http://www.applianceaid.com/images/drainhose.JPG
Posted on Jun 22, 2008
Why is there a layer of ice under the freezer draw
Seems like the drain trough is blocked and overflowing. When the freezer defrosts, water is supposed to run into the trough and then outside to a evaporation tank or dish on the outside. Sometimes bits of food, especially peas and beans etc, fall out and then end up in the drain. You may have to remove the back panel from the inside of the freezer to get to it. The drain trough is across the bottom of the freezer at the back.
Apr 08, 2015 | Refrigerators
Water draining into freezer Maytag MFX2570AEM
Certainly should be, if it is a blocked drain tube and not a broken fan or defrost unit.
Assuming this appliance to be a frost free unit, generally (as I don't know this particular unit), there should be an outside access panel on lower rear of unit. Behind this, you should see the compressor (large round or square sealed container) and a drain tube leading to it or to a receptacle on it, which allows the defrost water to drain from the freezer compartment, and evaporate using the heat of the compressor. It will be this drain tube that may be block with food debris or even (as I found on mine) a plug of mould. My tube just pulled off and I was able to completely clean through with fresh water. Inside the freezer, there must be a drain channel leading to the drain tube outside. This may be visible or hidden behind panelling and, If the outside drain tube was blocked, will probably be full of iced up defrost water and will need to be cleared, either by leaving unit switched of or, by careful use of a hair dryer - GENTLY - so as not to warp the plastic insides. Once this is cleared, ice can then melt off the hidden freezer grills when on defrost cycle and escape correctly to the outside for evaporation.
Mar 30, 2014 | Maytag MFX2570AEM French Door Refrigerator...
Water leaking from inside the freezer
if the bottome of the freezer floor is frozen then the most common cause is that the defrost drain is cloged, the back wall will mostlikley need to be removed and defrosted, then i use hot water & a long zip tie to make sure the drain is clear, don't use anything too hard as to punch a hole in a drain hose.
May 24, 2010 | Samsung RS2630SH Side by Side Refrigerator
Water leaking on inside - top shelves
The drain for the freezer is clogged. Unplug the frige and let it defrost. Pull the cover from the bottom front and note the drain pan. water should start draining into pan as the freezer defrosts. If Not the drain may be blocked. To access the drain remove icemaker then rear panel of freezer carefully, unplugging fan and ground wire. Look for drain in the middle under the coils. Look on outside back for the drain hose, this will help you locate the drain. Clear the drain of ice using hot water. You will hear it drain down the drain hose to the pan below.
Mar 29, 2010 | Whirlpool Refrigerators
Frigidare Mod.FRS26H5AS Leaking water into bottom of freezer where it freezes then leaks out door
I had the same issue.. I checked this web site and found the solution (on another post).. It was the drain of the fridge being blocked.. I didn't know the existence of such drain.. it turned out that it got blocked with some dust, therefore with every defrost cycle, the water was not going down to the evaporator tray, then going inside the fridge (eventually freezing), then overflowing to the outside doors.. Check on youtube for videos on how to open the fridge and clean this drain.. Have fun..
Feb 21, 2010 | Frigidaire FRS26H5AS Side by Side...
Inside the refrigerator underneath the vegetable bins we are getting ice build up. We have defrosted twice but the build up reoccurrs. Where exactly is the drain opening? and How do I clean it? How do I...
The drain opening is inside the freezer compartment (in the rear) so you need toremove the back and maybe bottom panels (inside the freezer), or you mey be able to access this hole from the back of frig if the drain tube is located outside the unit (in the rear). The best way is with pressurized air ( not a coat hanger wire). The drain heater (if so equiped) can only be accessed from the freezer by removing the panel(S). Good luck, macgivor
Dec 27, 2009 | Sub-Zero Bottom Freezer Refrigerator
Hotpoint csx22d side by side has leak under freezer side @ door...coming from wiring harness that runs up into bottom of freezer maybe??????
This leak , is coming from the defrost drain , inside the freezer section , at the back . The defrost drain is clogged with ice . Remove the bottom freezer crisper , and use a hairdryer to defrost the ice . You will see a drain hole where the defrost water is supposed to drain thru . Hot water helps defrost this hole . Once defrosted , use a small hose inserted into the drain hole , to blow thru , to remove built up debris , inside the unseen drain line .
Sep 16, 2009 | Hotpoint HSS25GFP Side by Side...
Coils freezing over inside a side by side
Most times when coils freeze up it is due to the failure of the automatic defrost circuit, specifically either the defrost thermostat or the defrost timer. Occasionally it is the drain under the coils somehow gets clogged and the water from the defrost cycle doesn't drain. If you have water in the fridge side or water forming ice outside the back panel in the freezer the defrost is probly working and the drain is clogged. YOU MUST GET ALL THE ICE OUT OF THE DRAIN. Hair dryer, hot water, etc must be applied. Water MUST flow freely to the drain pan below.
Sep 14, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water on floor and ice on freezer bottom
The problem is that the drain hole inside the freezer in the lower back wall is clough and the water from defrost doesn't go through that drain to the evaporative pan in the back by the compresor ,you need to clear thatdrain first meltting the ice in that hole with hot water until it goes through then once in a while (every 3,4 months put bleach into the drain to keep it clear .
Apr 22, 2009 | Frigidaire PHSC39EGS Side by Side...
Every few days a stream of water comes out
The defrost heater is working, but the drain is blocked with ice. Every time the ref. goes into defrost the water does not drain down to the pan underneath the ref. You will need to remove the inside back cover in freezer and remove all the ice that has built up. you will need to defrost the ice with boiling water until the drain opens. then you will need to attach a heat probe to the heater and down into the drain. Usually you can use a piece of copper or aluminum wire to attach to the heater.
Dec 14, 2008 | Jenn-Air JCB2389G Stainless Steel Side by...
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
