Question about Dryers
Dryer only works for about 20 minutes, buzzes then stops.
My dryer will start up for about 20 minutes and then shut off. Before it shuts off it makes a buzzing noise. If I try to immediately restart it, it just makes the same buzzing noise as if it's trying to start doesn't. If I wait for approx. 30 - 60 minutes it will start back up and run. I'm thinking tha's it's either the motor or the drum support rollers. Any ideas?
  • 1 more comment
  • mreddad Jun 21, 2008
    Dyer starts and heats but shuts off ater a few minutes. It will start again after 20 minutes or so.
  • woodn1980 Jun 23, 2008
    I took the dryer apart and did find a lot of lint. I cleaned it out and it still has the same problem. I also ran the dryer on 'No Heat' and it made it almost all the way through the cycle and then I had the same problem.
  • woodn1980 Jul 02, 2008
    After cleaning the motor, I still had the same problem. So I replaced the motor and it works fine know.
    Sergeant:
    Champion:
  • 285 Answers
The dryer is over heating up due to a blocked steam pipe , fluff build up inside the dryer. I have a dryer that id the exact same thing , found out it covered in fluff though out the whole dryer , motor and element ..
Posted on Jun 21, 2008
Dryer shuts off prematurely. When I try to restart, it just buzzes. After an hour or 2 it restarts, but shuts down again after 20-25 minutes.
It is overheating for some reason , make sure the filters are clean and the dryer is not close to any wall. make sure the drum is free to turn and not binding.
Dec 03, 2015 | Dryers
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 | Dryers
What causes my dryer to stop after 20 minutes?
Sounds like a possible motor over heating. The main motor has a heat safety built in that shuts it off if it gets too hot. It will restart once it cools off some. Over heating could be from excessive lint around the motor or even from a blocked vent pipe. All you can do is clean it well and check again. If it still shuts off the motor will need replaced.
Jun 03, 2015 | Dryers
Need Kenmore 80 series, gas dryer wiring diagram. dryer overheats after 15 to 20 minutes, with a full load of clothes, then shuts off...........wait 20 minutes, then I can restart; ...
you need to send the model number kenmore doesn't make anything,the only way to tell who made it is by the model number but anyway if it stalls on you and you go to restart it does it make like a buzz sound if so you have a bad motor,when the motor cools off it starts again,it's not a t-stat or anything because when they fail they won't work again non resettable,most likely will be the motor
Dec 29, 2017 | Dryers
Turns off after a few minutes
sounds like your motor is overheating or going bad. sometimes lint built up around the motor can cause it to overheat. or the motor is dying.
Aug 31, 2009 | Kenmore 73952 Gas Dryer
Loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Apr 10, 2009 | Kenmore 62602 Electric Dryer
Kenmore Clean Touch dryer making buzzing sound and
Ya, happened to me. Sounds like you may have a clogged vent. (in the tube, or the dryer itself. Try cleaning that out really good. Then, double check that the venting is secured properly. If not, may overheat and shut down. I think that's what's going on. After you clean tubing (And the inside tube on dryer), the buzzing will continue for a while (days) until itr resets. If it runs after this, but still buzzes, that's your problem. Hope this helps you!
May 09, 2017 | Whirlpool LGQ9858P Gas Dryer
Roper RGX4634KQ will run for 3 minutes then stop.
if you can restart after it stops but have to wait 30 mins or longer suspect bad motor
Jul 21, 2008 | Roper RGX4634KQ Gas Dryer
MY KENMORE MODEL 110.76722694
You have a bad motor. You can remove and verify probably bad bearings and burnt start winding.
May 16, 2007 | Kenmore 74992 Gas Dryer
Dryers Logo
145 people viewed this question
Top Dryers Experts
