Question about Maytag Washing Machines
Maytag washer model # A212
The washer fills then does nothing. Not in any cycle. Could this be a lid switch problem? Or maybe the motor?
It is not the switch.
Posted on Aug 06, 2008
Does not wash
The arm does not move as the program does not engage the WASH cycle and it seems that the program controller unit is a suspect. You can remove the connectors and connections to the controller after noting the details and reset, If the fault repeats then the controller is a suspect. Check motor free movement, check if motor hums, if so check and replace the motor capacitor.
Jan 15, 2013 | Maytag Motor Start Switch for A212 Top...
MAV6200AWW; fill correctly then nothing, does not cycle at all
if the motor is not getting power are you sure you properly checked your lid switch? when you close the lid slowly do you hear a click sound?
Jun 24, 2009 | Maytag Atlantis MAV7000
Washer fills with water, then stops
OBVIOUS REPL LID SWITCH AND SHOULD SOLVE YOURE PROBLEM 100 % MAYBE INSTALLED IN CORRECTLY,, TAKE A LOOK AT YOUR LID MAKE SURE BUMBER IS ON AND NOT TWIKED
Nov 29, 2008 | Kenmore 22422 Top Load Washer
Maytag Atlantis MAV6200 fills but doesn't do anything afterwards
If nothing turns on than your Lid Switch is probably it.It is the first most common fix on this model. Please Rate This !!!
Nov 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer will fill but won't start cycle
you need to take the 2 lid switch wires from the lid switch and wire them together this will bypass the lip switch,should fix it,let me know-mike
Oct 20, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag stacked washer/dryer Model LS7804
OK it may be one of 2 things. I would check the lid switch first. On some maytags the have a lid switch that if it is not working properly it will not let the washer fill. If it will not fill the washer will not wash because the pressure switch did not activate the timer to wash. If the switch checks good you might have a bad timer. If you open the control panel you will find a tech sheet with the wiring diagram. I would follow the fill cycle and check the components. You might also check the water valve to make sure its ok too. But its very rear that both the hot and cold would go at the same time. Good luck!
Jul 11, 2007 | Maytag LSE7806A Top Load Stacked...
Washer fills with water , then shuts off , doesn't move to another cycle
Since you know about the lid and check switches, they are located under the splash (control)panel. unplug the machine and remove the screws holding the panel on. Using a meter check the switches for continuity and replace if they've gone bad.
Jun 06, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washer just fills up and that is it
Sounds like a winding on the motor is burned out or the timer is defective. The motor uses a low power circuit during the delicate cycle both during wash and spin. The timer selects which winding is energized (fast or slow).
Feb 05, 2007 | Maytag LAT3600A Top Load Washer
MAYTAG LAT9235AAE TOP LOAD WASHER WILL NOT WORK
Pt, Should be a yellow wire from the water level switch according to the diagram I have. See if it has 120V to motor when full. Just take it to ground. Same with the lid switch in closed position, it shows here as yellow, but could be grey, these diagrams are not always accurate. I think you have a level switch or lid switch problem. Check for voltage to the motor when it should be agitating. Catriver..post back.
Oct 01, 2006 | Maytag LAT3600A Top Load Washer
Washing Machines Logo
160 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
