Question about GE WBSE2090A Top Load Washer
Water won't fill
When I turn the knob to the wash cycle, where the water usually starts to fill, it doesn't do anything. I usually notice the sound of the water 'kicking' in.....but there is no sound at all. When I advance the the knob to the spin cycle, it will spin the clothes, but no water.
I would appreciate any help you can give me in this matter.
  • GE Master
  • 5,568 Answers
If it is doing it regardless of setting water temperature to hot or cold, then the water control valve to which the hoses are attached has failed.
These are junky when new, not generally expensive or difficult to replace.
If one source is working and the other isn't, you may have screens at both ends of the water hoses and one end is clogged.
Removing the back panel is pretty easy and the valve is normally not tough to reach and often held in place by 1 or 2 screws only with 1/4" or 3/8" heads.
If you have a Johnstone Supply in your area, the part will cost about half as much as from GE or Sears.
Posted on Jun 21, 2008
Water filling
sounds like a faulty cold water solenoid
Sep 25, 2017 | GE WDSR2080D Top Load Washer
Will fill with water but doesn't start cycle
One possibility is that the timer motor has failed.
That would mean the timer should not be sounding like there is a clock (ticking) inside, and the knob should not advance as it ticks.
You can listen for the ticking by putting your ear to the control panel on top.
The reason it fills is that that is the first step, and it would do that, even if the times doesn't work sometimes.
Be blessed.
Apr 20, 2013 | Washing Machines
What will the washing machine do if the timer is bad. My Roper fills up with water and won't do anything else at all, doesn't even make a humming sound. Had to drain with cup. The knob for
From the closed position lift the lid of the washer about 2'' and listen for a distinct click. Then set lid back down and should hear another click just before it closes. The wire form hinge on left side of lid actuates the lid switch. Is it broken? Let me know.
Jan 26, 2013 | Washing Machines
Kenmoore 800 washer doesn't do anything
Possible that the timer controller is faulty as it fails to switch or move in the cycle of the program
Use WD 40 to clean the switch, the knob can be replaced if this turns loose.
Jan 25, 2013 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Washer will fill but won't do anything after that when turn to spin cycle it will work just replaced intake water valve before this started
The timer is bad (this is the knob that you are turning to get the spin cycle to work). Order a new one from, use your model number to search for the right one. With age, these timers go bad and is usually is the problem, not much else can cause the exact problem you are having. Let me know if you need anything else.
Nov 04, 2010 | Whirlpool Washing Machines
Fill cycle stops before full
It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 03, 2010 | Kenmore Washing Machines
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Humming from Water Solenoid area
It may have some dirt or sediment clogging it making it work harder than usual.
Jan 23, 2009 | Washing Machines
Kenmore Model 24642300
It is usually a coupler, look under to see if black shavings
Oct 20, 2008 | Kenmore 22422 Top Load Washer
GE WBSE2090A Top Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
