Question about Acer AL1715 17" LCD Monitor
17" AOpen monitor about 2-3 years old
When I turn it on it starts to light up, then quickly turns off.
    Sergeant:
    Champion:
  • 285 Answers
Sounds like a backlight problem.. due to the inverter shutting down due to a fault.
Posted on Jun 21, 2008
Why my car when i turn large light fail and the car try to turn off?
Sounds like a loose cable, weak battery, or charging system problem. Start out by making sure all battery and ground and alternator and starter connections are tight. An auto mechanic would make quick repairs out of this problem. 25314047-wng3opgl1pug32fsc4t4fc4i-1-0.jpg
Dec 09, 2014 | 2001 Toyota Corolla
How to start a 2001 Volkswagen Jetta after replacing the battery.
If your car has the yellow car key symbol on the instrument cluster when you turn the key to on shown activated below it has an If your car has the yellow car/key symbol on the instrument cluster when you turn the key to ON shown activated below it has an immobilizer This light comes on for a second but quickly goes out when turning the car on and all is normal If it stays on you have an issue immobilizer This light comes on for a second but quickly goes out when turning the car on and all is normal If it stays on you have an issue
May 03, 2014 | 2001 Lincoln Navigator
Oil light
Turn the ignition key to the on position don't start the car press the gas pedal four time quickly then turn the ignition off remove key then start the car as normal the spanner light should be off if not repeat process
Mar 22, 2014 | 2011 Lancia Delta 1.4
2001 Sebring Wont start unless gas pedal pressed down. Just keeps turning over until I press the gas with the key turned then it starts. Check engine light is on.
First, go to AutoZone, Big A or any chain autoparts store, most have free CEL code reading, that will tip you off in the right direction.
Sounds like you have a EVAP issue, and the fuel system is losing fuel pressure, so when you press the gas, you are calling for more fuel allowing it to pressurize faster. Instead on quickly turning the key on, turn it to ACC (Lights and chime) wait 5 sec, then try to start. Most cars will start the fuel pump and pressurize the system for a quick start.
Also check if you smell gas around the car.
Dec 06, 2013 | Chrysler Sebring Cars & Trucks
No power to starter
At the starter key on or off make a quick connection with a screwdriver at +&-, if it sparks and turns over you need a new starter or solenoid.
May 10, 2013 | Cars & Trucks
Dashboard lights turn on and off
take to auto parts store hook up on computer
Jul 26, 2017 | 2002 Chevrolet Malibu
Check engine light stays on
On 1993 model turn the switch to on but no crank to start turn off turn on turn off turn on and let on that position, when all lights turn off the check engine light will star flashing for ej: two flash a quick pause and three flashes will be code 23 after a longer pause will star other code , code 55 is end of codes. after you have the codes can search with it,
Jul 28, 2012 | 1993 Jeep Grand Cherokee
Quick Rinse light was flashing at end of cycle. Opened and closed door and pushed Start. Quick Rinse and Cancel/Drain light are now flashing and machine won't start. Turned off power supply (30 seconds) /...
Ok try this, open the door and then hit these buttons in the following combination. HI TEMP - DRY - HI TEMP - DRY...then close door and press cancel...then wait for the pump to shut down. you should be able to run a cycle after this...If this fails to fix the problem give me the make and model # of the dishwasher, this can normally be found just inside the door.
Jun 22, 2009 | Dishwashers
2005 Hummer H2 battery went down and when I replaced it the alarm keeps going off and it will not start.
if it is the factory alarm you will have to do a relearn. G.M. uses a couple different ways to do the relearn and I would think it would be the same for hummer. turn off all acc and then turn the key to the on position wait 10 minutes you will see the light on the dash flash and go out . asap turn the key to off to on 3 times quickly and the third time leave it on on again do this 3 times for 30 minutes then after the final turning of the key 3 times on the 4th time start the car. so turn off all acc like radio , a/c ect then turn key to on in 10 minutes the light on dash will flash and go out quickly turn key from off to on 3 times and once again leave on on do that 3x for 30 minutes then start the car. that is the gm relearn for security they have one on some models that start after 10 minutes but that is usualy on the cheaper cars so just do the 30 minute.
Jun 04, 2009 | 2006 Hummer H3
Acer AL1715 17" LCD Monitor Logo
75 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
