Save files I bought a kingston flash drive 8gb and i don't know how to save files to it. I want to save the manual for my digital camera which I found on the internet.
  • 63 Answers
From my computer - there will an extra lettered drive there, to make it easy to find go there with the device unplugged then plug it in and refresh the view and you will see the extra entry.
Posted on Jun 21, 2008
My kingston 8gb flash drive shows 0bytes
Dont worry, you can usb flash drive recovery software like asoftech data recovery to get back your files. You may refer to this step by step guide
how to recover files from USB drive
You may check out this video tutorial also
Mar 23, 2012 | Kingston Digital DataTraveler 4000 8 GB...
Sudenly kingstone usb changed to skymedi and doesnt formated
When the flash drive is inserted and is still detected Kingston, flash drives can be repaired and the data can be saved.
How to save data
To save data, use software full version, for example, you can use EASEUS Data Recovery. After the data is saved, do the repair flash drive.
Repair flash drive Kingston
1. Right-click the flash drive, select Format - select quick format. If this does not work, don't repeat, do the second.
2. Format from Administrative Tools.
Win XP: click START - Control Panel - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - select quick format
Win Vista & 7: click START - Control Panel - select View by: Large Icons - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - Perform a quick format - OK. If this does not work, don't repeat, do the third process.
3. Format using the software, the HP USB Disk Storage Format Tool. Make the process quick format. If this does not work, don't repeat, do the fourth.
4. Repair the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
How to install the HP Drive Key Boot Utility to the operating system
Win XP: double click the file cp006049.exe - select Install
Win Vista & 7: double click the file cp006049.exe - select extract
How to use the software HP Drive Key Boot Utility
For Win XP, first way
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win XP, second way
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\Program Files\Compaq\hpdkbu\ flash\initrd.img - Next - wait until the process is complete.
For Win Vista & 7, first way
Insert the flash drive - double click cp006049.exe - for example, extract to C:\HP Drive Key Boot. Open folder C:\HP Drive Key Boot then double click file hpdkbu.exe - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win Vista & 7, second way
Insert the flash drive - double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
initrd.img files, the image file for the schema partition flash drive capacity <= 2GB. For capacity >2GB, example: 4GB, 8GB, 16GB, 32GB, etc when we use the initrd.img file, will be changed to 2GB capacity. To restore the capacity of flash drives, do the Low Level Format. To make the process of Low Level Format, use software HDD Low Level Format Tool.
How to restore the capacity of flash drive Kingston
Open HDD Low Level Format Tool - select drive - Continue - click S.M.A.R.T - click Get SMART Attributes - click the tab LOW LEVEL FORMAT - click Format This Device - wait for the process is completed - Finish. Then, remove the flash drive from the computer, then insert it again. Then do a quick format the flash drive. Finish
Hope it helps.
Sep 04, 2011 | Kingston Technologies 512MB DataTraveler I...
Kingston 8gb pen has malfuntioned
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm www.CardRecovery.com
May 30, 2011 | Kingston Digital 8GB DATATRAVELER C10...
Sd card not recognizable
I read the following spec for your camera: Recording Media Internal Flash Memory 64MB Video/Image
SD/SDHC Up To 32GB Video/Image
So, I think that an 8 GB SD card should work.
Try another capacity and brand to make it work.
Jul 12, 2010 | Kingston 4GB Secure Digital High Capacity...
I bought a Kingston 8gb flash drive and then it became RAW
you might have a virus on it. scan it with a virus software program. also try another usb port. some times the 2.0 ports don't work on the 1.0 ports.
hope this helps
Apr 30, 2010 | Electronics - Others
My kingston 8gb cards only show 1.87 gb and will
The 'FAT' file-system uses 16-bit arithmetic, and thus is limited to about 2GB in size.
The 'FAT32' file-system uses 32-bit arithmetic, and thus can easily format an 8GB device.
So, be sure to choose 'FAT32'.
Also:
Click Start
Right-mouse click My Computer
Choose Manage
Click Storage
Click Disk Management (local)
Does the card show a 1.87GB "partition", plus 6.13GB of "unused" space?
If so, then delete that "small" partition, and then create a new partition that "spans" the entire 8GB.
Then, FORMAT that partition.
Nov 27, 2009 | Kingston 1GB Secure Digital Memory Card
Move data from one computer to another with kingston 8gb data tra
When you plug in the Flash Drive to your old computer, it will show up in My Computer probably as Removable disk or "Kingston Data Travler". You want to open that link up and drag whatever files you need into that folder. After doing so you put the flash drive in your new computer and repeat the process except you drag the files out of the folder and onto your desktop or a folder of your liking.
Jan 31, 2009 | Kingston (SDCZ2-512-A10-KT)...
Can't view file in Kingston 8GB Pendrive.
Try this,
Format the drive using HP disc format tool after backing up the data.
Make sure you select FAT32 as file system.
You can download this tool from the following link,
http://www.eocfiles.com/bdc86eb1ed2989c30dcd1902e84939ae/bootdisks/SP27608.exe
Please let me know if the issue persists.
Nov 26, 2008 | Electronics - Others
Computers & Internet Logo
David Payne
David Payne
