Question about HP Officejet 7210 All-In-One InkJet Printer
7200 ALL IN ONE WILL NOT PRINT
7200 PRINTER WILL NOT PRINT. IT SOUNDS LIKE ITS PRINTING.
  • blb2 Jun 23, 2008
    My HP Officejet 7210 is not printing either.  I have removed and reinstalled the latest version of the software/drivers from the HP website and have installed all OS X updates.  It acts like it is going to print up until the very end, but gets hung up.  I can't print a test page.  I get an unexpected error (1525).  Help.
    Scholar:
  • 162 Answers
Unit crashed. You need to send it back.
Posted on Jul 25, 2008
How to fix error lights.
we are reading this blog http://www.canonprintersupportnumbers.com/blog/how-to-solve-canon-printer-e02-error/ here define some steps if you are free read this Steps To solve Canon Printer E02 Error
Jul 26, 2016 | Canon imageCLASS LBP-7200CDN Color Laser...
Printer receives info but does not print
Try uninstall then reinstall printer software. If you still have the problem check ink levels, then fi not printing selwct another printer port.
Oct 20, 2014 | Kodak ESP 7250 All-in-One InkJet Printer
Canon Image Runner 7200 prints twice instead of once. When I ask for two copies I get four copies.
If you are using Windows, you will want to check the drivers of the printer to make sure you are not selected on 2 copies.
Go to Control Panel\Printers and faxes
Right click on the printer driver and select "printing preferences".
Make sure the "Copies" is set to 1.
You can also try a wtest page by going to "properties" and select "print test page".
Mar 25, 2010 | Canon imageRUNNER 7200 Copier
Canon ir7200 or canon ir8500 which one is best to buy
for my choice will be Ir8500, tough and reliable machine and high speed printing.
Sep 06, 2009 | Office Equipment & Supplies
Printing Acrobat 9 pdf file to the Imagerunner 7200
In acrobat go file, print and press advanced. Check print as image. Print the job again and see if you get different results. This does the image processing on the PC. Your document may have a postscript error in it and your device may be set not to print PS errors.
What driver language and version are you using?
Try updating your driver to the newest version, get device status.
You may also wish to try PCL printing for that file. (as a workaround)
Do other files have the same problem? What about when sent to another printer entirely?
Mar 05, 2009 | Canon imageRUNNER 7200 Copier
HP Officejet 7210 All-In-One printer two-sided printing
Had the same issue with an Officejet 7210.
Basically, what the printer is trying (not very well) to tell you is that it is not capable of handling the entire two sided printing project automatically - which for reasons that are completely obscure is the default setting for two sided print jobs - way to go HP!
To solve the problem, open up the printer's properties window (or preferences depending on your approach). On the printing shortcuts page, you should find a drop-down menu entitled Print on Both Sides. This drop down should read 'Automatic' (which indicates that the printer will print the first side, flip and reload the paper and print the other side without any intervention - yeah, riight). Simply change this setting to 'Manual' and the problem is solved!
Happy printing!
'Doc'
Nov 23, 2008 | HP Officejet 7210 All-In-One InkJet...
Prints extra blank page for every one page of printed material
Ok, I too have HP Photosmart 7280 and it was spit'g out a blank page after each print page.
I went into the Control Panel/Printers - Right click on the HP Photosmart 7200 series icon and choose delete. Don't worry...just delete it.
Right above (Vista) click on Add a Printer - it's going to ask you if you want to add a local printer which is connected via USB connection or if you are set up wireless then choose Network
It will find your printer click on the printer hit next - then this is the most important step
It will ask you to find the manufacturer it shows Hewlett-Packard and underneath it shows HP - Do not click on HP - you'll have the same problem with that driver - choose Hewlett-Packard and find this driver HP Photosmart C7200 series Version 61.71.244.0 [3/23/07]
Hopefully they are all digitally signed with this information.
Click on that driver and click next - then click on replace the current driver and click next.
Print a test page and problem should be solved. Hope it helped!
Aug 01, 2008 | HP Photosmart C7280 Laser Printer
The printer won't print/just changed black cartridge
Uninstall the printer, reboot and reinstall using your printer software/driver cd.
Dec 18, 2007 | Lexmark Z715 InkJet Printer
Printing from the internet or e-mail
TO isolate the problem you can do a print preview and see if if looks good before printing.
If it does look correct before printing try
1) Sounds like there was a communication problem between the printer and computer.(IF the printout is garbles characters)
Typically you need to
a) Delete any existing print jobs.
b) Turn off printer.
c) Verify all cable connections to printer.
d) Power on printer
Try printing again...
or
If print previw showed "Code"
If the print out is "HTML Code" make sure you are not selecting "view source" and printing it...
Nov 20, 2007 | Canon PIXMA iP1600 Printer
HP Officejet 7210 All-In-One InkJet Printer Logo
74 people viewed this question
Ben Johnson
