Question about Epson Stylus 680 InkJet Color Printer
Epson stylus 680 injet printer willonly print very small text cannot change it
  • irismarsh Jun 22, 2008
    I AM EIGHTY TWO YEARS OLD AND FIND IT DIFFICULT TO DO THIS ,HAVE TRIED CLEANING THE HEADS,MAKES NO DIFFERENCE . CAN NOW ALTER THE SIZE ,BUT WHEN SET TO NORMAL IT IS MI NUTE HAVE TRIED REINSTALLING PRINTER THIS DOES NOT HELP
    Novelist:
    Sniper:
  • 68 Answers
Please go to my website http://www.the-inkstore.co.uk . I have the latest version of SSC Service Utility to download directly onto your computer and instructions on how to use it, what to click on etc etc. Click any of the Epson links if you can't find it, everything you need to know will be there, including printer Firmware resetting which sorts out a multitude of problems.
The 'maintenance required' problem with Epson printers has absolutely nothing to do with which cartridges you are using, it is a built in page counter in your printer firmware, which has a different maximum amount for each Epson model. Don't listen to old wives tales and heresay, we are the experts and it's an Epson scam to cause a lot of people to pay for maintenance or throw their printers away.
I haven't found a model that can't be reset with the latest version of SSC Serve or the manual reset on my site.
For Epson RX500 users there is also a manual reset on my site, as the SSC Serve software won't do it for you.
When using the program & choosing your printer from the list, it may have a weird name with 'x' in the model number, this is because some configurations are for many models in a series. For example, the C46 will be listed as C4x as it is for the C42, C44 & C46 models.
I hope this helps all Epson users to overcome the Epson scam of page counting and locking out until you pay their dealers money for maintenance.
If you like what I've done for Epson users, please show your appreciation by spreading the word and perhaps buying your ink from my site.
Happy trouble free printing
The INK Store (UK & Europe)
Posted on Jul 15, 2008
  • Aeronautical Apr 08, 2009
    I'd bet that the problem is not with the printer but the computer.
    Somewhere along the line, the settings have been changed either for the whole computer or the software package you are printing from such as Microsoft Word.
    To check the computer font settings first, click on the [Start] button at the bottom of the computer screen, click on [Control Panel] (If in Classic View) click on [Display], click on the [Appearance] tab, look at the bottom of the page where it says "Font size" and make sure [Normal] is selected. If you are partially blind you may want to set this to [Large] or [Extra Large].
    However, this should make no difference to your print size.
    Whatever software package you use to print from, such as 'Word' or 'WinWord', it is possible to save print settings that apply to all documents. If so, open a document you wish to print, but before printing click on [Tools] at the top of the page, then click on [Options] then click on the [Print] tab and where it says "Default Tray" make sure [Use Printer Settings] is selected. If this makes no difference when you print, it is possible that you have over-riding settings saved for that package, so with the same document open, just click on [File] at the top of the page, then click on [Page Setup] the click on [Default] and the document will revert to it's intended set up, as it was when you first installed it. Try printing the same document, then if ok, save the document before closing it.
    If none of these make any difference, it is possible that print settings have been saved somehow, which are coming into effect even when you uninstall the printer software and reinstall it. Therefore, all you have to do is print using the manual method, which is, click on [File], click on [Print] then when your printer properties box opens, click on [Default]. This will reset your printer to its intended settings as it was when you first installed it on your computer.
    I hope any of this helps!
    Regards
    Nigel
    The INK Store
    Master:
  • 848 Answers
Try this
1. Unplug the power and USB cables from the printer. I pried open my C42UX printer, careful not to break anything. I use a flat blade screwdriver to pry it apart; there are two-three tabs at the back and two at the front. Gently push them in, and then using a bit of force pry apart the cover.
2. Next I removed the two (2) waste ink pads. They are located at the back on the left hand side. I used the flat blade screwdriver to lift up the ink pads (they were soaked). Please use rubber gloves as it gets very messy.
3. Next I took the pads to the kitchen skin and washed them with just plain hot water until they were white again. I just let the hot water run on them (the pads are about three inches long).
4. Once washed I dried them using a hair drier. (you could place it the sun for a few hours or on top of your heater or maybe in a heated oven; (make sure you do not set it on fire with too much heat).
5. Once dried I placed the pads back in the ink waste bin at the back of the printer.
6. I closed the printer cover and put back all the pieces and plugged in the USB & power cable and turned it on. (Yes the lights are still flashing).
7. Go to this link and download this software: http://inkjetprinterhelp.us/epsonSSC.html
8. Install the software and run it.
9. Select your printer and model number ( It only says C42 there is no UX, choose it anyway).It will ask if you replaced with new pads; say “YES”. Then close the window.
10. Now right click on the SSC service utility, it looks like a printer icon near your clock in the task bar.
11. Then click on reset counters. You can do all other stuff with this utility too.
12. Turn off the printer power and then turn it on again. If necessary un-plug the power cord from the back of the printer, wait 20 seconds. Plug it back in.
13. THERE YOU GO! IT WORKS AGAIN.
Posted on Jun 22, 2008
Small printing
Start with reinstalling the software for the printer, do you have a cd, can you tell me what operateing system are you useing and I will get you the newest version of the software.
Jun 21, 2008 | Epson Stylus 680 InkJet Color Printer
Epson colour 680 green and red lights on, will not print
  • Pressing and holding LOAD/EJECT and CLEANING buttons,
  • press POWER button and hold it until You will see blinking INK OUT and PAPER OUT leds.
  • Release all buttons.
  • In 2-3 seconds time press and hold LOAD/EJECT button, until all leds will blink.
Aug 14, 2010 | Epson Stylus 680 InkJet Color Printer
Epson stylus color 680: can only print black, no colors
chek th eprint mode is it colour and the catridge is not empty.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 24, 2010 | Epson Stylus 680 InkJet Color Printer
Red light keeps flashing on EPSON 680
no, he can print only if he download a driver for his printer
Mar 08, 2009 | Epson Stylus 680 InkJet Color Printer
Printer driver lost and need to install
Give us a clue! What OS are you using and what language do you need. If you want an XP driver in Dutch, English, french, German, Italian, Portugese or Spanish or Mac OSX Driver in English I can help.
Apr 02, 2008 | Epson Stylus 680 InkJet Color Printer
Not printing in black
Turn off the Stylus CX. Load letter-size paper in the sheet feeder. Press the ink and ON buttons together and hold them down for about 3 seconds.
The Stylus CX turns on and prints a test pattern, which includes a nozzle check. If the print comes as = >
Nozzle check pattern with no gaps, and if its print in black then reinstall the printer driver
or => Nozzle check pattern with gaps and black doesn't print please send the printer for repair
Sep 19, 2007 | Epson Stylus 680 InkJet Color Printer
Epson Stylus 680 InkJet Color Printer Logo
204 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
