Question about Hoover Dryers
When loading the dryer (Hoover Maxi 6 TV30) a continuous 'buzzing' noise can be heard when the on switch is pressed. This can be heard for a few moments or a little long then everything is OK. Occasionally I have to tap the front panel (just above the timer) to resolve the problem. I have been advised it might be the relay.
  • 525 Answers
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database. Please observe the TIP below, and post me back and I will be happy to assist you further. Should you require more extensive consultation to help resolve your complaint(s), you may contact me through our premium chat service.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
Based on your complaint it, certainly sounds like a relay,(typical), or it could be the timer motor. I have no way of knowing if it has a relay. Generally this is harmless.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
Posted on Jun 21, 2008
Dryer makes a buzzing noise when I turn it on but it doesn't come on, just buzzes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
What is the model number?
Nov 06, 2012 | Dryers
Hoover WDM120 scraping noise heard when drum spinning with a load in washing machine.
have come across this prob before the noise you describe sounds like an underwire from a bra or the condencer on the back of the mach some had a baffle plate fitted just where it goes onto the backof your mach on some this came loose and caused it to scrape of the back of the drum hope this helps .
Jun 07, 2011 | Hoover H120M Front Load Washer / Dryer
I have a Kenmore Elite electric dryer. It is only two years old. The dryer is a HE 3. Model 1108787 or 1108789. It was working fine two days ago then after finishing the dryer load it was on....I went to...
This could be one of several things.
1.thermal fuse is blown(with power off(unplugged)check for continuity)
2.Belt is broken (check belt).
3.loose wire somewhere
4.Door switch malfuntion push in on it and and test for continuity.
5.The control board is malfunctioning.Try removing it and observe the back of it for burnt or cracked places.
6.Motor is bad test for power to motor see wiring diagram and tech sheet inside cabinet.
Input full model # here for parts and diagrams. Model # should be located just inside of door.
Nov 03, 2010 | Dryers
My dryer is making a buzzing sound when trying to turn it on. Not working. Cleaned lint in machine. Also made sure the door is closed. This happened a few weeks ago, didn't work for a few days and then...
the buzzing noise is the motor trying to start try a test leave the door open with one hand press the door switch with other hand spin the drum at the same time have someone press the start button if your dryer starts then and when it is cool it is the motor replace the motor
Apr 05, 2010 | Dryers
Hoover TV30 tumble dryer belt do I access the belt area? I cannot slide the top off!
On models that do not have disengageing clips for the top to be removed, you must remove the front (face panel) and this is usually done by 2 small screws at the bottom of the front panel. Then you tilt the front out and will be able to unhook the front from the top. Now, you need to undo a small bolt or screw inside between the top and the side panel (there is one on each side). Goodluck, Macgivor
Jan 02, 2010 | Hoover Dryers
Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
Aug 26, 2009 | Hoover Dryers
Dryer makes a buzzing noise when I push the start switch.
Sounds like a bad motor, The buzzing noise is probably the motor humming then nothing because the thermal over load switch inside the motor opened. Timer will still be energized. Good Luck
The Squirrel
Mar 26, 2009 | Dryers
My Hoover TC650 condensor dryer has a fault. When turned on it makes a noise (buzz) but the drum does not revolve. If I turn it by hand and then quickly close the door and press the button it will...
i saw your question and never worked on a hoover dryer so i checked it out go here to see video
i have to tell you on all the dryers i've ever worked on they never had a cap in them,only washers,on a dryer that isn't a condenser dryer if you get the dreaded buzzing sound and start it like you did,open the door,hold in the door switch and spin the drum with your other hand while someone else pushes in the start button and it would start it would be the motor,i've seen a condenser dryer and the problem always was with the filter,people that had just bought one didn't know you had to clean out the filter box,never took one apart,i saw that nobody answered you so i hope this video helps you out and i learned that condenser dryers have a cap in them.
Dec 30, 2017 | Hoover Dryers
Hoover hdv fm tumble dryer
only thing may make a buzzing sound is a relay not making up or a motor contactor not closing all the way.
Sep 11, 2007 | Hoover Nextra HNT 2135 Top Load Washer
Dryers Logo
118 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
