My PC was unplugged before powering down it is an ACER, all that comes up not is DEl TO START UP AND F12 TO BOOT NETWORK...MY PC will not recognise my keybaord
    Scholar:
  • 141 Answers
Hi Tilley;
Power Off your PC
Remove Keyboard
Power ON your PC, do you see "No keyboard detected"? anyways
POwer Off your PC again
Now,insert back your keyboard, POWER ON and make sure you see 3 lights blink in your keyboard
better yet, use your keyboard on another PC just to make sure its working.
Hope this helps, i often do this procedure when my keyboard doesnt work...
Posted on Jun 23, 2008
What is the f2,f8, r f12 want work? only the Ctrl+ Alt+ del that wroks
F2 usually takes you to the BIOS setup screen, you need to hit the keys as soon as you power up.
F12 selects on a Dell instant boot menu to select booting from CD-ROM, USB, etc rather than the BIOS options.
F8 goes to safe mode start up for windows, this must be done before the windows logo comes up (ie when it is a black screen).
Control - Alt -Delete Keys together can be used any time, after windows boots as it tells it to re-boot the computer, back to start up.
Jan 30, 2015 | Computers & Internet
Have power pc does not boot
your system is not booting probably because the OS is corrupt. Have the OS reinstalled and your PC's operation should re restore.
Regards.
Jan 05, 2012 | Acer Computers & Internet
I have an acer aspire one zg5 it boots up to the acer logo and begins to start then all of a sudden the screen goes black and a white underscore flases in the top left corner. i called acer yesterday and...
A few things to check
  • If you have any external storage (Hard drive, flash etc) plugged in, unplug and reboot. Your computer is trying to boot from these.
  • Power down the computer and unplug and remove the battery for at least 30 seconds
  • Enter BIOS (generally F9,F10,F11,F12 or del) just mash them all while the logo screen shows and check under boot devices and see if a hard drive is listed. If no then your hard drive is bad and I would send it in if under warranty
Comment back for further assistance.
Aug 20, 2011 | Acer Aspire One Netbook 8.9" Notebook
When you push the power button, the button turns green but the computer doesnt start up. The lights are on but there is nobody home, there is no sound indicating that the computer is starting up.
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
Hope this helps you.
Feb 18, 2011 | Acer Aspire 9300 Notebook
AcerPower 1000 (AP1000EA380M) PC Desktop: i cannot install win xp on acer power 1000...
Hi! Try to go to bios menu via F2 or del while system is starting up.Go to sata operation, change IDE to AHCI or vice versa, save settings then try to reinstall os(win xp) again via booting to the disc (F12) and choose cd/dvd or odd...hope this helps...Cheers!!!
May 18, 2010 | AcerPower 1000 (AP1000EA380M) PC Desktop
Acer computer is frozen on screen which reads press f12 or del to enter setup. when computer comes on it does not beep so i cannot use keyboard all the lights on the keyboard aare off. HELP!!
From the description you are giving, it appears that the system is not detecting a bootable hard disk drive. Hold the power button on the system till it powers off. once system is off, try the following:
  1. Ensure no floppy diskette is in the A: if system has a floppy drive
  2. Disconnect all external items (Printer, scanner, network connection) leave only video and keyboard connected to system.
  3. Try powering system on again
If the system gives the same message, try rebooting and pressing F12 ONCE at the ACER screen and see if you can get a 1 time boot menu. If you can get the boot menu, select CD-ROM, and put you WINDOWS CD in the optical drive, see if system will boot to the CD. If you can, then at the first prompt, press R to enter recovery console, and see if you can run the command CHKDSK /R (then press enter)
If chkdsk runs, then reboot and see if the error has gone away. IF you cannot run CHKDSK then the hard disk drive has likely failed and will need replacement.
Nov 01, 2009 | Computers & Internet
Acer Aspire T180
check your removable media disk drives and make sure that you don't have like a jump drive or CD-Rom that the computer doesn't like. If that doesn't work, enter the BIOS setup (usually F2, F12, ESC or something like that....check the bottom of the screen.) and find the Boot Order settings & move hard drive to #1
Jan 08, 2009 | Acer Aspire™ T180 PC Desktop
Wont turn on
He is getting the screen with del, enter , f12 so the power supply is fine it could be his bios battery that needs to be reseeated and factory default loaded. If you left it on for a while it could be in a state of sleep/hibernation and if you should it down manually you could have stopped it from resuming and thats why it wont boot now and by reseating the bios battery for a couple minutes could remove the resume from the computers memory and might fix your problem. Hope my answer gets you closer to a solution. Please Help rate me if I helped you out or not I am new but a very good tech.
Aug 09, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire T180 Frozen
Select the del and in bios, select optium defaults. next select F12, will it go any further?
Jun 08, 2008 | Acer Computers & Internet
Acer Aspire T180-UB72 does not boot
I have the same model and had the same problem. Fortunately there is a simple fix - unplug all your USB devices (mouses, printers etc). It should now boot!
Assuming that fixed it, it was trying to boot from a USB drive for some unknown reason. I think it was due to the latest windows XP update. Wierd. Hit F12 next time you reboot and make sure it is booting from hard disk first.
Jan 09, 2008 | Acer Aspire™ T180 PC Desktop
Computers & Internet Logo
David Payne
David Payne
