Do you mean you want to improve the speed from what it always has been?
What are the "kinds of things" you've already tried?
What OS?
The more information you give the better the chance of a solution that will work.Do you mean it runs slower than it used to?
What OS?
You can't post conmments that contain an email address.
First, small size of RAM makes computer slow. When we use many programs at one time, computer tends to bogged down. Since, uploading/viewing pictures or watching videos on Facebook use many resources, it can result in freeze. This problem can be cured by increasing the size of RAM. An increased RAM size will make sure that enough space is available to run many programs at the same time.
Secondly, corrupt windows registry cause freezes in computer. With passage of time, registry becomes congested and corrupt. Registry is most vital part of the computer system that stores and use vital information.A neat and clean registry ensures smooth and fast computing. Clean registry means no Facebook kind of freezes. For this, you need to use the best registry cleaner. It will solve the problem of such freezes. Registry cleaner reg in out should be used regularly. Additionally, it will speed up computer for all other programs.
Software Installation : Installing more and more software can make the computer slow down. The reasons for that are that installation of a software will make entries in registry and that is somewhat bad. The software may be running in the startup. The software will install various files on the computer and an overloaded hard disk makes the computer slow.
Free up disk space : Try to keep your hard disk space free. You’ll always notice that a computer with free space on hard disk will always run much faster than the one which is loaded with extra stuff. * Remove Unwanted Items From Startup : Well, if you’ll remove the unwanted softwares from the startup then your computer will boot up much faster and the memory (RAM) will also remain free and thus that will again result in better computing experience
Run hard disk maintenance utilities : Always run the utilities like Disk Defragmentation or Disk checking utilities regularly, around once in 2 weeks
Run Registry Cleaner : Right, this one is related to first tip. In case you’ve already installed and uninstalled various softwares before reading this tutorial then you can go ahead and run various registry cleaning softwares
Hello Sis, I guess your computer has a big problem with a virus which your anti-virus wasn't able to detect. If I were you, I will back up all my files on a separate drive then format your computer. This crazy problem already happened to me and what i did was the one i just wrote to you. If you don't have the actual drivers for your computer, go back to the place where you bought it from and ask for the drivers then you can format your computer by yourself. If you are not able to do it on your own, consult anyone who is able to do it for you.... Godd Luck Sis !!!!!! Good Day !!!!!!
i have i problem in pc when i start my pc it works slow and when i want to download but can do that the task manager also not working please solve my problem as soon as possible
well i need to know what type of system you are running and what kind of computer you have. i have on thing in mind, did you try to add a hardware setup program. sometimes that helps.
What OS?
