SOURCE: Frigidaire Dishwasher FDB1050REC1 - Washing Indicator Light Blinking
Make sure the water feed is open....although I don't know this make and model, a flashing light at the start of a program is usually always to do with a water feed problem....make sure there is sufficient water pressure at the hose (by closing the tap, removing the feed from the dishwasher and opening tap with hose in bucket) You will be surprised how many times a worn tap washer is to blame for low pressure. A stiff turning tap is always a sure sign of problems.... If the unit is a integrated model, make sure that when you close the door it "clicks"...if it does not activate the door switch properly, there could be a flashing light. Sometimes the integrated units "move" deeper into the enclosure, and the door will not close properly to activate the door switch. Oshie
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
SOURCE: Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
SOURCE: Flashing "Washing" light on my frigidaire 1000 series dishwasher
no name 2's solution worked great for us so far. It took me while to figure out how to disconnect the two connectors, so I thought some pictures might help.
Hello Shirley - Typically error code ER01 indicates that a water leak is detected under the tub. Unit will possibly need a hydraulic kit. Try unplugging the unit or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. Could the error code DF possibly be PF? If so, PF means power failure and you should be able to start a cycle. If the error code continues to display on dishwasher then I suggest contacting a professional to accurately diagnose and repair it.
