Question about Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118)
Ford escort my doors wont lock , the key doesnt work
  • 660 Answers
Wrong or damaged key......
Posted on Oct 04, 2008
I have a 97 ford escort and the drivers side door is not the same door. So the locks are different
You would have to get a locksmith to cut a key from scratch by making an impression of the lock.
Jan 16, 2014 | Ford Escort Cars & Trucks
2000 ford fiasta. you can lock with keys but cannot unlock drivers door. the lock was a bit stiff but now turns only i little. locking no problem. unlocking from other door ok.
you will have to spray wd40 into the lock and keep working the key in and out and turn side to side and spary every so often. good luck.
Jan 27, 2010 | 2000 Ford Escort
I just recently bought an 89 ford escort LX and there was no key with it. the car would start with out a key until today when i turned the ignition switch all the way back and it locked the wheel. now i...
drill out the lock with a 5 mm drill bit to the depth of the key, the drill will turn the lock and probably start the car when it is drilled out just enough and the key will still work in the lock if you push it right in only any key will now fit and this key will fall out going round corners... you can get the ignition barrel and key for about £25 from car breakers, and now the lock is drilled once you push in the buttons on the bottom of the barrel it will come out easily = theres always an escort on the breakers, any MK4 escort lock will fit, get the door locks and keys too if you dont want more than one key with the car - having mismatched keys reduced the resale value also.
Jan 24, 2010 | 1989 Ford Escort
Does the 99 ford escort have a transponder key for the anti-theft
Hello. yes, the 99 escort does have a transponder key. Here is a link which discusses it. http://www.fordf150.net/howto/patskey.php
Regards, Joe
PS please rate my answer. Thank you. AND happy holidays
Dec 19, 2009 | Ford Escort Cars & Trucks
I slammed the passenger door too hard and now the radio doesnt stay on when key is turned off, the auto lock on that door doesnt work and the dome light wont come on 2007 ford escape
I`d check the flexible wiring between the door and the car to make sure it hasn`t been trapped or snapped.
Also check the fuses to make sure one (or more) haven`t blown
Aug 28, 2009 | 2007 Ford Escape Hybrid FWD
Remote key fob won'tprogram
1-insert and remove key from ignition two times
2-close and open driver door two times
3-insert and remove key once from ign.
4-close and open drvr door twice
5-insert key into ign.,then close driver door
6-turn key to on (not start) then off, twice this is rewrite mode,have all remotes to reprogram it will clear any lost remotes.
7-remove key from ignition,the door locks should cycle twice.if not start over.it may take a few tries.
8-press lock/unlock together and hold for a second
9-release,and press lock on remote,the door locks will cycle confirming program.continue to do other remotes you have,steps 8 and 9.if only one in possession,you are done. To end mode open door or insert key into ignition.
You'll need to follow the steps with no more than a 1-2 second delay between each step.. hope it works
Aug 13, 2009 | 1999 Ford Escort
CENTRAL LOCKING ON 99 T REG FORD ESCORT
Some of the Escorts do not have central locking. If the keys open both front doors, the hatch and fit the ignition then I would not worry too much about it. You may find that you also have a hatch release catch at the side of the drivers seat also. I trust this information helps you.
Mar 11, 2009 | 1996 Ford Escort 4 Door
My doors wont open
disconnect the bonnet switch under the hood behind the right headlight .should stop the alarm.let me know how you get on with this.will the doors open manually with key in door.or they wont open with remote as you did not specify
Oct 12, 2008 | 1998 Ford Escort
Ford Escort 1998 central locking
Are you talking about the key cylinder or the electric lock button? If you are talking about the key,you need to remove the door panel and watch the lock rod move up and down. There is a plastic clip that pops open or breaks from age. If you are talking about the electric lock, will the passenger door lock move when you press the lock button on the drivers door? Does the passenger door make a grunt noise when trying to lock/unlock?
Aug 25, 2008 | 1998 Ford Escort
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) Logo
23 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
