Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Help the water and shampoo will not come out of the shampooer what could be the problem
    President:
  • 1,673 Answers
• tanks are not sealed into receivers
• faulty auto load receiver
• pinched/clogged line
• defective component allowing air into system
• pump not mounted so it can move freely
• defective bridge rectifier
• clogged heater
• defective pump
• defective circuit board
* spray nozzles are clogged
Posted on Jun 21, 2008
My shampooed won't pick up ythe water
does your shampooer have a cap on the shampoo tank. Usually you take the cap off to let the shampoo out while shampooing and to pick up the water you put the cap back on to create a vacuum to suck the water off the floor..
Jul 01, 2017 | Vacuums
I have a Kirby vacuum with the shampooing attachment. The shampoo/liquid comes out of the shampooer in a drizzle of liquid. There is no foam.
You need to check that the little round screen is in the hole where the hose attaches to the shampoo tank. My guess is that the little round screen is wedged sideways in the end of the hose. Here is a guide to help you further... http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Marci
Jun 01, 2009 | Kirby Ultimate G Bagged Upright Vacuum
My Kirby shampooer - G4 - hardly used any water from the tank and no suds at all. Pet hair did blow out of the small slotted holes in the tray as I moved the shampooer back and forth, but the carpet was...
Few things:
Make sure the sponge and the valve under the sponge (water tank) is clean.
Make sure you follow the instructions (f you do not have the manual you can find one HERE)
See if the straw inside the water tank is not clogged (happens when you use toilet tissue or some other paper to dry inside of the tank after you shampoo)
Noise - if it is noisy al the time - it may need new shampooer brush roll. Also check the tray - bar brush roll bearings overheat and melt the tray... Never submerse brush roll in water when cleaning it. Clean it simply by lifting the shampooer nozzle and letting it spin for 10-20 seconds. If you have tu put it under running water - put it back in the shampooer nozzle (with tray and shield) put on Kirby and turn it on for 20 seconds or so. If it stays soaken wet - moisture damages barings.
Good luck
Feb 28, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Shampooing with the kirby
In the cap where you fill the shampoo, make sure the filter and components are clean
Apr 17, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Shampoo stairs
There is a portable shampooer/sprayer that attaches to the hose ( the long one that makes the kirby a canister vacuum). It should have come with your attachments. Looks a bit like a gun without the tank attached to the bottom...the tank screws on.
To use it you would put the fingerguard attachment on the front of the kirby where the powerhead would normally go and the hose with the portable shampooer where the bag would go.
The tank on the portable sprayer/shampooer has lines to indicate how much water and shampoo are needed.
Be sure to put the mesh nozzle (sort of a triangular shaped thing with a piece of mesh along the front that attaches to the front of the portable sprayer) on the front of the portable sprayer if you want to shampoo..otherwise it will just spray a mist. The triangular piece with the mesh screen is what produces suds.
Vacuum the furniture/stairs thoroughly before shampooing. Cover the stairs/furniture with a thick coat of suds. Once covered with suds, pop the suds into the fabric/carpet using your hands...working the bubbles into any heavily soiled areas with a soft brush. No need to vacuum after shampooing. There is only about 10 percent water to 90 percent air in the suds.
Then let it dry. 15 minutes to and hour depending on the amount of solution used. Hope this helps!!!
Feb 23, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Rainbow aqua mate II instructions
You have the vacuum and the basin, you put them together just like when you vacuum but don't put water in the basin. There is a large white container that comes with the shampooer. you fill that up with water and then you place the vacuum cleaner and the basin on top of that. Now you will need the water hose (not the one that has the gas pump hadle). Hook that in the same spot that you do for vacuuming. Then you take the shampooing handle( it will have a trigger and a little white bottle and some tubes hooked to it) the one end of it hooks to the water hose and the other end hooks to the wands. There are 2 wands that come with your shampooer. At the end of those the shampooer head will be attached. There are two separate tubes there is a thick tube ( there two tubes fused together) and a thin tube, they hook to the large white container that you fill with water. Just look and you will see where they go. Then there is a tube that hooks to the shampooer head at the bottom. The you take the little bottle and fill it with your shampoo. You should have gotten some clips to hool onto your hose so that you can keep the tubes attached to it so they aren't in the way. You should be set. I hope I helped.
Jan 27, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Kirby Sentria - Not distributing shampoo correctly
this site may be helpful
make sure the brushes on the shampooer head are spinning and that you have the shampooer head lowered all the way down to its lowest setting. Also...shampoo at a slower pace than you would move when vacuuming...when both putting down the suds on heavily soiled areas and scooping them up. The more oils in the carpet, the less suds you'll see when the shampooer is working properly. one more thing that may be mentioned in the guide is the little round sud screen that attaches to one end of the shampooer hose...make sure that little mesh screen is there and seated properly. It is what produces the suds from the shampoo solution.
Dec 07, 2007 | Vacuums
Kirby Vacuum Shampoo Attachment
If your trying to shampoo your carpets but the water flow is to weak and it trickles through the spout to the carpet leaving small puddles
This problem often occurs when the foam filter is not replaced after rinsing or ends up in the shampoo hose at an angle preventing foaming. If you take the small shampoo hose of the shampoo tank the filter should be on the tank, if not, it may have come off and be in the hose. If it’s not there locate it, likely in the area where you last cleaned the shampooer or in the box, and put it back on the tank. While this should be cleaned after each use, care should be taken to replace it and not lose it.
The problem may also occur if you don’t actually add the Kirby Dry Foam Shampoo to the water or if you use some thin else.
Take care to also clean and replace the air filter after rinsing. It is located under the shampoo tank where the tank fits onto the vacuum.
Phil-T
Sep 07, 2007 | Vacuums
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
47 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
