Question about Dryers
I need to change the exhaust pipe vent for my tumble dryer. it has ripped. how do i go about fixing this or do i need a professional?
  • 958 Answers
You can put an aluminum duct tape to the ripped portion just to stop hot air from venting from the damaged portion. or if the ripped portion is near the end where you put the flexible hose, then maybe you can move the flexible hose as far as it can reach as to cover the ripped portion of the vent pipe. then secure the flexible hose with a good hose clamp. i hope i was able to help
Posted on Jun 21, 2008
I have a CE Error. How do I clear, or reset, my dryer to clear this error?
CE - Clean Exhaust
Shameful!
You need to clean out your dryer vent.
Not just the exhaust vent, do the whole pipe.
If you don't know when you last did it, you need to do it.
Yes, we all hate to do it, but it needs to be done.
If you have an electric leaf blower, take the exhaust vent off outside, disconnect the pipe from dryer, and let'er have it.
Mar 19, 2015 | Kenmore Dryers
My kenmore 60 series gas dryer stopped drying clothes.
Check for restriction in lint chute, blocked exhaust tube, plugged lint screen
Feb 12, 2013 | Kenmore Dryers
My dryer comes on and spins, but it is not drying the clothes. What could be wrong?
Its most like to be the thermostat, temp sensor or the heating element is broken.
Sep 10, 2009 | Hotpoint Dryers
Dryer lint all over the house
Generally this would be caused by an open or tear in the flexable exhaust vent pipe to the outside. Look behind the dryer and determine if the flexible exhaust pipe is connected at both ends. With the dryer running you might feel a lot of warm/hot air in the area around the vent pipe if there is a tear in the foil. The fix is either to reconnect the pipe or replace it if the pipe has a tear in it. You should be aware that if the lint is exhausting into your home, it is likely the exhaust gas (carbon monoxide or other exhaust gases) are being injected into your home. If you are unable to repair this, you should call an appliance repair company and have a professional technician check out your unit.
Dec 12, 2008 | Whirlpool LER5636P Electric Dryer
Dryer Heats - Drum Turns - Clothes Don't Dry - Dryer Seems To Over Heat
Before ripping into the dryer, with the dryer running, check the vent outside. There should be a rather strong air flow. I'll bet you have little or maybe no air flow. Check behind the dryer to make sure you don't have squished flex duct. If you have flex pipe, try running the dryer for a few minutes with the dryer pulled out into the room to stretch the vent out, and check outside airflow again. Try to eliminate all or as much of the flex stuff as you can, replacing it with aluminum dryer vent pipe. (tape joints with foil duct tape) Clean out remaining dryer vent. (there are special brushes you can buy to clean out vents, but they really only work on ridgid pipe.)
Sep 27, 2008 | Hotpoint NVL333EY Electric Dryer
Tumble dryers
condenser takes the warm moist air and keep circulating it within the dryer ,,some times these unit have to be emptyed of water every so often..exhaust vent have to be vented directly to out side..
Sep 08, 2008 | Zanussi TC7114W Electric Dryer
Tumble dryer problem
Please refer to the following link for detailed instructions on how to diagnose you dryer problem.
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you only changed the vent hose on the back of the dryer, it may not have been enough. Especially, if your vent line runs under the house, or through an attic. If you have long exhaust run from the point where the dryer connects to the exhaust, to where it exits your home, you may have a clog EXTERNAL to the dryer. You need to trace the exhaust line and locate the cause of the air flow blockage.
Try removing the vent hose on the back of the dryer and check for air flow. If you still don't have air flow, you have a clog INTERNAL to the dryer and you will need to open the unit and check the blower fan assembly under the lint screen. If you have air flow and still do not have any heat, please refer to the link I provided for advice on how to determine what may be source of the heating circuit failure. If you need further assistance, or have questions, please post back and let me know. I hope this helps you.
Jun 11, 2008 | Dryers
Whirlpool Dryer
Your prof. vent cleaner failed to do his job. Ther is a definite restriction in the vent from point A to B, The prof is in the test u performed. You need a straight shot from the dryer to the outside using a class A 4"vent line and a dryer exhaust hood at the termination point,then your problem will be resolved...
Apr 29, 2008 | Dryers
My Miele T8322 Tumble dryer turns off before the clothes its fully dry even in Extra Dry mode. The vent pipe is clear. Is there any kind of adjustment or do I need to get a new sensor under warranty...
IS THE DRYER PUSHED UP AGAINST THE VENTING IN THE BACK OF THE DRYER? IT MAY BE CRIMPING THE EXHAUST MATERIAL CAUSING A RESTRICTION.
IF THAT IS O.K., DISCONNECT THE EXHAUST AND RUN A LOAD OF LAUNDRY THROUGH A NORMAL DRY CYCLE.
IF THE DRYER DRIES THAT LOAD O.K., THERE IS A RESTRICTION SOMEWHERE IN THE EXHAUST. ALSO, CHECK THE LINT TRAP. IF THERE IS A WHITE CLOUDY FILM ON THE LINT FILTER, TAKE A WIRE BRUSH AND CLEAN IT OFF. IT IS RESTRICTING THE AIR FLOW AT THE FILTER.
CHECK THE LINT FILTER HOUSING FOR A BUILD UP OF LINT. IF THERE IS, USE A CENTER CARDBOARD FROM WRAPPING PAPER ATTACHED TO THE END OF THE VACUUM HOSE. FLATTEN THE CARDBOARD TO FIT INTO THE FILTER SLOT AND CLEAN OUT THE LINT.
Apr 22, 2008 | Dryers
Dryers Logo
Top Dryers Experts
