Question about GPS
I have a Mio C220 that does not power on even though battery is charged. Will not work off of battery or plugged into cigarette lighter. Bought it in Nov. 07 but have lost box, receipt, software, and all documentation. So, warranty is not an option.
Mio wants people to know, especially the folks who recently bought the Mio C220, that you need to put the SD card in the unit for it to work. The Mio C220 has the maps on the SD Card, and it seems that not everyone knows to put the SD card in the unit before firing it up. No SD card means no working GPS.
Mio Says:
1. Before you power on your C220, insert the SD Card firmly into the slot on the right side of the device
2. Once the SD card has been inserted into the device, power on your C220 by pressing and holding the power button for 10 seconds.
For More information check out the Mio GPS Page on the SD Card for Mio C220
Posted on Jun 22, 2008
Used cigarette lighter to inflate tire, left inflater on for a long time now cigarette lighter doesn't work and car doesn't always start
It sounds like you might have drained your battery! When the car is running does the Cigarette lighter produce power? It should be working while the car is running. That would also explain why the car starts sporadically. Try leaving the car on for 40 minutes. That might charge the battery enough.
Jan 22, 2014 | 2001 Pontiac Grand Am
Unlocking the car
You can either buy or easily make from readily accessible parts the "battery clips/clamps to cigarette lighter adapter" or just get a cheap chinese battery charger that has the cigarette lighter thing already attached to it. Plug one of these into the cigarette lighter for at least a few hours and it will charge the battery at least enough to unlock doors, etc.
If you are in some kind of metro area go to the Harbor Freight store and for under $15 you'll be OK. It is likely not the alarm system from preventing the hood being opened, but the lack of any electric power to kick the linear actuator from closed to open. Even still, once the battery is charged up again the alarm system would now be functional and you'd be able to turn it off or maybe put it in stand-by mode.
Nov 17, 2017 | 1988-1989 911 Carrera Relay Alarm
My garmin nuvi 650 na keeps depleting its battery even though I just fully charge it on the computer. It also does not charge when I plug it in the cigarette lighter in the car. The screen turns dark...
well if you have the factory car charger. There is a fuse inside of it. This is indicated in the manual. But it could also be the cigarette lighter fuse in the car is blown. I would make sure the cigarette outlet has power. If the cigarette lighter has power and you have the factory power cable that has a fuse try this. f the unit will not charge in your vehicle, you might need to replace the fuse that is located at the tip of the vehicle adapter.
1. to change the fuse unscrew the black, round end piece on the vehicle power adapter and remove it. inspect the fuse to see if it is blown. If not end here.
2. if determined the fuse is blown remove the fuse (glass and silver cylinder), and replace it with a 1A fast blow fuse.
3.ensure that the silver tip is placed in the black end piece. screw on the black end piece
let me know how this works by following up with a comment and i can instruct you on where to go from here. Thanks.
Aug 26, 2010 | Computers & Internet
I have a remote car starter, but find that the car does not heat up enough to clear the frost sometimes. I thought of adding a small electric heater that plugs into the cigarette lighter, but in my car (a...
do you have your heater controls set to defrost and the fan on high when you park the car,that way when you use your remote it is already set up.Your scooter though,I guess if it was me,I would run wires up to the front seat so I could plug it in the cigarette lighter while I was driving to charge up.
Jan 11, 2010 | 2004 Jeep Liberty
94 Toyota Tercel DX. 4 door
it is fuse # 1 in the fuse box under the dash on the drivers side it is a blue 15 amp fuse
May 29, 2009 | 1994 Toyota Tercel
Mio c220 sat nav update
You have to find someone who bought a Mio C220 with europe maps on their cd that came with their unit. You can download map from their cd using a 1gb sd card plugged into your computer.
Or try Ebay.
Jan 07, 2009 | Mitac Mio C220 GPS Receiver
1999 toyota corolla cigarette lighter works but electronics do no
a lot of cars are that way u need to have it changed to a power point adapter should not cost to much GM is famous for doing this even though it does not make sense
Jan 07, 2009 | 2000 Toyota Corolla
Battery dead; cannot open hood
If the cigarette lighter is an unswitched power point you could use it as a location to put a very small charge, just enough to get the hood release solenoid to activate. Years ago there was a device that was a male cigarette lighter power point at both ends and enough cable to go from car to car. DO NOT ATTEMPT TO DO ANYTHING ELSE EXCEPT OPEN HOOD, DO NOT TURN KEY TO RUN OR ATTEMPT TO START. ANYTHING COULD RESULT. MINOR OR MAJOR. THERE IS A COMPUTER MEMORY SAVER THAT MATES A 9 VOLT TO A MALE CIGARETTE LIGHTER PLUG THIS MAY NOT BE ENOUGH TO RELEASE HOOD BUT MAYBE WITH A 12 VOLT FLASHLIGHT BATTERY (2 6 VOLT BATTERIES) WOULD WORK TO OPEN THE HOOD. (TURN EVERYTHING OFF EVEN DOME LIGHT.)
Aug 23, 2008 | 1999 Porsche Boxster
WILL NOT CHARGE SAID BATTERY LOW AND WILL NOT CHARGE
I used another charger in house and charged battery must be the car charger adapter I haven't used it yet but I will today and let you know if it works
Jul 24, 2008 | Garmin StreetPilot C330 GPS Receiver
Charging unit with AC adapter
I have a 100v A/C power / charger unit for my garmin C340 GPS that I use to charge my Garmin's battery every day. I can use thj adapter to run the GPS, or just turn it off and let it charge the GPS. But it connects dirctly to the Garmin GPS unit, not to the cradle like the Cigarrette lighter unit does. .
Mar 18, 2008 | Garmin StreetPilot c340 GPS Receiver
GPS Logo
453 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
