Problem with HP Photosmart C5180 All-In-One InkJet Printer
ink system has failed error: oxc19a0035. what is the solution?
Posted by avatar on Nov 20, 2010
Solutions (2)
Best Solution
Ink system has failed error messages on hp photosmart c5180 caused by faulty capacitor on systems control board at right hand side of machine. The capacitor designation no. is C228 and is roughly in the middle of the printed circuit board. It is green and roughly 1 cm tall and is a 330uf 10volt component which is not high enough rated for job. You can see the faulty one straight away as the top of it is domed compared to all the other ones on the board. It is easy to get to and change provided you are proficient with a soldering gun. Unplug unit and lift ink draw, you will see 1 black torx screw holding side panel and 1 at the rear of unit. Remove and then you can get side panel off if you put unit on to it's left hand side. Use a flat screwdriver to prise plastic clip off at centre top and remove. To remove systems board, unscrew 5 silver torx screws and then you can work on board without having to unplug. If you cannot solder yourself, ask a competent electronics engineer to fit new cap. for you. I got replacement cap from Maplins at a cost of 26 pence. The one I got is a 50volt one and bigger than the original which is fine as it is better able to do the job and still fit ok. The old one was causing an AC spike to appear on the LT lines and corrupting the microprocessor.
I tried all the so called cures off the net and was getting to my wits end with this machine, it being a superb printer when it worked. People are throwing these machines away not realising that all it needs is a 26 pence part and 15 minutes time. This part was an instant cure as the machine was giving various errors and looping as well as going crazy at power up. After what I have read on net about other peoples experiences with HP tech.
I cannot believe that they do not know the cure for this fault and can only assume that they are more interested in selling you a new printer.
    • By avatarroberttrout4 Dec 01, 2010
    • PS. When taking plastic side panel off there might be a yellow plastic dummy plug in ethernet socket. Just remove to facilitate ease of panel removal.
    • By avatargwbuchanan Apr 02, 2011
    • Thanks Robert,
      The capacitor C228 was bad and another on my board by the same manufacture (Tempo) which appears to be out of the cap. manufacturing business. I replaced both and now printer works fine. Used Mouser Electronics Part # 667-EEU-FR1E331 & 647-UHM1A681MPD
      75 cents or appox. 46 pense plus shipping
    • By avatarakurt Aug 15, 2011
    • HI there, while I was carrying the motherboard in my bag looks like the capacitor c642 got ripped off. I had replaced the other one and was very happy about that but been triyng ages to findout the specs of the capacitor numbered c642 on the mother board. Any help ?
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
    NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon ( ). Figure 2: Example USB connection (your product might not look exactly the same as this example)
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
If you need more help come back.Post / thumbs / testimonial are welcome! Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Add Your Solution
See all HP Photosmart C5180 All-In-One InkJet Printer Problems
