Question about Compaq Presario Notebook
Blank screen The battery nor the a/c adapter are the problem. I have power yet the desktop screen will not come on.You can see the screen has some light but no image. Some one mentioned that the memory was bad, yet replacing the ram didn't work either. I am stumped.
    Genius:
  • 2,028 Answers
This sounds to be the screen. It's possible that the screen inverter has gone out, but usually you will barely be able to see the desk. Try plugging into an external monitor. If the external works properly. Then the problem is with your screen.
Posted on Jun 21, 2008
Dell optiplex not booting from xp cd
If your laptop screen is not working and is blank, you are out of luck as far as working on your computer. However, while there may be a major problem you need to troubleshoot, there are some easy solutions to keep in mind as well, such as brightness settings and your power source.
1. Check the power source. While you have presumably already attempted to turn your laptop on and off, the problem may lie with your AC power adapter. Is the power-indicator light on the adapter on? If not, your problem may lie here. However, whether or not you have a power indicator light on your adapter, consider unplugging it and plugging it into another outlet. This may turn on your laptop and take care of your blank-screen problem.
2. Check your brightness settings. While it seems like a simple oversight, the brightness on your laptop may sometimes be turned all the way down. Thus, the screen appears to be black, off or defective, when the problem is simply that the brightness is on its lowest setting. To fix the brightness, check your laptop keyboard. Most laptops have the brightness settings mapped to two keys at the top left of the keyboard, accompanied by a symbol (often a sun). Use these keys to fix your brightness, but keep in mind that some laptops require that you press the Function key at the same time as the Brightness key.
3. Check the status of your laptop battery itself. There should be a battery indicator on the laptop that is connected to the battery. This indicator is either on the bottom of the laptop or (likely) on the side. If there is no indicator, your battery itself may be the problem, and may require replacing. Keep in mind that older batteries of the nickel-cadmium variety are more likely to decharge over time and forget their initial maximum charge level; this may be a particular issue to users of older laptops.
4. Find a VGA connector and hook up your laptop to an external monitor if the above steps have not alleviated the blank-screen problem. Turn on the computer and the external monitor. Does the external monitor light up? If so, the blank screen is likely due to a video subset problem/LCD problem in your laptop.
5. Consider that a deeper problem may exist if the external monitor did not light up This problem may lie in the motherboard. In this case, taking the laptop to a professional repairman or sending it off to the manufacturer is recommended.
I hope you find it very helpful. Best regards from fixya
Aug 15, 2011 | Dell OptiPlex SX270 PC Desktop
How can i fix my laptop black screen? I can hear it coming on, but no image on the screen.
Instructions Things You'll Need:
  • AC adapter
  1. 1 Check the power source. While you have presumably already attempted to turn your laptop on and off, the problem may lie with your AC power adapter. Is the power-indicator light on the adapter on? If not, your problem may lie here. However, whether or not you have a power indicator light on your adapter, consider unplugging it and plugging it into another outlet. This may turn on your laptop and take care of your blank-screen problem.
  2. 2 Check your brightness settings. While it seems like a simple oversight, the brightness on your laptop may sometimes be turned all the way down. Thus, the screen appears to be black, off or defective, when the problem is simply that the brightness is on its lowest setting. To fix the brightness, check your laptop keyboard. Most laptops have the brightness settings mapped to two keys at the top left of the keyboard, accompanied by a symbol (often a sun). Use these keys to fix your brightness, but keep in mind that some laptops require that you press the Function key at the same time as the Brightness key.
  3. 3 Check the status of your laptop battery itself. There should be a battery indicator on the laptop that is connected to the battery. This indicator is either on the bottom of the laptop or (likely) on the side. If there is no indicator, your battery itself may be the problem, and may require replacing. Keep in mind that older batteries of the nickel-cadmium variety are more likely to decharge over time and forget their initial maximum charge level; this may be a particular issue to users of older laptops.
  4. 4 Find a VGA connector and hook up your laptop to an external monitor if the above steps have not alleviated the blank-screen problem. Turn on the computer and the external monitor. Does the external monitor light up? If so, the blank screen is likely due to a video subset problem/LCD problem in your laptop.
Oct 04, 2010 | Computers & Internet
Problem regarding blank and black screen of acer notebook
Try to drain first the static of your motherboard.
Take out the battery and unplug the adapter
Press and hold the power button for 30 secs
Put the battery back in including the adapter
Power on the computer
Issue is not resolved. There is a huge possibility that there is a problem with your LCD.
May 19, 2010 | Computers & Internet
BLANK SCREEN ON MY hp compaq nx9420. my laptop was working fine and then when restarted I got a blank screen. The power LED and cahrging LED both light up but screen remains blank. have changed the video...
Did it display any video at all with boot options or HP logo? Any POST test or beeps after you started the laptop?
Try removing the power ac adapter and battery. then only boot it up with just the AC adapter (no battery).
Good Luck, JAJ
Mar 30, 2010 | HP Compaq nx9420 Notebook
Blank screen, error code;0f00c.
The error you appear to be getting during diagnostics should not be related to the computer not starting. The error you are referencing has to do with a blank CD not being in the CD/DVD drive during that part of the test.
I ran the diagnostics again with a blank cd in the drive and I recieved error code 1000-0146.
Mar 12, 2010 | Dell Dimension 3000 PC Desktop
Flashing light, blank screen, no fans
I'll assume the computer is not in standby mode in which case the problem is most likely a power supply that has given up.
Dec 17, 2009 | Compaq Computers & Internet
Blank screen
You need to power drain
step1. remove battery and ac adapter for your laptop
step2. HoLD POWER BUTTON for 30secs-1mint
step3. put back battery and ac adapter
step4. power on it sud boot normally
try this hope it helps you
Feb 25, 2009 | HP Pavilion dv6000z Notebook
Turn on Laptop gets to desktop with icons then screen goes blank
By "where I want to go", do you mean going on the internet? If all you are getting is a blank screen, then you have the "about:blank" virus. Go here, print out the instructions, and read them well. Then read them again and follow them closely. At one time I had it on a desktop system and the instructions worked just fine.
Dec 10, 2008 | HP Compaq nx7010 Notebook
Blank screen
do a power reset on the computer. turn off the computer. remove the battery pack and unplug the ac adapter. press and hold the power button for 10 secs without any power source to drain all excess power in the laptop. put in the battery first followed by the ac adapter. turn the computer.
i hope this helps.
Sep 12, 2008 | Toshiba Satellite A205-S4617 Notebook
Compaq Presario Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
