Question about Cell Phones
Not enough time to answer my phone before it goes to missed call
My cell phone is great but does not give me enough time to answer it.
  • jane2justine Jun 21, 2008
    This was really helpful.Thany you
    President:
  • 169 Answers
It may be set to divert calls to voicemail as a set delay.
This can be corrected.
Dail
##002#
Press the call button.
Should then display - "Requesting..."
Then Display - "Divert Cancelled"
Hope this works, best of luck.
Regards,
Abdul Qayyum
Posted on Jun 21, 2008
  • Abdul Qayyum
    Abdul Qayyum Jun 21, 2008
    Please do not forget to vote! Thanks!
My phone goes to no network coverage area message without network bar in phone.I had reset to factory settings but its not resolved
there is not enough info to answer this question. is it att/tmob? or is it verizon/sprint? are you in a low signal area? are other people with the same service missing service too? have you recently changed your network settings? if you can answer this for me i can almost certainly tell you whats wrong. TIA
Nov 25, 2015 | Samsung Galaxy Note 2
Any calls I get ring only two times (not enough time to answer it) Can I change this?
Call your carrier. They can adjust the default rings before it goes to voucemail
Nov 26, 2014 | Cell Phones
Our phone only rings 4 times before it goes to voicemail.
Depending on your phone ,but you should be able to adjust it in your setting and that is in your phone menue
Apr 24, 2012 | Samsung Prostar DCS-24B-LCD Corded Phone
Hi, My Parrothead 250 worked great for the first month. Most bluetooth are not loud enough in my Peterbilt to hear. Now it wont connect to my HTC Evo cell phone. I did get it to connect, but...
some configuration missing at the time of connection sholud be connection proper or not check it battery also and media and then restart the phone switch off the and on
Sep 23, 2011 | VXI Corporation Blueparrott B250-XT...
Rings twice then goes straight to missed call had this phone for a couple of years no problems until lately i have not altered anything but last few days it only rings twice before going to missed call i...
Try removing the battery from the phone for 10 seconds and after that restart the phone. If the problem persists then ask an expert to help restore
Jun 05, 2010 | Motorola Mobility RAZR V3
When my 8110 rings it only rings 4 times and I keep missing calls because I cant answer it quick enough. How can I change the length of time it rings for,thanks,Bill
select your profiles which is the little loudspeaker icon. scroll all the way to the bottom you should see advanced. select advanced, selcet your profile that is labeled as active. you will then be able to customize the entire profile.
Dec 14, 2009 | RIM Blackberry 8110 Cellular Phone
I have a Uniden 5.8GHz DSS8955+1 and it's connected to my phone and fax. The problem is: everytime the fax rings, the answer machine works as it works when is a phone call. How do I set up the machine not...
Set your answering machine to pick up after four rings2.gif . This will give the fax machine enough time to take the call if it senses that it's an incoming fax. Setting the answering machine to pick up after four rings would give the fax machine enough time to accept the fax.
hope this was helpful .
Nov 13, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
HTC - P3470 - Phone intermittently not receiving calls
hi you might have your phone set to call diverts or answer machine its worth a look at
Jun 12, 2009 | HTC P3470 Cellular Phone
My cell phone has no network connection
Try this: turn off the phone & let it charge for 48hours, that will give it enough time for the electricity to dry out the internal circuitry in the phone and possibly fix your internal antennae problem...if that doesn't work then your phone's tea bath may have shorted the antennae.
Jan 02, 2009 | Motorola Mobility RAZR V3
Cell Phones Logo
197 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
