Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
The solution in our bissell carpet shampooer will not come out what can we do?
  • Anonymous Jul 09, 2008
    UNIT HAS NOT WORKED SINCE PURCHASED IN MAY...I SHOULD HAVE STAYED WITH MY HOOVER UNIT. IT LASTED ME 8 YEARS OF CONTINUAL STEAM CLEANING. I HAVE DESTROYED THE BOX AND HAVE MISPLACED THE RECEIPT.
    I WOULD BE ON MY WAY BACK TO THE STORE WITH THIS OVER PRICE PIECE OF JUNK!
    CHICAGO
  • mwilems1 Jul 26, 2008
    I have looked at my Bissell 9400. There are 3 flow meters or valves; not sure which. Some how it seems to sense when the detergent solution is empty and shuts off flow. I think this may be the problem. Fluid does not come out from either the floor nozzles nor the hand unit. Is there any way to be more specific? Does anyone have a schematic so I could troubleshoot?
    President:
  • 1,673 Answers
• tanks are not sealed into receivers
• faulty auto load receiver
• pinched/clogged line
• defective component allowing air into system
• pump not mounted so it can move freely
• defective bridge rectifier
• clogged heater
• defective pump
• defective circuit board
* spray nozzles are clogged
Posted on Jun 21, 2008
My bissell proheat 2x dual dirtlifter is not succioning very well then the carpet smells
We have several parts here for the Proheat 2X,
Proheat 2X Shampooer Shampooer Parts
It may be a clog in your tank, preventing the water being sucked back up. Check your tank and tubes for clogs or damage. Make sure the brush is still rotating and the belt is not broken too.
800-775-6586
GoodVac com
Feb 26, 2015 | Bissell 2X Proheat 9200 rug cleaner
No instruction manual for bissel powerlifter carpet shampooer
go to this link:
http://www.bissell.com/customer-support/
there is a spot to put your model number in and you can download the owners manual. Good luck! Regards, Ross
Sep 12, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
My bissell proheat rug shampooer wont wet carpet at all
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
gfhjdhg
Jun 26, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Using Bissel proheat carpet shampooer. Have used
No, you don't dilute it. And yes, it does use a lot of formula!
Apr 27, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell carpet shampooer priblem
Something is probably clogging up the suction.
Try to snake it out with a coat hanger or similar tool.
Often, especially with shedding pets hair will clog the suction pipes.
Jan 17, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel shampooer
yes there is a belt on the side that will need to be changed
Jan 13, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell carpet shampooer wont dispense water
Bad Pump. You pump is where the belt attaches to spin the brushes and also puts water on the floor. Take it to you local Best Buy to be serviced or a local appliance shop which may service it.
Dec 15, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
Power Pro Bissell cleaner
Try going a diferent direction. Burber carpet is extreamly hard to clean because the nap it causes vacuums to bounce and shampooers to catch. just try using a differnt angle to shampoo the carpet from.
Oct 13, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Carpet shampooer
I couldn't find the exact guide for your model but the two links below are the ones bissell told me to use. http://www.bissell.com/images/UserGuides/1694-8806_607.pdf http://www.bissell.com/images/UserGuides/1697_1205.pdf I hope this helps:)
Jul 15, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
123 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
