Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
How to unclog i guess
It spit the water out but don't **** it back up
    President:
  • 1,673 Answers
If this has a foam filter on the bottom side of the recovery tank lid, make sure there is at least a 1/4 in. gap from the top. Also check the filter from the bottom, it has a red frame, clean it off it covered over. The other thing that will cause this is that the lid for the recovery tank is not locked down all of the way around.
Posted on Jun 21, 2008
Unclog steamer so it will suck water?
To unclog any sort of water clog mix white vinegar 1/3 cup, with 2/3 cups of water, Than pour mixture into suction opening and let lie for about 5 minutes.
May 15, 2014 | Dirt Devil CE7000 Easy Steamer Upright...
Vacuum won't turn on
Be sure to that the latches are connected to the water pan. The eSERIES and up will not turn on without the water pan latched. If that is not the issue, please call us and speak to a Rainbow Specialist.
RainVac
www.rainvac.com
800-523-0510
Oct 17, 2012 | Rainbow E series Canister Wet/Dry Vacuum
My dirt devil purpose for pets vacuum is picking up anything and pushes everything around.
sounds like you have a blockage in the pipe behind the brushbar take off pipe and unclog the link below is the manual
http://dirtdevil.com/file/295/
Aug 22, 2012 | Vacuums
Kenmore canister. Brush is turning but spitting all dirt under and out the back of the head. I guess the suction is very weak or non at all. What is reseting overload protector doesn't work. Haven't tried...
i would look to see if there is a clog. that would be the only reason that the power head would be spitting dirt in back of the power head. check the hose.
Oct 13, 2009 | Kenmore Vacuums
Hose that releases the water and cleaner on my Hoover is clogged
Your right the hose is clogged.. Use a portable vacuum to blow the dirt inside the hose.
Jul 24, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Shop vac sucks water for a few seconds then it spits it back out
Don't use the paper filter for sucking water. It can ruin it. It will still be usable if you just set it out to dry but there is no reason to use it for water in my experience. I have a sears shop vac and it will fill up more than half full without ejecting the water.
Dec 22, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Bissell Spot Lifter
ok - this works even though it probably isn't the "best" solution. Unclog the input and output nozzle ares with a pin. The input area (behind the solution) was my clog problem - I put 2 or 3 drops of CLR into the hole, waited 5 minutes, then primed the trigger. This unclogged it! Fill the tank with a 1:1 ratio of white vinegar and warm water. Insert tank into unit and spray out the contents into the sink. This will eliminate any leftover CLR residue and clean the nozzle thoroughly. For the intake (suction part of the tank) I just rinsed through the lines with the vinegar mix and it seemed to unclog the rest. These things are a pain to take apart and if you break any pieces you'll be stuck - replacement parts have been discontinued for older models.
Feb 29, 2008 | Bissell 1715-G Spotlifter Bagless Handheld...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
130 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
