Question about Toyotomi TID-2400 Air Conditioner
No Condensed Water Coming Out From the Unit
I used my Toyotomi TID-2400 last night for about 7 hours and when I woke Up
this morning to remove the drain tank I noticed that the drain tank is empty.
I look around and but I can't find any water spilled around the place where I put the unit.
Also I noticed last night, that the unit will switch sometimes to fan only. Is it
natural for the unit to switch from fan to cool. I just noticed it last night. Ihave the unit since 2002 but I seldom use it.
Your help regarding this matter is greatly appreciated.
Thanks a lot.
2 Suggested Answers
SOURCE: The "tank full" light flashing
Dear-heart, the tank should be EMPTY...when it's full the machine shuts off to keep from over flowing.
Dump the water out and try again. The "flashing light" is to tell you the tank is full of condensate water and needs to be emptied.
In hot, humid climes this will happen often. Many models can be hosed for continuous operation.
Good luck
Anakron
Posted on Jun 23, 2009
How do I recharge freon on a toyotomi TID 1800 unit?
You can't. You have to be licensed to use and dispense refrigerant gasses. 'Freon' went out years ago. Look in Yellow Pages for someone local.
Oct 10, 2016 | Toyotomi TID-1800 Air Conditioner
After washing engine on 2006 mustang gt codes p2104 p2111
P2104 is your throttle actuator. Probably wet the sensor. Try drying out with a hair dryer. P2111 is also a throttle code. Overnight the water has condensed and is affecting throttle position sensor.
Oct 25, 2017 | Ford Cars & Trucks
My 1800 will put out ac and then will go off
Check an error code displayed?
If unit stops immediately after you switch on, fan motor mechanism locked. Check motor and PCB.
If unit stops after few seconds, check coil and room air sensor and replace if it's defective.Helpful?
Jan 19, 2011 | Toyotomi TID-1800 Air Conditioner
Btu of Dimplex Dac 3400/Toyotomi TID-1200 please
It is a 3400BTU unit--Checked from my own unit.
Cheers,
Tony
Sep 09, 2010 | Toyotomi TID-1200 Air Conditioner
Diminished capacity. Have had it on high for over
You probably have a dirty coil... this is the most common problem with inefficiently operating units.
do you change your filter or clean it often? how old is the unit? do you smoke inside that room? are there any animals that live in there? how clean is the room on a scale of 1 to 10.
Oct 10, 2009 | Toyotomi TID-1800 Air Conditioner
Lost Power
Replace the thermal fuse inside the control panel.
Part #3376359
Mar 11, 2009 | Whirlpool DU960PW Dishwasher
Smells like gas
anytime you smell gas turn off the gas at source quickly.
Dec 22, 2008 | Toyotomi TID-1800HP Air Conditioner
You can find a user manual at http://www.toyotomiusa.com/products/manuals/TID-2400%20(Type%20A,%20B)%20-%2020456095%20-%20Multi%20Lingual.pdf
Jun 08, 2008 | Toyotomi TID-2400 Air Conditioner
Toyotomi TID-2400 Air Conditioner Logo
Top Toyotomi Heating & Cooling Experts
hmca
Level 1 Expert
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Toyotomi Heating and Cooling Expert? Answer questions, earn points and help others
