when we do popcorn in our Magic chef the oven shuts down
automaticlly for about 10-15 mins then it resets and comes back on,this only happens with popcorn.
-   I have the same problem with an Over the stove unit bought less than 2 weeks ago. Magic Chef customer service said they do not have a service center in my area (Owen Sound, Ontario) and that I should cut off the plug and mail it to them and they will give a refund !!!!! GREAT SERVICE NOT !!
-   Guest
You are running the risk of damaging the Magnatron by doing this.
Check the packets you are using, you will have to reduce your power output.
This is because microwaves act by being absorbed by water. There is very little in popcorn and in fat. Once this has been evaporated, the microwave energy builds up (as it is still being produced - but not absorbed), and ends up cooking the magnatron itself.
I have seen countless posts on here after cooking popcorn!
More fun on the hob anyway - and cheaper to buy in bulk!
I've been having the same problem with our magic chef over-the-stove microwave. Every time I cook popcorn it shuts down like you said for 10-15 minutes then beeps and comes back on. I thought it was the popcorn button so I tried again just with normal cook time and same problem. Richie's answer seems to make sense but I'm not sure how to check the packets and reduce the power output. Will this slow down the rest of my microwaving?
My MCD1311st 1100 that i purched at Home Depot a couple of mounths ago worked find until last night...
(More)
My MCD1311st 1100 that i purched at Home Depot a couple of mounths ago worked find until last night , look to see what time it was and there was not on ,Ichecked the power and pluged it in to another outlet and still it did not come on NOW WHAT
I have a Magic Chef MCD1311ST and it will not cook what we put in it but, the outer walls become hot...
(More)
I have a Magic Chef MCD1311ST and it will not cook what we put in it but, the outer walls become hot to the touch. However, the inside is still cold. The food only gets slightly warm after about 30 minutes of trying.Can not even boil water. Worked fine when I cooked baked potatoes went to do a second batch and finis.
