Question about Techko SH1524CP Shredder
Power light on
Ive got power but there is no movement when i put a peace of paper in i hear the paper sensor click and when i pull it out the sensor resets but nothing happins on auto or forward or reverse
    Sergeant:
    Champion:
  • 285 Answers
The motor could be fryed , these are hard to get for replacement depending on the model and price.
Posted on Jun 21, 2008
I had a paper jam , now i have a loud clicking noise left , red light screen says door open . ive checked all doors taken toner out and put back in removed paper drawer and replaced still nothing
THE LOAD CLICKING NOISE COULD BE THE CARRAGE JUMPING IN AND OUT, DUE TO THE CARRIAGE BEING JAMMED,SWITCH OFF POWER AND TRY MOVING CARRAGE ALONG SLIDE, REASON FOR THIS ANSWER IT HAPEND TO MY PRINTER AND I CLEARED IT BUY DOING AS ABOVE
GOOD LUCK
Sep 22, 2016 | Samsung ML-1910/SEE ML-1910 Mono A4 Laser...
Tip
Use this method with your own risk!! E2-2 = No paper (ASF) E3-3 = Paper jam E4 =...
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full for Mp140
turn off printer.
- press and hold your finger at on/off with reset/stop button together
- turn on printer power switch
- release the button on / off, but at the same time continue to press the stop / reset and then press the button on / off again and continued to hold the two buttons.
- wait a moment
- relese stop/reset button 2X.( you will see the led light blinks twice when you press the stop / reset twice)
- release on/off button.
wait until the screen on the printer control panal shows the number 0.
- after printer panel screen shows number 0.
- press stop/reset button 4x
- press on/off button 1x
- wait until you hear the movement of your printer roller
- when you hear the movement of the roller your printer, wait a while until you do not hear any sound of movement in your printer. :)
- turn off and turn on printer again and your will see your printer back to normal.
Ok world...Good luck
------>>>Download guide to fix waste ink overflow ip1000 Click Here
on Jul 21, 2010 | Computers & Internet
Black n& DEcker paper shredder CC600 will not turn on
Check if there is power from the outlet. Check the cabling. Then do a check on the shredder to see nothing is blocking the free movement of the "knives " then check if all sensors are engaged. Not closing the shredder 100% ant the not closed sensor will prevent the motor to run. See and here if the paper in sensor is in tact and clicking when putting in paper. Needless to say, you better unplug the shredder when you open it to check.
Apr 18, 2015 | Black & Decker CC600 Shredders
My epson xp-312 will not print on photo paper.it keeps saying paper jam.how can i load when the back tray only allows one sheet of normal paper?
When a printer indicated paper jam, it means one of its sensors does not indicate a movement of paper, where it expects it. In only rare occasions the sensor is defect, but most of the time here is really a jam. This must not be a complete sheet of paper. Can be a little scrap left somewhere in the printer. Sometimes a paperclip fell in or just a paper tray was not put in place. Please open the printer and look careful using a flash light, to see if you can find anything that does not belong in the printer. Then switch it off and really unplug it for a few seconds. Reinsert the plug and switch on. If the error keeps coming back you should call a service centre, although ig you have to send it in for repairs, a new printer is probably cheaper, unless it is still under warranty.
Jan 13, 2015 | Epson Office Equipment & Supplies
DISPLAY BUSSY
Remove printer covers, put small peace of papers in door sensor & cartridge sensor,plug in power see where carriage stuck? Might be carriage stuck in service station,disconnect power, rotate manually service station gears for un locking the carriage assm.Once carriage unlocks check why it's stuck? Is there any paper partials jammed in side or service station movement obstructed by waste ink.. Remove service station clean with forced water, allow it to dry, apply silicon grease for smooth movement, fix it back.. test it..I hope this exercise will resolves you issue.. but its too dirty work,...
Jul 20, 2012 | HP Designjet 110plus nr InkJet Printer
The power light is on but the unit will not move forward or backwards. It just stopped working. I clean everything with a shop vac. When paper is initially installed you hear a click but no movement of the...
If the shredder won't move in either direction,it's usually a sign of a jam. Unplug the unit, turn the head upside down and with a small knife, flathead screwdriver, or tweezers, dig the remaining scraps of paper from the teeth. It's time consuming but eventually, there should be more pieces from underneath the head that are the actual cause of the jam. If when all (or almost all) of the paper is removed the shredder motor still won't engage, then in all liklihood the motor is dead. I hope this answers your question.
Greg
Nov 23, 2009 | Audio Players & Recorders
Shredder will not
Andrew,
You have done all the right troubleshooting.
I would say the circuit board is toast.
Sep 17, 2009 | Office Depot Ativa DQ60M Shredder
My canon M 160 jammed, I pulled paper thru, now it won't print
E2 is "NO PAPER" error but in most case it's showing when the paper feed is in incorrect position.Check it movement correctly and check for any objects drop in printer.
Jun 14, 2009 | Canon PIXMA MP160 All-In-One Printer
Status light is red and paper light blinking
Alex,
To isolate the problem, please try the steps below:
Remove and re-insert the paper tray and then click Go.
Take the drum unit out of the machine and put it back in.
Here, I provided you a link that might help you:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000070/faq000170_007.html?reg=us&c=us&lang=en&prod=hl5250dn_all
Have a great day!
May 07, 2009 | Brother HL 5250DN Laser Printer
LQ-2180 printer is Continues blinking front panel lights.
The LQ2180 blinking lights can be caused by paper jammed, printhead overheated, paper loaded not detected and cover unclosed. Try to check all this first, you may have a fragment of paper stick to the sensors, or broken sensor. If all of the light flashing try to check the carriage movement, move it side to side, but with power off condition. If the carriage movement not smooth or stuck, look for any foreign matters inside the carriage path that blocking the movement if not, try to lubricate the rail which hold the carriage. If this doesnt solve you, the machine require parts replacement.
Apr 14, 2008 | Epson LQ-2180 Dot Matrix Printer
Techko SH1524CP Shredder Logo
218 people viewed this question
Top Techko Office Equipment & Supplies Experts
Randy Schumann
Randy Schumann
Anita Nystad
casper muchato
Level 1 Expert
Are you a Techko Office Equipment and Supply Expert? Answer questions, earn points and help others
