The unit has no power when pluged in it must have a blown fuse as i said before how do i replace it
  • diamonddan11 Jun 24, 2008
    thanks mate very good information thanks for going the extra yard u have been very helpful
  • 1,512 Answers
Hi diamonddan11
I have posted to your original request for help the details of this. here is a sumary
  1. mains power fuse FU11 is located INSIDE the deck on the same circuit board and the mains on off switch.
  2. There is a thermal fuse that is not changeable inside the widnings of the transformer. This is can be repaired but generally it is considered that you replace the transformer
  3. on the printed circuit board attached to the secondary side of the transformer you will find 5-6 pico fuses, or circuit protectors. The are small black 2 pin devices that are marked on the board as IC901 to IC905
  4. the main power regulator board REGB ASSLY also has a circuit protector IC911.
  5. Thjere are several others in power supply areas marked as IC907, 908, 909, 910, 913, 914.
OK, thats a run down of the fuses in the unit. Non are considered to be user replaceable parts. If the deck has had the wrong mains voltage applied, it is likely that it has blown the primary fuse, FU11. If you do replace that fuse, and the unit still does not work, the transformer may be blown, or any one or combination of the Circuit protector type soldered in fuses may need to be replaced also. If you cannot follow what I have given you here, I suggest you take it to a Pioneer Authorised Service Center.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jun 22, 2008
  • Graeme Ross
    Graeme Ross Jun 24, 2008
    No worries mate,I posted this into the Premium post, no chance of rewarding me with a FixYa there too hey:) Cheers
    Problem Solver:
  • 17 Answers
Try to check the regulator nearest
Posted on Jul 02, 2009
Burner will not start up. Pilot light is good. Filters are clean etc. ??
Make sure there is power to the unit. Turn the fan to the on position if it doesn't come on there is a lack of power there could be a control circut board in the bottom half of the furnace pluged into it somewhere there is a fuse like what goes in a ca pull it out and replace if blown no more than a 5 amp
Jun 21, 2011 | Heating & Cooling
When the unit is pluged in an the power switch is on there is no power to the unit. Anyone help?
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 15, 2010 | Samsung SyncMaster 245BW Monitor
DVD PLAYER DIED ALL OF A SUDDEN. NO LIGHTS,NO POWER, NO SOUND. NOTHING. UNIT IS PLUGED IN AND WORKED FINE YESTERDAY.
Your probably got a blown fuse, You might want to unplug it pop off the cover and check the fuse. if its blown carefully take it out and bring it down to radio shack for a replacment.
hope that helps you out please to forget to rate.
Apr 05, 2010 | GoVideo D2730 DVD Player
WHEN THE UNIT IS PLUGED IN AN THE POWER SWITCH IS ON THERE IS NO POWER TO THE UNIT. ANYONE HELP?
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside for blown main AC fuse first, see example of failed SAMSUNG monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 29, 2010 | Samsung SyncMaster 245BW Monitor
No power, system is 4 years old. un pluged system and moved to another plug but still no power
You can open up the unit and check the fuses. Replace them if they are blown. If there not blown then there could be loose wiring. If there is alot of dust build up, take care of it with some dust off.
Jan 17, 2010 | JVC TH-C50 System
On pluging on the main AC pluf, there is not
do you have the cord plugged into the computer? is there a switch on the back near the power supply? if so, is it on? is the large connector from the power supply tightly latched to the mother board? (unplug the computer before you check this!) any fans running? plug a lamp into the outlet and see if it has power! could be a popped breaker, or blown fuse.if you feel confident of your skill, remove the power supply, open it up and see if it has a fuse that may be blown. if so, replace it with a fuse of the same type (size & amperage). if the fuse was blown, and you re-install the power supply and it blows again, then you have a problem (probably) with the power supply, and if cost effective, it needs replacing! get a compatible power supply with a higher power rating, if you can! more power for your peripherals!
good luck!
Sep 28, 2009 | Compaq Evo D510 Minitower (Open Box)...
Recently i had a power surge and my copier machine was pluged up now it does not come on or work
Sounds as though a fuse has blown. Unfortunately, this will be inside the unit to protect the power supply and other electronics.
Sep 10, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Front red light comes on when pluged in, but no power the the tv
be sure all units are auto volt. if you plug units 110V to 220V it might be damage or fuse will blown up.
Jun 28, 2009 | Toshiba 23HLV85 Television
Ilp iwt3206 32" sdtv
Next best guess is the larger filter capacitors in the power supply are bad and shorted out, you can check with an ohm meter across capacitor leads (with power unplugged)
Apr 21, 2008 | iLO 3200 32 in. LCD Television
Power problem.
1. Make sure the AC outlet is good.
2. Make sure there is no damage to the AC line cord.
3. Look to see if there is a fuse at the rear of the unit. It's usually located inside a black circular housing with a screw off cap that says "fuse".
If not, unplug the unit and remove the outside cover. Look for a blown fuse on the motherboard or power supply. Replace it with the EXACT value of the original fuse. You can purchase a new fuse at Radio Shack or hardware store or auto parts store. Try powering up the unit again and see if it works now or whether the fuse blows again. If it blows again, the power supply may have been damaged.
Please let me know if I can be of further assistance to you.
- Jim
Mar 20, 2008 | RCA DRC8320 DVD Recorder/VCR
174 people viewed this question
 Grubhead
Grubhead
