Question about GE Â 17.9 Cu. Ft. Top-Freezer Refrigerator
Top freezer ice maker not putting out ice
When ice maker is turned on the green light appears. Shortly after the light turns to a blinking yellow and no ice is produced. What could the problem be?
We shut down the freezer for 12 hours and the ice melted in the pipe. Thanks
Posted on Jun 22, 2008
Fim120 flashing green light
is there any pause in the blinking light if so count the blinks and the pause and the seconds blinks this will tell you the error code
Dec 11, 2013 | Franklin Chef 120lb. Ice Maker FIM120
Ice maker not working on GE side by side
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iyooyi76
Jun 01, 2010 | GE GSL25JFPBS Side by Side Refrigerator
57029 Side by Side Refrigerator: ice maker not making ice and red light inside the ...
Your ice maker may be turned off. The blinking light is the sensor. The switch is right beside it. Is it in the on position?
May 16, 2010 | Kenmore 57029 Side by Side Refrigerator
GE Monogram icemaker is not working. The green light on the ice maker is blinking every second. I turn the ice maker off then turn on after a few second. The light stays green. After 10 minutes, I...
Your model uses a electronic ice maker. If the tray has srinking cubes and if you fill to top with tap water, let freeze and if it does not drop the ice the problem most ikely is the icemaker mode=> WR30X10093 The ice maker has a thermistor or thermostat built in and communicates with the circuit board inside to tell when it is time to cycle. You can try the water test and let me know but this is a typical failure with that type of ice maker. If this solve you ice maker problem please rate me. If not explain what you tried and we will try the second test. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Feb 11, 2010 | GE Monogram ZISS480DRSS Stainless Steel
Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Nov 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker flooded top freezer compartment
It may be just the water control valve on back of refrigerator. Put tap water in ice maker and lower lever for on. After ice is made, does it drop to tray? At this time when empty is the time the control valve is asked for water. The problem could be in valve on back or the inside ice maker itself. If you can try a few test with me I will help you locate the problem. Let me know what you find as I go through this with you. Sea Breeze
http://servicepartstec.blogspot.com/
May 19, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
General electic gsh25jfta bb
According to the manual for your refrigerator:
Blinking green light indicates an ice cube is stuck in the icemaker. To fix - Turn off the ice maker with the on/off switch. Then remove all of the ice from the icemaker by hand and turn it back on.
I hope this helps.
Jul 19, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Daewoo refrigerator water filter red light still on after replacing the filter
Press and hold "ICE MAKER LOCK" button, and while holding it shortly press "LOCK" button, and the light will change to green LED.
Ivan
Oct 08, 2007 | Refrigerators
GE Â 17.9 Cu. Ft. Top-Freezer Refrigerator Logo
105 people viewed this question
Top Refrigerators Experts
Gere knutson
KJ4QOB
Alan Moore
Level 1 Expert
