Question about Philips 43P8341 43" Rear Projection Television
Very odd problem
No Audio... will not completely. If i press the vol button "up or down" i can get sound, but as soon as i let go of the button no audio. Same with the channel button. Also should the video button on the front of the TV turn the TV of and on?
  • 2 more comments
  • Shawn Philbert Jun 21, 2008
    shawnp@tampabay.rr.com
  • Shawn Philbert Jun 22, 2008
    Yes the video is fine just an audio problem
  • Anonymous Aug 29, 2008
    i have tv no sound
  • Edward
    Edward May 11, 2010
    Do you have video?
    Do you have any audio?
    Is the green power light on?
    Ed
  • Philips Master
  • 3,459 Answers
Sounds like the opto ic chip has failed. If so www.magnavoxhelp.com has a kit that will fix this common problem.
Posted on Jul 04, 2008
  • Philips Master
  • 8,617 Answers
Sounds like you need the front keyboard PCB. You can get one frome the following link. They dont have them listed but if you leave them an email they will send you a response. Bought one three weeks ago they are 25.00 with free shipping.
http://servicemanuals.vstore.ca/
Posted on Jun 21, 2008
How Can I reset after too many pattern attempts?
OK to my understanding you forgot your pattern and can't get in your android phone. No problem
The following procedure will erase everything from the phones memory this cannot be undone.
Now that that's out of the way... Power off your device. Then hold vol down and the power button it should take you to factory mode use the vol down button to navigate to factory. Reset press the power button to select it and soon it will be done navigate to reboot phone using the vol down button (touch dont work in recovery) and select it with the power button and your phone will be as if you just took it out of the box. If by chance everything is in chinese in factory mode remove the battery and press thw power button and hold it down then press the vol up button right after. You will see a black screen with three things recovery fastboot and normal use the voo up to navigate to recovery press vol down to select itif you see no words and an android robot with an exclamation mark press the power button you should see words use vol down to navigate to wipe date/factory reset and select with vol upove to yes -- delete all user data and press vol up wait until finished go to reboot system now and select using vol up and enjoy ur brand mow phone :)
Dec 31, 2015 | Cell Phones
Very odd problem
It is a fault with the control board or with panel.
Aug 24, 2008 | Philips 43P8341 43" Rear Projection...
DNX7120 issue with VOL increase button. When this button is pressed once, the volume skyrockets to max, VOL decrease button does not work right away to lower the volume, nor does the ATT button. Unit...
I had the same issue. You can use the on screen volume buttons on screen to stop issue and don't use the physical buttons anymore. Watch out about a month after the volume problem started all physical buttons on my DXN7120 stopped working. There are a few reports of this online, I have not found a fix yet.
Dec 15, 2010 | Kenwood DNX7120 Car GPS Receiver
Looking for remote codes for vizio sound bar and comcast remote
After much research, here is a step-by-step for getting your Vizio Soundbar to work with the Comcast remote using EFC codes (mine is the newer charcoal grey one, works great!)
Aux - Setup (2 blinks) - 11144 (2 blinks)Aux - Setup (2 blinks) - 994 - Setup - 00169 - Vol Up - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00168 - Vol Down - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00037 - Mute - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00165 - Power - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00164 - Input - Should get 2 blinks
These are optional, I didn't use them:Aux - Setup (2 blinks) - 994 - Setup - 00036 - <button to use for TVOL> - Should get 2 blinksAux - Setup (2 blinks) - 994 - Setup - 00101 - <button to use for TSHD> - Should get 2 blinks
Then set the volume control on the remote and other settings according to the Remote's manual.
ENJOY!! Hope this helps someone...
Aug 28, 2010 | Vizio High Definition Sound Bar
Parental lock code has been lost how can i unlock and reset code
Without a model number I'll have to list several solutions.
Push Vol Down and Chan Up on the set at the same time, Then go to password screen and enter 0000.
Reduce Vol to minimum and hold Vol Down on set and Vol Down on remote.
Hold Vol Down on TV while pushing "TV" button on remote for 3 seconds.
With TV OFF, press and hold Vol Down on TV and "Clear" on remote for five (5) seconds.
Press "Menu" button on TV and "TV" button on remote for 3 seconds.
Some models use the Vol Down button on remote instead of "TV" button on remote.
With Remote go to Parental Menu and enter 2211 for code.
Go to parental Menu and press Mute, Display, Clear, Reset in sequence on the Remote.
Press "Menu" button on the set and Vol Down on Remote for 3 to 5 seconds.
With remote go to parental screen and press Chan Up and Vol Up on the front of set for 3 to 5 seconds.
Jun 05, 2010 | RCA DRD485RG DirecTV DTV Receiver
I have a yamaha receiver. Zone 2 is not playing any sound. When I go to adjust the volume it says "zone 2 volume fix". I saw these directions below on your website to help solve this problem. However,...
Hi
could you send me the model of your yamaha.
Please use the add a comment link, as if you accept the solution I will no longer be able to respond to you.
Thanks
Jun 20, 2009 | Audio Players & Recorders
Zone 2 issues
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there
Aug 03, 2008 | Yamaha RX-V659 Receiver
Volume fix problem
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there Good Luck! This worked for me.
Aug 02, 2008 | Yamaha RX-V659 Receiver
No zone 2 sound coming from yamaha amp rx-v861
We had the same problem - I think it was reset when the power went off in a storm. Went to Yamaha website (http://www.yamaha.com/yec/faq/faqdetail.html?CNTID=206010&CTID=5009135) and found the following worked:
Assigning the receivers internal amp for Zone 2:
  1. Set the remote control [SIDE SELECTOR SWITCH] to [AMP]. (Located to the right of the volume buttons on the Remote).
  2. Press the [SET MENU] button on the remote control.
  3. Arrow down to Manual Setup and press the [ENTER] button on the remote control.
  4. Arrow to the Sound Menu option and press the [ENTER] button on the remote control.
  5. Arrow to Speaker Set and press the [ENTER] button on the remote control.
  6. Arrow to the EXTRA SP ASSIGN and select ZONE2
  7. Press the [RETURN] button on the remote control to exit out and return to the Manual Setup.
Feb 16, 2008 | Yamaha RX-V661 Receiver
Zone 2 Vol Fix
Try this:
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there Hope it helps. It worked for us.
Jan 19, 2008 | Yamaha RX-V657 Receiver
Philips 43P8341 43" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
