Question about Mitsubishi WS-65413 65" Rear Projection Television
How do I put it to 1080 resolution
I noticed that my T.V. has been in 480 resolution, and cant figure out how to change it to 1080. I have a play station 3 and some blue ray disc's and would like to get maximum resolution. Also dont have the remote or owners manual, the ex- wife probably threw them away...
Thanks,
Jim M
I have this same TV and a PS3. You either need to get a HDMI - DVI cable, or plug in some component cables in order to get 1080i from your PS3. Your DVD's will upscale to 1080i and your Blue_Rays will run at 1080i, but be aware, if you play PS3 games that only read 720p on the back of the game box, the PS3 will down convert them to 480p instead of upconverting them to 1080i.
Peace, Bob
Posted on Aug 06, 2008
I have a hisense 50H5G and i cant figure why it wont go to 1080. Its says 480 and i have a hdmi cable and hidef channels. Please help
Try to change from your HIDEF output setting from 480 to 1080 if output from HIDEF not proper then your TV also not work at 1080
Jan 25, 2015 | Hisense Televison & Video
Records & dubs but very poor resolution
You've got a Dish Network's HD DVR and a Toshiba 720P HDTV - so this part of the mix will maintain the HD pictures and high quality digital audio that you're used to seeing.
The trouble begins when you introduced the Magnavox VCR / DVD device. The highest quality video content that this device can record is the 480 type, regardless of the input or source quality - which in your case would be 720P via HDMI cables. 480 is considered "SD" or "standard definition". This is the weakest link in your setup and is responsible for your unsatisfactory results.
The Magnavox will "upconvert" to 1080 lines of resolution. The key here is the term "upconvert" True HD recordings are taken of a scene and capturing either 720 or 1080 lines of resolution in the image or video (such as a camera taking a photo or video); or recording the playback of a previously recorded 720 or 1080 lines of resolution source. Recording a 480 lines of resolution source with a an 720 or 1080 lines of resolution device will not make the image HD. The recording can not possibly be better than the original. In fact, due to losses, each generation of copy becomes worse and worse. Upconverting simply "fills in" the missing parts between the 480 source and 720 or 1080 output with what it "thinks" is missing data. The results are what you see on the screen. The original capture did not save more info that 480 lines of resolution so it is really impossible to improve it.
The recording can not ever exceed the quality of the original (the Dish Network DVR at 720 or more) and will only be as good as the weakest link (the Magnavox DVD / VCR at 480). Additionally, the moment you change from digital to analog, you lose quality instantly. Digital signals - both video and audio will always be faithfully reproduced do to error correcting technology, etc. that simply isn't available in the analog world.
You need to use a digital recorder capable of capturing and playing back of 720 or 1080 lines of resolution video and AC3 audio for optimum video and audio on a Blu Ray recorder or other device with hard drives or memory such as MP3 recorder. Otherwise you'll have to accept reduced quality of standard L & R analog audio and 480 lines of resolution of SD video. You can not expect HD audio and video if you try to save to equipment designed for SD / analog.
Dec 19, 2013 | Magnavox ZV427MG9 DVD Recorder VCR
How do I change the resolution from 480 to 1080
If you have DirecTV you can just use the remote by pressing the formay button on top right.............
Oct 22, 2012 | Vizio GV42L 42 in. LCD Television
Change element tv from 480 to 1080
The TV will play whatever signal (480,1080 etc.) it is being given, that is to say if you have 1080 available that is the resolution it will switch to, so there is not anyway to change this.
Feb 06, 2012 | Element Electronics Televison & Video
Change dpi from 480 to 1080
to change the resolution you will need to change the source. So if it's a DVD player then you have to make sure it's outputting the higher resolution. If it's a cable box the same thing. also to get 1080 you need to have component or HDMI hooked up. If you need further assistance let me know.
thank you,
Lee
Jun 09, 2011 | Vizio L37 Television
Change from 480 to 1080
You can do it from the PC. In windows, right click on the desktop and select Properties->Settings. Here in Screen Resolution you must select the resolution that you want.
Jan 12, 2010 | JVC GD-17L1GU (Black) (Black, Gray) 17"...
Mine wont play anything a DVD it recorded it wont let me finalize
Today with HD High Definition TV these kind of problems appears because the new dvd players have more video resolution options, so, for playing all variety of dvd, and home done dvs,s (like family movies on dvd) you need set up your resolution video on your DVD player at 480i or 480p option, not higher because some DVD movies (mainly oldies) have lower resolution than newer , for example new movies on HD format have 1080 P resolution, and if you have this option chosen in your DVD player you only can see this kind of videos, on the other hand if you have chosen 480i or 480 p on your dvd player , you can play all dvd formats including home movies made with any movie software, in this way you can play dvd-r and +r movies and of cours you can play HD movies also. So put some dvd where your dvd player works well (you need see the dvd menu in the tv screen), then press stop. Then press setup in your remote control, go to video resolution and choose 480 I or 480p, then press ok AND ENJOY THE MOVIE.
Smart techniques
Jul 07, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Hi there i cant remember how to change the resolution to 1080 it is on 480 and i would like to change it i have a 62" mitsubishi can you help
usually the set will sense the resolution and change itself. the format button on the remote changes the screen size
Jan 04, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Change from 480 pixles to 1080 how do you do it ????
Do you have the HDMI out in your Xbox??
The input is auto switching for the resolution.
Oct 09, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Mitsubishi WS-65413 65" Rear Projection Television Logo
324 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
