Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Error code F70
Displayed this code and power will not come on. Only does a twinke noise.
Machine less than 1 yr old.
  • cehelwig Jun 22, 2008
    Thanks gents,
    I did call and the service man will be out monday. Strange that they don't put the error codes in the trouble shooting section of the manual. The "tech" that I talked to wasn't sure but suspected it was the main controller. I hope this failure isn't a sign of the future for this product.
  • dbwhitsell Jul 23, 2008
    Same problem with kenmore dryer past warrinty period.
When you open up your washing machine, taped to the inside of one of the sides will be a plastic sheet, with a detailed list of troubleshooting problems/solutions, and all the codes for that particular model.
Joel
Posted on Jul 06, 2008
  • 413 Answers
This indicates a problem with the main controller. You can try unplugging for 30 minutes then plug back in. If you continue to have issues, call for service as this machine is under full warranty if less than 1YR old..
Posted on Jun 21, 2008
  • 487 Answers
Ok when the machine is less than one year the warranty is still in effect. Please contact Kenmore prior to opening up the machine as it will void the warranty.
Contact kenmore for this
Tip
Whirlpool duet F70 and F71 error codes.
F70 and F71 are two logic board error codes that point at a communication error between the main logic module and the control pad (user interface and CCU), and between the motor control unit and central control (MCU, andd CCU that is main control module).
Repair is difficult, as motor, wiring and voltages from control modules must be tested.
Try first doing a reset, by disconnecting power cord or tripping circuit breaker and leaving power off for five minutes.
If that does not help and errors come back, then the best thing to do is calling the service number listed on the user manual.
Here extensive explanation of error codes and relative troubleshooting:
F70: CENTRAL CONTROL UNIT HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and the Central Control Unit.
3. Replace User Interface if drum is rotating.
4. Replace Central Control Unit if drum is not moving
F71: USER INTERFACE HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
4. Replace Central Control Unit if drum is not moving.
To get parts and diagrams try entering the full model number in one of the websites below:
Enter the model number ..
To contact a repairer, call the number listed on the owners manual or use the Fixya directory (US only)
on Nov 05, 2010 | Whirlpool WFW8300SW
I have a front loader MHWE3000VW12 it's giving me a code F70 Ineed to know what it means
Thanks
Jul 26, 2012 | Maytag Washing Machines
Whirlpool duet getting error code F70 and F71. When hitting start button, getting a clicking sound and nothing is happening. Cannot open the washer door as it is locked with clothing inside it.
Hi jreib29,
Hope this helps.
Thank you for using FixYa.
Sep 17, 2011 | Whirlpool Kitchen Ranges
I have a Kenmore model 11049962603 that displayed an f-71 error code. I ordered a new cpu computer from sears and installed it. the machine seemed to work for one or two loads. now it displays an f-70...
I provided a complete list of error codes for this type of washer in the image below. The error codes vary by the exact model of HE3t washer that you have. Since you have an HE3t that is displaying the F70 and F71 codes, the list below should apply to your model. These are not listed in the owner's manual because they are intended for technicians. Use extreme caution if you follow any of the troubleshooting described in this information sheet. Unplug the washer and shut off the water supply before accessing internal components.
The F70 and F71 codes indicate that you have a communication error between the CCU (Central Control Unit or main machine control board) and the user interface touch pad assembly. Here are some troubleshooting tips:
Make sure that you have the washer plugged into a properly grounded 3 prong 120 volt AC electrical outlet.
Unplug the washer for 30 seconds to allow the control boards to power down and reset. Plug the washer back in but do not touch the power button (or any other buttons) for 1 full minute. This may reset the control board. Pressing the power button too quickly after reapplying electrical power to the washer can cause the F70 or F71 code since the CCU does not have time to recognize the user interface control.
If the above tip does not help then the most suspect component failure is the MCU (motor control unit -- motor control board at the bottom of the washer beside the drive motor). You can check for this failure by unplugging the washer and then pulling the MI3 connection on the CCU. The wiring diagram below has the MI3 connection highlighted in red. The connection has blue wires. The third image below shows this connection on the control board. The connections are labeled on the control board. Press the tab at the bottom of this plug down and then pull it out. Power up the machine with this connection unplugged and don't touch any buttons for 1 minute. If you then press the power button to turn on the washer and don't get the F70 or F71 code then the MCU at the bottom of the washer will likely need to be replaced to fix this problem. A technician would normally be needed to verify this failure and replace the MCU. The MCU is expensive ($423).
This troubleshooting information is based on a common HE3t model that displays the F70 and F71 codes. If you need more help, submit additional details and the full model number of your HE3t washer.
Mar 27, 2011 | Kenmore Washing Machines
Error code f70
F70 Error code means Central Control Unit Heartbeat Failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
F71 error code meansUser Interface Heartbeat Failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
In both the above situations the following things are required to be checked and replaced where required:
1. Continuity of the User Interface harness.
2. Wire harness connections to the User Interface and the Central Control Unit.
Oct 04, 2010 | Whirlpool Duet WFW9550 Washer
My washer is one year old I have use it maybe ten times this morning the power was on and the it would not go in to any cycle I then unplug it and tryed again then no power at all it sound like it won'ts...
Hi
Thanks for using FixYa. Error F70 is Central Control unit Heartbeat failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface. To resolve this issue you'll have to:
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 14, 2010 | Kenmore Washing Machines
I'm getting an F70 error code. Unplugged the washer once, which allowed 1 load of laundry to be completed. Then the effor code came back - which does not allow any thing else to happen. My book does not...
Hi
Thanks for using FixYa. Error F70 is Central Control unit Heartbeat failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface. To resolve this issue you’ll have to:
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 27, 2010 | Washing Machines
Can anyone tell me what an F70 code is? When I push the start button it beeps at my twice and then in about 30 seconds I get a long beep and the error code F70 is on the display. Thanks in advance for your...
F70 error code indicates Central control unit heartbeat failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
Thank you !!
Jun 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Flashing code F71 then F70
We've owned a Whirlpool Duet Washer (WFW9200SQ00) for about 3 years. We started getting the F70 error code intermittently about 6 months ago and it seems to progressively be getting worse. Unplugging the unit for a few minutes resets the error, but it comes back about every 2nd or 3rd load causing my wife a lot of frustration and with 4 kids, our laundry was backing up. After reading several Forum's, I found the F70 error code indicates a "heartbeat" communication error between the various electronic boards inside the washer and the consensus seems to be the most likely culprit is the Motor Control Unit (MCU) board. Before spending nearly $250 for a replacement board (http://www.helpfulparts.com/servlet/the-5733/8183196/Detail) with no guarantee that it would fix the problem, I decided to take the board out of the machine and inspect it. What I found is the connector for the communication (the connector with three blue wires) on this board is a very unreliable connector that uses the edge of the printed circuit board on one side of the connection instead of a real connector soldered to the board. In addition, the fit of this connector seems to loose to make a good connection. I noticed a little bit of corrosion on the board contacts which I cleaned with rubbing alcohol and a pencil eraser. After re-installing the cleaned board we've done several loads with (keeping my fingers crossed) no errors. I am still concerned about the reliability of this connection. Because of it's location, this board is subject to a fair amount of vibration and because of the loose fit I'm concerned that this issue will only come back over time. I've already decided that if the error comes back I will solder wires to the contacts on the board to provide a more robust connection. It's a shame that you can spend well over $1,000 on a top of the line washer, and in order to save $.10 Whirlpool decided to use a very poor connector in a critical area. It makes you wonder where else did they skimp to save a few pennies?!! Our next washer will not be a Whirlpool, and next time will not get a high end washer with all the bells and whistles.
Oct 02, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
89 people viewed this question
Sal De
fordexpert
Robert Rankin
