Old Maytag model A510
My washer was fine yesterday. today i got a load going, but it won't get past filling up the basin. i hear it running/clicking as if it is trying to get to the next step, but it won't start agitating. I also tried all the other cycles, but nothing will work. I realize it is an old washer, i just need to know where to start looking for broken parts.
thanks.
  • br ball Nov 15, 2008
    permanent press cycle stopped working a few months ago so we started using just the other cycle. today it filled and then stopped. it still makes the clicking sound but nothing else. what should we do?
I know this is an old post but, the most common reason this problem happens is because the timer fails to advance to the next cycle. There is a complicated escapement linkage between the timer motor and the timer cam inside the switch that likes to screw up. It usually burns off one of the sets of points so you can still have fill but no spin or fill and spin but no agitate. The most common set of points to burn off would probably be the set that relates to the spin cycle as the most amperage is flowing to the motor while under the strain of spin cycle. Remedy? Get a new timer switch probably about $50.00 American
Posted on Mar 28, 2009
  • 38 Answers
The lid switch is bad
Posted on Jun 22, 2008
Maytag ensignia top load washer will not fill with water at start of the cycle?
The drain hose has to be at least 30 inches above the floor or gravity will drain the machine. Also: If the water hose is jammed into the drain a siphoning affect will occur in some instances.
Aug 04, 2012 | Maytag Ensignia MAV2757AWW Top Load Washer
Maytag stackable top load wash maching - will fill with water but then nothing. It just stopped.??
Hi. Listen for an audible click as you just open and close the lid. You should hear a micro-switch. If you do not hear that click you most likely have a bad lid switch. A bad lid switch on a Maytag washer will still let it fill BUT, it will not agitate or spin.
If you hear a click then there are other things to that can cause the symptom that it would spin but not agitate.
Thanks for choosing FixYa,
Kelly
Aug 26, 2010 | Maytag WD16 Top Load Stacked Washer /...
Maytag Top Loader Thumps When In Spin Cycle
My guess is that one of the three counterweights have separated from their support. Probably rusted away.
36 years is quite a feat. Today's machines would be lucky to 1/3 of that life.
Sounds like its time to go shopping.
Do you have an anniversary coming up?
Ladies love washers for an anniversary gift.
May 24, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Washer won"t fill with water
check your lid switch if its a top load
May 18, 2009 | Maytag LSE7806A Top Load Stacked...
Won't run
sounds like your lidswitch.when you close lid you should hear or feel it click on and off.located on back side of lid in center.
Mar 10, 2009 | Maytag LSE7806A Top Load Stacked...
Washing Machine will not fill with water
It sounds like the water solenoid has gone bad or stuck closed OR timer/control knob has bad set of contacts which control the solenoid.
Jan 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My Roper won't fill with water.
you need to replace the water inlet valve on the washer that the hoses go on,it is stuck closed,have you tryed hot water only to see if it comes out?the valve has a hot and cold water supply valve,you can get one by going to sears .com click on parts out in your model number and order your part,let me know if you want to try it and i will tell you how to get into the cabinet-mike
Nov 18, 2008 | Roper RAS6233KQ Top Load Washer
Washing Machines Logo
304 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
